Roman
Posts posted by Roman
  1. G4 cant upgrade to a G4+ or anything like that.
    I'd recommend downloading PClink for both G4 and G4+ and see how they compare.
    G4 software is alright but a bit more janky than G4+ which has had another 10 years of updates or whatever.
    If you've got a serious itch for ethrottle, that's the only reason I'd consider the G4 xtreme over a G4+ storm.
    (assuming G4 xtreme does ethrottle, cant remember)
  2. 1 hour ago, kpr said:
    Generally to keep your tuner happy as possible.  you want to leave your car at home, drop them off a large sum of cash, along with that V and pie, then leave.
    • Haha 3
  3. 45 minutes ago, bigfoot said:
    My lancer is running a g4+ atom. I have a air temp sensor from a commodore and a map sensor from a celica or something similar. Fairly easy to find at pick a part. Managed to tune it myself with guidance from @Roman, I shoyld probably pay a visit to @kpr at some point
    You should, I bet you've got a lot of power hiding in your ignition table at the moment.
  4. 8 minutes ago, mjrstar said:
    Is there hp left on the table by not accurately measuring iat on a stock ecu? My thoughts are being n/a then probably not..
    If it's MAP based, then IAT decently contributes to the airmass calculation. But if it's MAF based then IAT does hardly anything.
    Maybe you could wire in a potentiometer, so you can adjust it and see if you make any gains. haha
  5. If you get canbus based wideband controllers, you can run one in each bank and read from them both.
    Then this way you also dont use up any of your precious analog inputs, annnndddd its way more accurate.
    G4+ is pretty good but honestly wouldn't recommend going older than that.
    As the software is a bit more janky and you'll grow into some of the features that are in G4+ but not earlier models.
    Idle speed correction isnt a huge deal really, but yeah get rid of the stepper based one.
    You can calibrate any sort of IAT to work, same goes for MAP etc.
    However I've got a favorite that has good fast response and they cost nearly nothing. Dont go paying $100 for an IAT sensor, they are literally just a 0.005c thermistor with some plastic bits to hold it in the air stream.
  6. 3 hours ago, Rhyscar said:
    and then I thought about it some more and a car is wider than it is tall, so the air moving around the sides has been displaced as much, if not more than that going over the bonnet.
    Here's another thought.
    You have a high pressure zone right at the nose of the car.
    then a low pressure zone right at the middle of the rear of the car.
    Why not run a big tube through the middle of the car, that joins the engine bay firewall to the lowest pressure area at back of the car.
    Turn your car into a donut for reduced cross sectional area. Haha
    • Haha 2
  7. I guess another way to look at it - There are fast as fuck race cars, that do any and all of the above.
    So long as you are following some well established general principals I'd not get too hung up on the details for starters.
    I bet there's a fairly decent deadzone where you get similar results from lots of different ways of doing something.
    Where different wings or angles etc are a fairly linear drag vs downforce tradeoff.
    Then you're chasing incredibly diminishing gains to optimize it all.
    Might be time for some sideskirts? 🤐
  8. The Alfa 155 DTM cars did the dual radiator thing where they come out in front of the wheels. But yeah I agree its likely more to do with rules than ideal aero.
    I am guessing much like BTCC, they werent allowed to change the body panels much or at all.
    So werent allowed to chop a big hole in the bonnet, but modding the bumper was fine.
    So it was probably just best way to deal with a bad situation handed to them by the rule book.
    It's funny how many times race car stuff isnt "ideal" so much as, just best conforming to some really abstract constraints.
    Alfa 155 V6 TI Collection of informations. | Alfa Romeo Forums
    • Like 6
    • Thanks 1
  9. On 17/04/2025 at 18:59, Gravity Sucks said:
    Wondering where you've got to with this project ?
    What news do you have to share ?
    I ended up moving house and not having any garage space any more.
    There is an fb group for diy flow benches though, and using a MAF is a popular option.
    Might get back to this one day, but not any time soon
