ThePog
Everything posted by ThePog
  1. In my bus i will be running a gas hob only. I have made the box for the bottles to what I believe is the correct spec, and the hob has flame out protection etc. What i want to know is can I just run a standard gas reg/gas pipe to the hob? There is no physical issue doing this as it is not a long run between one and the other, so it means no need for gas fitting etc. The regulations I have read state a need for all work to be carried out by a gas fitter and then certified, but there is no actual gas fitting required...? Any of you lot know the rules?
  2. Some time consuming stuff happened, mostly creating the gas bottle box. I thought about buying one but it would have meant quite a lot more surgery to fit and they were bloody expensive. This is tidier anyway A hole; A cagey bit of stuff tailored to the exact size that was available underneath, but somehow also perfectly sized for 2x 4kg gas bottles - I hope - although i did go to Mitre 10 and measure the bottles there. There are locating rings and tie hooks as well; Slammed into place; Not the tidiest work I have ever done, and the door sits out a wee bit too much. But I can fix this and the thing is solid as. It is all removable anyway if it needs some mods. I also placed some ply in the main bed frames and put a layer of PU floor tiles in there to maximise the comfort. Not really, this was actually because I had 12mm ply sitting in a 25mm angle frame, this meant about 10mm of the frame was sitting above the ply. The foam fills in this gap nicely. I also fixed the water tanks in place and made a mount for the water pump that Shane supplied out of his bus stuff. I am going to try to get the water system hooked up before the COF check....
  3. Sorting the really important things
  4. I am sure sidewaysickness knows a few people in takaka, I am sure one could grab the book for you..
  5. Been smashing this out over the last couple of weeks, things are going swimmingly. I bought some 100l water tanks and started building the bed etc around them. I also built the second story bed frames. Unbelievably all this shit has used 48m of 25x5 angle. Then I built a bench for the sink, gas burner and fridge, I put my poos wood working skills to good use. It is all pretty minimal at the moment, and will probably stay that way. It will need more bench space, I have a plan for this. The main bed will be two king singles. This is so they can fold away either side with the mattress, so then big things can get put in that space if needed. Also it means that either side can become a sofa as well. Yes I know I am a fucking genius, thank you.
  6. Yea pretty stoked considering it hasn't had a cof since 2009!
  7. A nervous 40 minute wait today, only to find that it failed the COF........... on broken exhaust clamps. YEAAAHHH MOTHERFUCKER! Ian is looking like the bargain of the century right now. Obviously it got pulled up on the cert issues, including the roof, plus I need it to have a bed etc before I can convert it to a camper registration, so 28 days to rectify this... Totally doable.
  8. I painted the roof with a bit of white, then I put the windows, seats and seatbelts in. This is in preparation for taking the old bitch for a COF check. Now I just need to sort the horn button properly and this can be done. It hasnt had a COF since 2009, so this will be very interesting. Everything seems to work pretty well so if it is anything it will be suspension/steering joints or brake imbalance. Initially I will not actually get a COF as it will fail on the mods I have done for the seating and seatbelts etc, but if they pull me up on the roof mods or the like (which they technically cannot as there is nothing in the regs regarding this, but you never know). This way I can then discuss with the cert man getting anything like this that I might fail on included in the paperwork. We will see. Shit is theoretically watertight now... The lounge;
  9. As I did not make it to Hanmer I decided to crank a whole lot of shit on the bus. Firstly I painted all the blue bits after extensive prep work, ie scraping the particularly big lumps off with 180 grit sandpaper then losing all interest. Then I finished it with two coats of highest quality Lumbersider in a shade called 'Elephant'. I would genuinely like too see an elephant this shade of blue, that would be absolutely fucking remarkable. This came up pretty much perfect. Then I painted the roof with black plastidip after a coat of etch primer (seen in the first pic), this looks pretty good too; This will get painted white in the near future. Then I did the very last rust work around the headlamps. They were small patches so i used the time honoured technique of throwing weld at it until it burnt away enough thin metal to start sticking, then worked my way back filling in the hole. In between all of this feverish activity I also painted the upper window frames and placed the glass. The application of sealant was not pretty, but it will be high enough that no one will see it. There is zero doubt that the windows will seal given the amount of poo that got flung around. The glass is 4mm and is tempered etc. It even has the wee stamp on it... Also I added some brackets inside the bus so that the plywood lining has something to attach to in various areas, I forgot to take a photo of these tho. Solid progress.
  10. Yea, I got it all sorted late morning yesterday. I still could have gone but was not feeling the love for the driving/fun in Hanmer ratio. I did end up getting a shitload done on the bus tho, plus helped the neighbour by pressing the bushes out of the A arms of his Singer Vogue. So not all bad...
