Everything posted by Carsnz123
Carsnz123 replied to TimShadboltfan27's topic in South Island Region
Spray and pray mate, spray and pray.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Some say that he once killed a giraffe with just his feet and that he has a black belt in paper maché...all we know is he's called @igor- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
you know I never knew that button was there. back on topic slightly. @Seedy Al why convert from (I'm assuming) live axle and leaves to IRS. Crown wagons aren't fast enough to benefit from the improved cornering. Unless its Massive turbo 2JZ-GTE.
It's brake calliper overhaul time. I had the same problem. Freed the up by working the piston and slider a bit. Month or so down the track they seized up again. Pull the caliper to bits. Sand blast the housing and put new seals and dust boots in. Replace the pistons too if they are pitted. 2 front calipers on my crown cost about $110 with new pistons.
Carsnz123's 1984 Volkswagen Mk2 Golf 3 door
Carsnz123 replied to Carsnz123's topic in Projects and Build Ups
Had a bit of spare time on my hands so I decided it was time for a little work on the mighty Golf. First port of call was removing the carb and giving it a damn good clean because the car has been running like shit for the past couple months. I cut out a new gasket for the 2 halves of the carb but was lazy with everything else and used grey RTV. Next was breaking out the Bosch one way lowering kit. having a extra set of springs from the parts car comes in handy about now. After a bit of measuring I thought lopping a coil out of each spring was a good start. I could probably take another coil out of the rear springs but the fronts will no longer be captive if I make them any smaller. I should just stop being cheep and get a set of coilovers if I want to go lower. It hasn't made a huge amount of difference but the rear end has come down getting rid of the "Stink Bug" stance.- 20 replies
- Volkswagen
- Mk2
- (and 4 more)
This has probably been asked numerous times but I can't find any info anywhere. Is it legal to paint a white/black number plate black and silver to look like the pre 86 plates?
i thought they only dealt in mopeds.
I suggested this to @Ben_10. We should organise some OS motorcycle meets. So let's have a roll call of the 2 wheel lovers in the Christchurch area.
I'm going to have to give this one a miss. I've got another event on at the same time and I still haven't worked out how to be in 2 places at once.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Toyota Diff Info - Crown wheel sizes, Ratios, General info
Carsnz123 posted a topic in Tech Articles
I'm not sure where I got this info but I thought I'd share it. First of all some basic info about the F series Diff. Crown Wheel: 7.5" Braking: Drum and Disc variations RA65 Celica = Drum RT142 Corona IRS = Solid Disc MA61 Supra = Vented disc MX73 Cressida = Vented Disc YR22 Tarago = Drum MS112 Crown = Drum Corona Mk2 = Drum RT142 live axle borgwarner discs can be adopted (semi) easily onto some F and T diffs F series ratio info here on Toymods too. http://forums.toymods.org.au/index.php?t=msg&th=33561 To see which ratio your F diff is check out this: Read the Axle Code from the vehicle indentification plate. first digit: ring gear diameter A 138mm B 145mm C 6.25" D 6.62" E 7.1" F 7.5" G 8" H 9" J 9.25" K 9.5" L 10.5" M 12.5" N 13.5" P 14" Q 12" R 162mm S 6.38" T 6.7" U 6" V 10.6" W 15.5" X 142mm Y 158mm Z 202mm - no ring gear = FWD Second, third digits: gear ratio 01 3.30 02 3.36 03 3.545 04 3.556 05 3.70 06 3.889 07 3.90 08 4.111 09 4.222 10 4.375 11 4.444 12 4.625 13 4.79 14 4.875 15 5.125 16 5.286 17 5.60 18 5.714 19 5.833 20 6.167 21 6.667 22 6.78 23 6.833 24 7.64 25 4.556 26 5.571 27 3.364 28 4.30 29 4.10 30 3.727 31 3.909 32 6.591 or 4.807 33 7.503 or 5.583 34 6.781 or 4.786 35 7.636 or 5.60 36 4.778 37 3.583 38 3.417 39 3.154 40 5.375 41 3.308 42 6.500 43 3.550 44 3.214 45 3.533 46 2.928 47 3.944 48 3.356 49 3.729 50 3.400 51 3.736 52 3.722 53 3.250 54 3.941 55 3.333 56 2.821 57 4.058 58 3.238 59 3.234 60 3.519 61 2.724 62 2.892 63 2.655 64 4.312 65 3.837 66 3.071 67 3.526 68 3.095 69 4.176 70 5.857 71 2.962 72 3.949 73 4.285 Fourth digit: no of pinions, ltd slip-yes/no Code pinions ls 2 2 no 3 2 yes 4 4 no 5 4 yes Example: F372 = 7.5" 3.58 final ratio 2 pinion diff. Will not be stamped on the diff, you will have to check the build plate on the firewall of the car you pull it from. LSD Availability: Altezza LSD's form the likes of Kaaz etc will bolt in but a spacer ring needs to be made up for it to work. Can anyone shed more light on this? Steroidchickens? Tomei Altezza centre into an MS112 Crown = Works, no problem! Cusco Altezza centre into YR22 Tarago = Success! IRS centres will bolt straight into Live axle F diffs so you could use an MA61 LSD but apparently no good for proper driving with small clutch plates and small surface area they aren't very effective and usually well worn out. An aftermarket 1.5 or 2 way or locker is your best bet for grip or drift work. See Kaaz, Tomei, OS Giken, Cusco, (TRD no longer available) Side note for celica/cressida/irs corona - Altezza/RS2000 Cusco LSD was a nightmare for my diff guy into RT142/RA65 IRS centre