ThePog
Everything posted by ThePog
  1. Nothing you couldnt sort im sure
  2. Someone is an optimist Also Turbo fucked you mean
  3. Ill take more pics later...
  4. So this showed up on TM and I put a cheeky bid on it, this was done without the knowledge or consent of the boss, but easier to ask forgiveness etc. It turned out to be just down the road. The seller had a similar story to mine, sold it years ago and it was a show car, hence the probable mad rear wing and hood scoop to ventilate the frunk. It had an uno turbo motor at the time. It got driven to Nelson from Tauranga and parked up, never to drive again until he saw it and bought it back, but its now dereg and turbo fucked so not worth doing anything to. Anyway, its mine now. There are plenty of good bits, uno turbo front brakes mostly, and lots of little bits of useful goodness that my car will benefit from. He had another rolling shell he wanted me to take, but it was way more fucked than this one altho it had ok lowering springs in it, so maybe I'll go back and pilfer those. I will now spend a week or two appeasing my wife....
  5. The X1/9s have a factory 5 or 6mm spacer, I know chaps who have been pulled up in it and have had to prove they were factory...
  6. Ah so there is a bit going on. There is a solar powered cabin that I work from that needs a bit of cloudy day capacity. All the dumb ideas are for this. The house does not have solar but it probably will later. When this happens it will definitely have a solar hot water diverter.
  7. Na the extensive real estate holdings of the pog empire means that that is our actual house. The only one spying on my magnificent manlyness porpoising in the spa is the middy. Of note is that the shed is significantly better appointed than the house as you can see.
  8. Cranking the redneck spa again, its about 2 hours to get to 38deg which isnt too bad. Altho you do need to be there to keep the fire stoked. It always amuses me that for a while at least there is condensation on the pipes enveloped in flame.
  9. https://xwebforums.com/forum/index.php?threads/completed-1976-x1-9-ev-conversion-ask-me-anything.45263/#post-441284
  10. I have had a quote to put 16 panels with micro inverters to offset the house use and with a unit to dump the excess into the hot water cylinder, it was surprisingly cheap, like 16k. So maybe at that point I'll just plug in, but meanwhile this investigation is a good time.
  11. I have also thought about buying some old leaf batteries as cheap storage.
  12. Electrolysing hydrogen sounds like a good time
  13. Looks like it, unfortunately I just dont have that much elevation. I do have another two panels so can potentially generate 1.5kW to fill up scrap batteries.
  14. Im not sure hydro is the way. I found an online calculator for micro hydro and it seems that to make 800w for an hour with a 10m head I would need 54000 litres...
  15. Yea so I am thinking about replacing my inverter and charge controller (due to that noisy power stuff we discussed) with a solar inverter unit of much higher quality, and the ones I have been looking at have a 230v input for plugging in to shore power or a genset. So I guess running 230v hydro isnt out of the question....? The most convenient arrangement for this would put the hydro something like 150m away from the cabin. Fuck now I have to work out how much head and capacity I need.
  16. I actually know a man who just replaced a shitload of his batteries in his solar setup, even at 70% soc I could stack up enough of them to be sweet....
  17. This. Hot water is no use to me in my cabin, and extracting useful work from even 100deg water is mechanically intense. Steam is a different story but not suited to slow, intermittent power input. I am keen on pumped hydro but while I have a good fall on the land my cabin is at the top of my property, this makes the power cabling back to the cabin very lossy. I might be able to convince my neighbor that another 25k litre tank up in his paddock above me is a good thing.
  18. I watch too many youtube vids for off gridding. But I have a certain amount of power capacity on a sunny day that goes to waste. My battery is fully charged by 9.30 or so and all that lovely power goes nowhere. And sometimes I need extra charge on a cloudy day. So I have devised many schemes for capturing that power to use on the cloudy days, and this 'seems' like a relatively simple one. I have also thought about pumped hydro but the infrastructure requirements are a bit too hard out where I am. I have thought about winching a heavy weight up then letting it fall down and spin a genny, but my P=mgh or whatever it was told me it would need to be a very big weight lifted up really high. I have thought about a sand battery heated by an element, with a stirling cycle engine sitting on it. There is no wind in Nelson and in particular in the valley where I live. So now I have the scheme of several old gas bottles pumped up to less than they are rated for, spinning some sort of air motor/generator as needed. I also am looking for an old multifuel Lister genset, so all my waste oil can get used up. Any othe suggestions are happily considered, particularly how to store my excess solar (and yes I know more batteries, but that is no fun). I am hoping for a fairly simple solution, but that is probably the eternally optimistic dickhead I am. This will be static, its backup for my wee cabins solar setup....
  19. Yea I did the obligatory AliX search and saw that. A strong possibility. I shall have to investigate this. I have no idea how an air over hydraulic accumulator works.. Edit; on some cursory googling I am not sure that has the capacity I am after. The key is to have a lot of air at a lot of pressure so getting something like 600watts out of a generator for a day or so. I did a basic spreadsheet and its a lot of air.
  20. It is to make an air battery, basically use the excess solar I generate to pump air into a large tank. Heat shouldn't be too much of an issue as I wouldnt think it would be fast. But a slow high pressure pump is key, I am just not sure what that is.
  21. If I were to find a high pressure, low flow 24v air pump on the cheap would I find it in the form of a truck AC compressor or the like? I am talking up to 2000psi or some decent fraction of that sort of pressure..
  22. Fuck yea!
  23. Part of the roof attachment mech is two hooks that are steel bits covered in rubber. After 40+ years this falls/wears off and the roof rattles like fuck. There are many fixes that involve packing shit with tape etc, but as I have the technology I thought I would solve it. First I just drew the boys up and printed them in PLA with carbon fiber, these looked pretty schmick. However the originals have a steel backbone and this was always going to be stronger. So I had the idea to trim all the old rubber off the originals and print a TPU sleeve to replace it. I gooped these on with some leftover windscreen glue, they are working well. The international X1/9 community got pretty fizzed about that let me tell you. I then printed some more plus some of the plastic pads that fit on the car in the same junction for the black X/Elliot. And while I am on a massive printing bender I modded the heater control faceplate by adding some lever detents to keep the levers in position, then drew up some vaguely factory looking knobs to interface with this detail. I made the top layer of the print a Hilbert curve, it gave it an interesting texture; And finally the rattle. More investigation found more shit in there in a completely inaccessible place; So I dumped a shitload of cavity wax (actually a bitumen ish thing) down there to glue it in place, and it kinda worked but not 100%. Shits quieter but still there. Sigh.
  24. Ah man I looked at making a turbine out of a turbo, just need to sort the injection situation /probably a shitload more to it. Also using a waste oil burner to make steam to feed the same thing. So many dumb options, I should just choose one and run with it.
