Ned
Everything posted by Ned
  1. ok, a quick update... i'll be putting in a 2T-B instead of the mighty 4K i had put in earlier this year. i'll have it mated up to a T50 box. driveshaft and rear end will remain the same for now, and the interiour will still be a surprise
  2. dont know... just use gasket paper that can handle the heat of an exhaust (not sure if there is such a thing... dont know how much normal gaskets can handle...) and use that... with gasket goo
  3. liquid gasket goo
  4. Ned
    sr20de - ke70
    and parts
  5. Ned
    sr20de - ke70
    i know they are gay! and no, no diesel
  6. Ned
    sr20de - ke70
    i had a FWD starlet with a 2E (1300) that let of more smoke than that! and it only had 1 wheel spinning
  7. Ned
    sr20de - ke70
    my mates mate has one in a starlet, so it can be done. but as i said, watch the radiator
  8. Ned
    sr20de - ke70
    if you wanna fit an sr20, you'll have to probably mount the radiator in front of the car because i dont think you'll have enough room. this alone stuffs up any plans fro an intercooler! still do-able but more of a hassle
  9. Ned
    sr20de - ke70
    Yes! get a ZE though and turbo that
  10. find someone with the same car and have a look... best thing i can suggest... sorry
  11. never mind these guys, find some series 3 RX7 hubs and calipers, same stud pattern and will fit in 13's i think series 5 will fit in 15's... not too sure though
  12. Ned
    Cooling engine down
    yeah, all it does is let water through your radiator before its up to temperature. all a thermostat does is make sure the water only goes around the block, not the radiator untill your engine is hot (measured by water temp) the hotter the water gets, the further the thermostat opens. when it opens it lets water run through your radiator to be cooled, thus keeping your engine at optimum temperature. for people that didnt know, a thermostat is just a valve
  13. Ned
    Mk2 Rebuild
    yeah, that sounds about right
  14. Ned
    3t into a ke35 corolla
    i would personally not use a k50 box though... T50 would be the way to go if not a W55
  15. you wouldnt be able to drop it that much could you? with those massive wheels?
  16. Ned
    windscreen
    yeah. with the old dude. got his window replaced in 1967 or some shit
  17. Ned
    tuning a 4k carb
    goodl uck man. i ended up driving with my choke halve way 24/7
  18. Ned
    water pump
    drive up to appco in henderson man, those guys are way better then repco
  19. Ned
    windscreen
    i took my windows out with a screw driver... i had no interiour so no1 could sit down and reach the window i told you how to put it back in logan... or have you still not tried
  20. put a 4age in it
  21. Ned
    3Y engine question
    just find a replacement instrument pannel from a wreckers...
  22. Build //oldschool.co.nz/index.php?/topic/18597-droppdkps-1982-toyota-corolla-dx/?p=485310 when you getting us some pics man?
  23. fibre glassing isnt hard, well, its do-able. you could give it a go yourself? the fibre glassing that is. just make a nice mould out of foam or something and make 4 flares that are identical. or make 2 moulds, back and front... dont know about the cutting etc.. but about the cert, not 100% but there is a site, ask WDE BDY , but my front guards aren't considdered structural and can do anythingt i like with them (including giant rust holes) ring around.
  24. Ned
    3Y engine question
    that depends on if it is the guage, wires or sensor... sensor or guage should be as simple as ringing a wrecker, getting a "new" one and screwing it in. Wire would be a pain, but it seldom is the wire
  25. 2 best simplest things are letting everything flow better, eg exhaust (NOT TOO BIG OR LOUD!) carb and filter of some sort... i'm not into eskies but thats the general thing for all cars my 2c
