Posts posted by dabuzz
Lol at 20 minutes, you're obviously not in Auckland then.
Haha, I definitely know the feeling
keeps getting better and better!
aweome work
Yes, ratshit aye- just you cos you look like you cant afford anything nice they take it off you....
Sparky has finished, all new power feeds, added relays for ignition, fuel pump and rad fan which was previously straight off the key. Car starts great now, and does everything it should.
Have also pre wired the car for EFI, so if I decide to change over its very straight forward now.
Have turned attention to the fuel system, it had a return line back to the tank, and for a carbed NA rotary you don't want any fuel running away from the motor. It also runs the factory fuel lines, so until I get a chance to upgrade the hard lines to 3/8, I've done a small upgrade for now. Blocked off the return line, fitted guage, and 3/8 hose from the regulator. Previously reg was fully open due to return line. Have slso replaced the crusty looking filter cut it open and found years worth of crap on it
- 22
1 hour ago, Popwill said:
Full rebuild underway...
Oh nice, injection time!
where do you get your Rad overflow from?, I need something like that
If you're vapour blasting, you wont need to coat in anything else, the process leaves the finish very resistant to filth, if just bead blasting then a light coat of matte clear helps.
paint everything else in high temp black, and it will look tidy enough.
Be mindful that as you are not modifying too far, that once the beautiful clean painted block goes back in, it gets covered with ugly ancillaries, wiring and hoses etc that will do no favours for aesthetics, so no need to over think it.
Oh man, cut so much shit, remember everything worked, so it's just a tidy, but have also added feeds and relays ready for ECU etc in prep for possible future plans .
Maybe I should leave that earth just do the car remembers it roots.....
Nope ha
Awesome pics @locost_bryan thanks!
@Roman this the one you stumbled across in a shed many moons ago?
2 hours ago, mjb.nz said:
^^^ can someone shed some light on front cover oil set up. Is that a MFR product or some sort of dry sump set up?
Pictures are sooo goood! Loving all the beaten up mufflers. . Really sets an old mazda off IMO.
Yes MFR dry sump front cover - lush
My sparky mate came over today to start on tidying up the looms, they pretty much just grabbed everything from in the bay, and jammed it under the guards. Lots of redundant parts, and mixed matched wiring etc,we wondered if @Roman has worked on this in the past
The car has had issues with starting and charging, so with fresh wiring for those and rad fans, fuel pump etc will definitely help, we will retain all the rest of the loom for lights, horn wipers etc as those work just fine.
I personally wouldn't bother re-nitriding if only a light skim, the factory hardening goes deep enough
Agreed man.
you might also be pleased to know i have most of a 13b J port that im tinkering with atm, may or may not find a home in the 4
Agreed totally expect some work when buying an old car,but yeah......
took it out for a run today to test a bunch of things, and it's driving really nice now, suspension is doing everything it should, no noises at all, got up to temp, ran really well, felt pretty good all round
There's still a few things to do, as listed and it's not starting well ( bad starter/voltage drops maybe), I think that's down to wiring issues which I've already planned to look at. And I'm going to change the fuel system a little.
Overall, I'm starting to like the car, and it does look pretty sweet on road
Haven't fixed that yet
Waiting on my sparky mate to come and go through a bunch of other stuff, will do that at the same time.
I dont have a vid, but difference was massive, not so much in volume, its a little quieter(still loud) but with the stainless one, it had a terrible tinny resonance under load, was nasty to listen too, with the new steel boiler it sounds as it should without offending the ears, hard to really explain how it was before, the resonance got inside your head, it truly was bad.
ha, yea you be right about the overflow, maybe need to find an old school thickwall double brown one
This is not a rant, and I suppose at the end of the day I will have far more confidence in the car, and more importantly confidence with taking my kids in it, once I’ve finished going over everything. I thought it would be good to put up a current list of what I’ve had to fix here so I can look back and go WTF bro….
Still cant really believe how much I have had to do even though the car was;
A. Sellers quote “not some slapped up banger”
B. Halfway through a 6 month WOF
C. Pricey
1. Fitted 18 inch 3 piece Simmons wheels.
2. Full Red taillights.
3. Fitted rear ¼ Mazda RX4 badges.
4. Fitted new Red ¼ reflectors.
5. Fitted Rear seat belts.
6. Replaced Leaking water-pump.
7. Replaced front wheel bearings after having no grease, damaged and worn.
8. Replaced bent strut and remanufactured Coil-overs, they were a major safety issue.
9. Made new trans tunnel gear stick cover for massive hacked up hole, and fitted new shifter rubber to seal it off.
10. Fitted large new custom rear mild steel boiler muffler because it sounded awful in stainless – still loud though.
11. Replaced gearbox mount, and modified crossmember so it didn’t foul on the mount as it was before and banging.
12. Replaced worn leaf spring and hanger eye bushes.
13. Fitted new rear bump stops, to stop driveshaft hitting tunnel.
14. Replaced leaf spring pad bushes.
15. New U bolts as threads damaged.
16. Adjusted non-working handbrake.
17. Replaced Missing number plate light and bracket – rewire so it works.
18. Replaced missing window washer system with an under dash hanging bag – wire up as original system butchered and non-existent.
19. Repaired dash indicator lights, because of the Autometer dash setup they had to hack the back of the gauge cluster but failed to properly modify the wiring and bulb holders and their badly soldered joints just fell apart. Fitted new LED bulbs and wiring, and secured correctly so it all works now.
20. Fitted the correct Steering wheel boss as the indicator cancelling part in the one fitted was incorrect and the indicators didn’t turn off after completing a turn.
21. Reconnected horn as was just left unplugged, due to previous boss kit not reaching the contacts.
22. Thermostat was missing and thermo housing by-passed for full flow, coupled with rad fans on full time as soon as key on, meant on a cold day the engine wouldn’t get over 60deg and would run like shit. So I have un-modified housing, fitted new thermostat and a thermo switch to the housing (still yet to wire in with a relay) to be able to let motor warm up properly before fans kick in.
Things to do:
Calibrate speedo gauge.
Calibrate fuel level gauge – even though seller promised me he did this.
Deal with terrible wiring around car.
Get reverse lights working.
Fit radiator overflow.
Re make throttle cable setup.
Get a WOF
Then “maybe” I can start on the actual fun stuff……
- 9
- 7
super cool little car, amazed you can find 'any' parts for it!
Out of interest, who reco's water pumps these days now that Muzzas waterpumps has gone?
Rotary piner thread.
in General Car Chat
@oldrx7 that defo looks great - save save save!