  11. Got halfway up Spooners on the way to Hanmer and the lower exhaust joint blew out. I turned around and went straight back to the workshop to fix it, decided to do a socket joint to get more poo area. I got most of it done but then many many things work related stopped me from finishing. I also tweaked the bit of pipe so the routing was a bit straighter. It is all in place but still needs a weld around the pipe cos I cut it off to make the joint better, but now it looks like I have to take one of our cats to the vet cos it has muntered its paw trying to get into the washing machine... The Prime Cause of the universe clearly thinks I should not be in Hanmer
  12. The old bitch failed the warrant on rust in the sill, not too much work to sort it tho; Warrant man should be happy, I got a blob of weld in my ear, this made me unhappy.
  13. It kindof looks like I am running out of time to get the bus ready for Hanmer, so I thought I had better get the backup plan well and truly sorted. I have not really been driving the Humber as the exhaust manifold poo didnt work out too well, probably cos I ran the car before it cured properly. I knew I had fucked up somewhere cos the exhaust was leaking worse than it had before. I was also a wee bit marginal on the Mighty Car Mods style surface cleanup that I had done on the manifolds, so decided to man up and get it right. I pulled a spare manifold out of the pile, this had an unusual bit of tin wrapped around it which turned out to be covering a pretty substantial crack - so that one got binned. Fortunately I have a rather large pile of spares and simply dragged out another one. This one I managed to attach to my little mill drill and proceeded to machine all the mating faces; Saturday morning I spent installing this along with copious amounts more poo. I then left it overnight to cure. I have been driving it around today and it feels well and truly sorted. It will need a warrant this week, so I will try and get it in tomorrow just so I have a wee bit of time to sort out any fuckery that might arise...
  14. Spent the last few days sorting out grot, Shane found a full bottle of good rust convertor, so I put that to good use once all the ugly was cut out. This looked like a lot of awkward shaped holes to fill in, so fuck it, it can be all one patch... Then there were a few pin holes in a seam down the sides. This had been helpfully filled with bog and painted over, so it could become much worse without anyone knowing. How hard is it to put a bit of steel back in? This bit took 10 minutes max including cleanup... And a few little bits of ugly that I uncovered and rust killed. The bits around the lights will need welding, but that will be it I reckon... I have many hundreds of dollars of paint sitting in the workshop now. I just need to give the roof a wee cleanup before getting into the paint. Here you can just see the aluminium frames that I made for the windows.
  15. I did a bit of stuff inside tonight, added a few ribs and such; Then I decided to tackle the grot in the rear quarters and boot, so started cutting it all out. Then I struck gold in the form of a set of pliers used to pack out the hole. I then accidentally lost a key that had fallen out to the shop vac, so I decided to go the full forensic for the sake of science. This is the final haul; - Some sandpaper - A crunchie wrapper - A pen lid - A set of pliers - A lollipop stick - A bottle lid - A 1 yen coin - A NZ 5c coin - A button - A piece of wood - A piece of filing cabinet - A bolt - The lost key Naturally there was heaps of paper and shitloads of bog as well, but this must be some form of record. It is for me at least...
  16. Gave it a serious clean out today and tidied a few things; Made a functional horn button. This will need more loving as you need to remove a spade terminal to remove the wheel, but it works at least. The quick release turned out a bit shit, it is cheaply made and so the wheel wriggled when locked. I fixed this by sticking M5 grub screws into the alternate wheel mounting holes and jacking them out until the fuckers got nice and firm. Made a latch for the door so it actually close and locks... Made a battery cover and a mount for the isolator that I had installed when it was not charging properly; Then I sat and contemplated the goodness for a while, then went home.
  17. Ha, I was thinking about you today trying to remember if it was designline you used to work at. I was thinking that this shit was harder than it looked!
  18. Probly time to stop eh
  19. Pretty sure she still has her teeth sorry. You will enjoy climbing in where I came out of I am sure..
  20. I am sure she could do with some young dick.
  21. I do have a timeline I am working to, I will need to back off if I do not make it to hanmer as family life will really start suffering... Plus you are a useless cunt.
  22. The last stretch of roofage today, I had managed a wee bit over the week; So I used a sheet of steel to make the template directly, unfortunately I bolloxed this up and had to use my last sheet to re do it. Just as well I had a spare.. Then I slammed on the triangular bits and made sure they covered all the holes I had cut to get rid of the rust; Knackered now, that was a difficult bit to sort and it took 8 hours solid. In other news I have invested in a spray gun, some fuck off etch primer and some plasticoat for the roof. I also have a new BT stereo coming. I have a cunning plan for the interior insulation and painting, more of this at a later date. I have the horn to sort out and some rust to remove, then some windows to make and install, then I will take it for a COF and see what ugliness ensues.
  23. ThePog
    PAINT THREAD
    The data sheet for the resene one says brush for small areas only, I have some solid meterage to cover. I might need to man up and spray it, I do have a big old compressor in the workshop. I am just a retard with painting...
  24. ThePog
    PAINT THREAD
    Alrighty you useful bitches. I need to paint the roof of my bus once it is all welded up. I am going to roller it, mostly cos it is a big area and I hate spraying shit. What do you reckon to use for the first coat onto the steel and then the topcoat? I was kind of thinking red oxide then house paint, but that is just because I am a dickhead about paint. Enlightened my ignorance please..
