shizzl
Everything posted by shizzl
  1. hmmm, maybe it is the guides that cause the smoking....if i give it a rev theres abit of blowby/smoke from the rocker cover breather filter... wouldnt be a stupid idea to do them really...
  2. i plan to o/s the rings anyway,so block will get a hone heke...and will use a 265 head thatll need a mean skim to get the comp ratio up... not planning to do the valves or anything though...
  3. beauty.. but whats engineers blue for? finger painting the block?
  4. how tech is it to rebuild an engine? ie, rings,big ends and mains bearings? is it a case of just ripping it all apart and slapping the new shit in it? or do you have measure stuff... i want to get my hemi rebuilt asap, but cant afford to pay some "mechanic" to do it for me. especially when it could fuk out on the first lap... i know alot of you guys have rebuilt your own motors, and am super jealous of your epic skills. would love to be able to do my own shite also.. ive done the head gasket on the hemi, but now know i needed a composite gasket instead of the shitty steel one i got.. if you guys have any tips or advice please let me know.. alos if theres any special tools ill need.. obviously ring compressor and digital verniers right?
  5. yeah racetech seats are farking expensive for what they are.my mate paid $2500 for his one, last 2 years before it was fucked... thats a total of 25 meetings..
  6. haha just noticed both the front and rear ford badges actually say FRORD not FORD..lol... no progress here though,haent found a turbo for it yet
  7. hey man,is that an alloy seat in that thing? if you are looking to sell it let me know....keen
  8. obviously it will need to be rotated so the flange sits flat,and also the comp housing will need to be rotated so the outlet can be upright.. probably wont i/c cos theres fuk all room for a cooler/piping..would rather not have to cut shit up anyway.. so thinking of making a J pipe...little bit laggy but meh...not after huge power or anything anyway..the turbo has a smallish comp wheel by the looks,also a smallish exh wheel compared to the t3 on the ld28....so hoping for around 5-6psi.... just enough to be usefull..not too much to melt shit..
  9. had a random play with the turbo for placement.. plenty of room.. will dump the a/c cos it ddnt work anyway.. Uploaded with ImageShack.us
  10. vac leak??? spray some brake clean around the carby/throttle body/manifold to find leaks.. if it doesnt show anything then you may had a torn/fukt diaphram...
  11. Uploaded with ImageShack.us
  12. Uploaded with ImageShack.us
  13. have unturned a heap of info on this mx6 site..... looks likely Uploaded with ImageShack.us
  14. nah didnt see that.. im keen to get some more power into the proceed.. cant decide what way to do it though.. ive got that ht18 turbs sitting here.. and the g6 runs lowish compression.. but a fe3 turbs will kill puppies with ease...
  15. come across this ozzy site build.. mega fukn cool.. so what im hoping from this thread is that a fe3 will slot into our 2.6l proceed... fe3 turbo skids on http://www.mx6.com/forums/fe-dohc/23466 ... s-too.html
  16. shizzl
    id my turbo
    manifold flange is about 85mm and 44mm...
  17. shizzl
    id my turbo
    well thats not gonna be easy to find a direct replacement then.. mostlikely a l20et turbo then...cos thats what the manifold would be too...
  18. shizzl
    id my turbo
    its got a 3 bolt flangey
  19. and more pics of skids..that thing will haul....
  20. shizzl
    id my turbo
    redoing them now. dump pipe flange spacing is about 50mm by 72mm ish... Uploaded with ImageShack.us
  21. shizzl
    id my turbo
    ah didnt think the pic worked.. the exh housing is bolted on...theyr f-n tight and dont feel like theyl release without heat/snappage.. will measure the bolt spacing once ive downed my lunch
  22. shizzl
    id my turbo
    dont think this pic will work, ill try it anyway.. the turbo has "nissan motor" on the comp housing. has the standard nissan 4 bolt manifold flange the dump pipe is a square 4 bolt pattern... is oil cooled only... need to know what its off so i can find another one before i end up blowing money on another motor if its the turbo thats gone... had a good look at it today and theres signs of oil seeping out of the wastegate pivot pin thing, and i can see a little bit of oil in the exh housing behind the turbine... so its now got me thinking the turbo seals could be gone??? no shaft play in it at all.. sound likely?
  23. is it insured? if it had wof prevopis just say a stone cracked it ae.. instant cheapo replaco
  24. anyone got a nissan turbo with a 4 bolt exhaust flange that they dont need? would be keen to borrow/buy to rule out if its the turbo or not... chur
