Everything posted by shizzl
Brakes are on!!!!! hoses and lines connected. have ordered some pads from palmside for “fast road car/high performance “. once they arrive I can fit them and bleed it all up. Check for leaks, apply electrical tape and cable ties, walk away. also altered the gear stick angle for a more rearward position. Easier to reach 1st now. post cert I will get new carpets fitted. next on the list to do: shifter hole cover and boot, adjust rear brake shoes, bolt check. Wait for engine to be built. Add in the extra resonator I have. Modify the centre console for the new shifter hole shitchea!!!
- 133 replies
- 15
Finished bolting in the fishnet recaros this morning while waiting on materials to arrive. also picked up some wedge lock washers for the brake discs. I don’t know why, but the hunter brake hoses fit the escort calipers, even though the internet says Theyr different threads. So what if Theyr cross threaded right
Have started on the front brake upgrade. first task was to fit a remote booster that would’ve come standard in these. id say the original had failed and was deleted on. so I salvaged one off a parts car I had. Got that fitted up. then sent my spare hubs and new capri vented discs off to Chris at suspension tech to get machined up. just need some wedge lock washers so I’m told. got a calliper spacer kit for the type16 escort calipers. these calipers are fugly, so have got a pair of rebuilt ones on the way. then lastly will need to get new hoses made up or an adaptor. Cert is booked in next month with Cletus, so should be plenty of time to get it back together.
Locked in with a guy out west quite some time ago on the original motor. Which turned out to be a grenade. has a very good reputation. although I would’ve definitely gone with Sprint RE, I’ve known Jason for ages, actually did my van conversion in his workshop 20 years ago.
Don’t have any of the internals yet. Still away getting built. im sure he’ll flick me a pic of the ports
Engine builder rang last night.. Any Rotor owner dreads the call from these guys.. "Hey mate, I pulled your engine down today..... And umm.................... " Gulp... waiting for the bad news that its a grenade... "It all looks good, ports are as rough as SH1, but the rest is mint".. This motor has also had its springs swapped out for rx8/fd springs, so they have more tension than a stock 12a stuff...will go well with the new unbreakable seals. So it turns out the porting is pretty average, so the plan he has for this is to turn it into a baby J port. Were going to swap the housings for the mint pair of RX2/3 housings I have on the shelf. Theyr already ported and notched. The ones that were in the motor will spin few triangles again, but have some peel.. do it once do it right ae.. I just have to drop my housings off, and flywheel so the whole rotating assembly can be balanced.. he wants me to run the lightened flywheel. Should go well.....poor fuel card
Pro Street in Pukekohe is who I used
better yet, chuck it in the oven to draw out any oils. But it should always be cleaned before welding regardless
Sandblast, clean clean clean, pre heat then fizz it up. I have successfully had stuff like that done before, so not too much of a drama _ think I used a shop opposite possum bourne motorsport, but back in 2002 for a manifold repair. Just find someone locally who doesnt mind welding it up
I reckon the October caffeine and cars day. Should be decent weather.
Remembered a contact I made a while ago. A quick cellular communication initiation later and I had them dropped off to Chris at suspension tech. choice as
Can brake discs legally be redrilled at all? Want to do the upgrade on the hunter while the engine is away.. Want to use Capri vented discs with the m16 calipers and a spacer kit. Capri PCD on the disc is off to fit the hunter hub.
Well I just can not believe it, but I have to, I’m looking right at it. I pulled the engine out to send off for a rebuild. And found it has a brand new xtreme clutch kit and machined flywheel in it. now I’m thinking of not even putting the lightened flywheel in it. Run the standard flywheel.
Should be able to book a kart session fairly easy for a group booking. Looks like the end of August could be a good time, out of winter, or end of sept if we arrange it around caffeine and gasoline.
Hey guys, Would any of you be interested in a session on the Hampton downs karts? possibly followed by a cruise to Mercer- Pukekawa- Glen Murray-Huntly? Open to dates and touring route too... lets make this an open convo..
Wof acquired. also noted today that it has a genuine Nardi steering wheel. But that doesn’t mean jack shit to me haha
Very local. forgot they did them. Will inquire cheers
I’m also keen to learn some tig . have a new machine but no idea on set up for these
So it turns out I only require a lower front ball joint. I’ll take that as a win not bad for 13 years off the road. but in shit news, the oil pressure takes a dump once it’s at temp, I’m hoping it’s just the oil in it that I’m using for break in. It drops to 17psi at idle, and 35psi at 3000 now. great
Yeah I saw that. Would love to grab the gearbox, but don’t have the time to get in there. Aswell as a few other bits like brakes, rear diff and control arms etc
Had a date with the hose this arvo. Have the little gem a wash. still has lime/clay/mud residue stuck to it from its last hiding. looking forward to getting this legal . I think I might chuck the 14” rally wheels on it for a looksy
- 54 replies
- 15
