Posts posted by Nominal
10 minutes ago, dmulally said:
Hi All,
I'm struggling to find the VIN on my Commer Van. The engineer needs a pic of it for LVV cert. I can find it on carjam and I can find the chassis and body number but the VIN is eluding me thus far.
If it turns out I can't find it, am I going to have to drag it down to VINZ? Lord help me...Only first registered post 1 April 1994 will have a VIN. I would have though that a chassis number would be OK for certificaction?
9 hours ago, scooters said:
what? thats good/great retention. What do you do ?
Professional troglodyte.
Looks like something @kws could fix?
16 minutes ago, kicker said:
Not in, got my new roster and the earliest one I can make it to without taking leave is Feb 2020, see you then!
Time for a career change?
In like flynn
Take care spraying epoxy - get the right protective gear. When I started spraying I stuck with single stage paints for safety reasons.
36 minutes ago, tortron said:
I think a trv specialist would be like a paid to hoard Barry. Someone with an oily old pair of overalls and a chipped tea mug permanently in hand, a mechanical pencil in their chest pocket and long grey hair twirling from their ears, fully ensuring that they never hear a word you say and just hazard a guess when they start replying. The trv Barry keeps their workshop clean as no work is ever done here and takes pride in the cut to fit furniture blankets covering each car.
Basically, living the dream then?
3
27 minutes ago, kws said:
Discuss blindly buying cars and how good of an idea it is....
eh, what's the worst that can happen........
How much steel is in the bodywork/floor?
The Eastwood tool will be 120V/60Hz so won't be easy to run on our 240v/50Hz system anyway.
It looks like you can get them in NZ, but have to buy a 2KW transformer too.
http://restosupplies.co.nz/index.php?route=product/product&product_id=487
So you'll be nudging NZD600 anyway.
You can use this sort of thing on a right angle die grinder for the corners
https://www.amazon.com/3M-7515-Scotch-Brite-Surface-Conditioning/dp/B000LQLHPK
15 minutes ago, WhangareiKE70 said:
Can anyone give me good advice as to how to tell if your welds are up to cert standard? Just weld some things together and take them to your local certifier to be inspected?
I would like to do it myself as it will save time/money, but while I think my welds are ok, I don't know they are, if that makes sense.
Can I tack things together then just get someone to finish weld it, or will the tacks ruin the weld bead and make it look shoddy?
I built my own rear trailing links and such with a MIG. No particular inspection or weld testing was needed. If its a critical weld (e.g. front suspension) then NDT is required.
Otherwise just reasonable quality welds seem to be OK. You can check with the local C-man if you like.
26 minutes ago, h4nd said:
Where's the standards / requirements for ewof for caravan please? I can see many docs saying 'you must have one' but none syring what the the technical requirements are (other than it's 'proscribed work''). Thanks.
You could try reading on https://www.electricalforum.co.nz
Prepare for lots of this sort of thing:
On 16/12/2018 at 12:08, Truenotch said:
Weldsafe Titanium. 4 sensors, tig capable, 98x87 viewing area, replaceable batteries, all the adjustments, good headgear, cheap replacement lens covers.
Moortool have them on special for $139. Most others will be $200 or so.
Bought one of these from Moortool for the same $139 this week.
Tried it out tonight, and it's amazingly better than the cigweld one I have been using.
Might actually be able to see what I'm doing with the weld pool now.
3
Paging @Spencer
I put a lot of effort into this on the roof of my wagon, including sanding, wire brushing, metal prep (phosphoric acid) and undiluted hydrochloric acid (concrete etch type) multiple times. Still had some black spots/pits after all that so I just etch primed it and carried on.
I keep a Ford FE sized one in my trunk.
/ling post
Really really sure that the ignition timing is right and not 180 out?
38 minutes ago, tortron said:
I ain't even mad
Nice Mustang.
Get him to sell it and give you the monies?
3
I expect that these are all 15A, so won't necessarily work on a 10A household socket.
1 hour ago, 64valiant said:
also dug around for 2 hours or so to find the article on these two rx3s last night
https://www.pressreader.com/That link doesn't go to specific story.
Someone give me an RX8 and I'll report back on comparison to Morris Minor.
For Questions Regarding WOFs/CERTs/NUMBER PLATEs
in Tech Talk
I'd suggest you call the lvvta number and have a chat.