probably due to the car not being LSD to begin with. Machining and lots of hunting for correct bearings needed. Have been told (but can't confirm) that the MA61 diff centre half shafts are needed as they were lsd from factory and are shorter to suit. Torsen and Truetracs LSD's are also available. Many hilux 4wd live axle ran 7.5" FRONT diffs too 80 and 90's, possibly 2000's. Lots of options from 4 wheel drive aftermarket companies. Cars: MX13 Cessida - 3.9 - 1410mm (Same width as T series/S series/KE70 BW) Tarago YR22 - 4.1 manual and 4.3 auto - 1435mm Uses a G series (Hilux) diff nose flange bolt pattern (60x60mm) All other F series is 55x55mm) Crowns: MS110 Solid Axle (coils) F362: 7.5", 4.77:1, 2 pinions, Open 5x114.3 1450mm Solid disc MS112 Solid Axle (coils) F292: 7.5", 4.10:1, 2 pinions, Open 5x114.3 1450mm Solid disc MS123 Semi trailing arm IRS F285: 7.5", 4.30:1, 4 pinions, Clutch LSD 5x114.3 N/A Ventilated disc, 1 piston calipers MS50 Solid Axle (leaf) F292: 7.5", 4.10:1, 2 pinions, Open 5x114.3 unknown Drum -
If anyone cares the F1 qualifying was good, couple can outs and a car destroyed.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I'd be a little worried if my milk jug was pressurized to 40 pound. Keen as for southland trip, make it saturday so I can get home at a reasonable hour. I might have the new engine in the crown by then.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
By contrast I had a trouble free trip back. Found someone to race from ranfurly to Palmerston. Now I need to sort going back to retrieve mine and @Nick Ritchie's new projects. Cheers for an epic day guys!- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Fucking Murphy's law. Car seems to be starving if fuel at 100. I hope it's the filter.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
charging/clearing mine as we speak. Should get some good footage of Dansey's Pass.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
In a world of old cars the man who has the tools is king.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I'll be singing off key.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Have we got a meet up point in Ranfurly? It seems a growing portion of us aren't traveling with the main group.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I've recently had my hearing rejuvenated so I'll either have to pack ear plugs or add a muffler for the journey. #LoudLYF- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Anyone coming from Dunedin way? there is a sump and crank pulley in Port Chalmers that wants to take up residence in my car.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Currently I'm stripping the bike down for a re-wire, new carbs, new exhaust, and a bit of a restyle. Being a California import the engine, fuel tank, and air box were hooked up to a carbon can because hydrocarbons and environment. Anyway its all been ripped off and put in the bin. I've stripped the carbs and exhaust in prep for replacement. A couple 32mm Mikuni carbs off an RF400 will replace the old 30mm Keihin carbs. They require a bit of modification but if it was easy everyone would do it. I'm still undecided about the exhaust but I'm leaning towards having the pipes on one side above the crankcase. The old pipes are rusty, dented and pretty much good for scrap. The battery box is being replaced with a 30 cal ammo can which will also house any fuses and relays. I picked up an old headlight which I later found out is off a D4 Caterpillar. It's built like a brick shithouse but looks awesome. the mounting bracket is a chunk of 1/4 inch steel that I'd like to use on the bike. The gas axe at work assisted in disassembling it in prep of a halogen unit to be fitted.
how far north do they need to get?- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
pack a tow rope in case my clutch packs up. was giving me grief a week ago.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Keen to come and raid Tony's place. It'll give me an excuse to go over Danseys pass seeing I missed it going to cromwell. I'll probably meet you in ranfurly.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Browsing through my photos of the bike I've come across some of the fails that happened When I first got the bike it had these awesome but sketchy as fuck brass bar clamps on it. It got pinged during compliance for excess movement between the triple clamp and the bars. Whoever made these homebrew jobbies did a halfass job of making the clamping surface round and the mounting bolts didn't sit properly in the triple clamp bushes. the crushed down dynabolt sleeves were an attempt at packing them out which was a major fail. A small exhaust leak which I thought was a loose nut was actually a broken stud that someone had decided the appropriate fix was gluing the nut on and making it look ok. While taking part in the ANZAC day charity ride the rear brake torque arm bolt sheered off under hard braking. Due to the way the brake operates as the backing plate rotated it pulled the brake on harder and harder until something gave way. It was a rather scary ride but all over in a second. Parts are not easy to find as the bike uses a lot of model specific bits but a modified xl500 front brake cam serves as a replacement.
