Posts posted by Yowzer
If it sounds like that with the factory RPM, yours is gonna sound insane!
- 7
I do like how the engine is barely in the car and we're already discussing extensive engine modifications
- 5
That would give a sweet revving 3.2L.
How much do ya reckon you could bore out the 4gr?
The clear option for your valve issue is to throw the 4GR in the trash and run the 2GR, just as nature intended.
Software, the EGR hardware is still on the engine at the moment but functionless, the DPF has a pipe shoved through the centre. The car is pre DPF removal threshold (anything registered after May 2010 has to have an emission cert or something or it's a WoF fail if you ditch the DPF) but I left it looking factory just to avoid hassle.
- 5
In modern Deez spam, I ditched the DPF EGR and remapped the Alfa to an estimated 250hp, but it was a bit laggy and pretty smokey. Suspected it was suffering the usual clogged up sticky turbo vanes, but fortunately found it was just a bit of something blocking up the vacuum circuit so it was getting piss all suck on the actuator. Cleared that out and now it fries the tyres a little too easily. No idea on EGT yet as I don't have a probe. Next up is an intercooler improvement as the manifold temp sits around 40°c cruising and easily cranks over 70 when given the jandal. The stock intercooler sits at the bottom behind the AC condenser, which is full of bent fins and moths.
- 7
On 17/03/2023 at 08:50, CaMpylobacter said:
man I dunno why people go so wild about 1kz being some kind of GOAT
precomp diesels.... what the hell eh.
Since Quatro is no longer here..
1KZs suck.
On 15/03/2023 at 20:53, Hemi said:
Not really my area of expertise tbh, maybe worn valve guide seals?
hard to tell without seeing eveything.@Yowzer might have a better idea
They can crack into the oil gallery and things like that. New head reckon injectors new radiator new viscous fan flush the fuck out of the block mechanical pump conversion wind up the boost and fuel three inch zorst no muffler loosely fitted poddy off the front of the blower and send it
You could potentially find a factory flywheel for it, as they did come with a manual box in the IS250. Although there's a likelihood they'd be dual mass and not work with a J160..
Yeah CVs don't give a fuck. Slap it and send it.
I still think a ESC from a RC car / drone is worth investigating haha
No idea if they'd actually be compatible with the motor, but I don't see why not, pretty sure they're just a regular brushless design.
Those spiral sockets work good, send them with the impact.
Chuck an AliExpress Hobbywings ESC on it
Ask @UTERUS about smartdrive washing machine motors. Great for gokarts etc
Shit works good if your engine sucks. Don't bother if it doesn't.
On 20/10/2022 at 12:13, tortron said:
What does a top switch/high gear switch do on a manual gearbox.
Obs. it's activated when it's in top gear. Tell the ecu to change something like lean burn or timing?
On a Triumph it's the overdrive switch. Has a planetary overdrive stuck to the end of the manual box.
Come on, what were the numbers?
Get those outboard injectors on there stat!
30 minutes ago, Willdat? said:
Hey team, a mate has bought an 2014 Pajero, 4M41 engine, 130km, he's wondering whether an EGR delete is an essential or not? I guess the wounders may have recovered from their tour @DoBro Jesus
Best option on one of those is to pull the manifold and EGR valve / cooler off, clean the fuck out of everything and fit a breather catch can to reduce the amount of oil vapour entering the intake.
If you do ditch the EGR, you ideally want to ditch the DPF as well as that is gonna run into issues with regen otherwise, and being newer than 2010 you can't do that without an emission cert.
Sometimes they can rotate as well which causes weird running issues.
The headgasket holds them up so they don't drop very far, damage is usually very minimal but you'd definitely wanna check the head for cracks.
19 minutes ago, Unclejake said:
Not a scenario I'd considered at all my friend! I'll get the head off next week if possible
If the pre-chamber was lose would it be likely to connect to the piston crown at every TDC (incl exhaust stroke)? If so then it seems a less likely culprit.
Good lord inside diesel engines are dirty. I've only ever touched one before this one. It's yuck.
They tend to drop down, get hit, stick back up for a bit before dropping down again so you do get weird intermittent knocks from them
I'm not familiar with the HZ heads, do they run prechambers like the dirty L engines? They do come loose sometimes and give the piston a bit of a taptap.
Edit: A quick google says yes they do. I'ma throw a guess that's what's up.
Those are fucking cool!
- 5
Beated.
I am currently studying to become a wof inspector.
I am not enjoying it.
For Questions Regarding WOFs/CERTs/NUMBER PLATEs
in Tech Talk
You must have a good stack of declarations for vehicles that no longer exist
