Hyperblade
Posts posted by Hyperblade
So I acquired a 3d Printer a wee while back and I've been learning how to design and create prints, and I finally had a cool job race car job for it.
I needed to lengthen the Watt's linkage slots so I can lower the linkage to get more grip out of the corners, and it's really important they are straight to keep the axle alignment.
So I 3d printed an insert that I could then outline the slot and center point for drilling the end of it out.
Worked a real treat and allowed me to do a much nicer job.
So the big downside of using @Roman ITB's are they are electronic, this means 2 TPS sensors, 2 pedal sensors new relay to supply power to the B plug of the ECU controlled by the ECU, and repinning and moving connections around.
I had thought at the time when wiring the car about DBW and thought "na I'll never go DBW"
Sigh.
So knowing it was a pretty big job I thought it might be worth remarking the top of my current manifold as an interim measure, so with Daves help I designed up a new top cover.
But once I got to that point I could estimate the amount of material need to print it and I was also very concerned with the strength of it hanging off the side of the engine with throttle body with the only attachment being bolts threaded into it, I'm sure it's all solvable with time and effort, but I knew I wanted to do ITB's so scrapped that plan. It did give me lots of experience designing a complex shape which was good.
So onto the wiring job.
My goal was to rewire ready for the ITB's but still run the Intake manifold for now.
So I previously had these bulkhead connectors to the engine. And they are nice, however having had them on the car for a while I wasn't happy with them.
They are big, but more importantly they are impossible to work on e.g. good luck getting the very center wire out. They do make it much easier for when testing the wiring as they provide a nice test point for connections, but otherwise they are really ideal for if you had another engine with the loom ready to go and drop in, but in reality I'm not a big race team doing that I'm just a club racer.
So my goal was to create something that was more modular that I could upgrade/add bits over time easily.
So I designed this in Fusion 360, printed mockups got it to how i wanted it, then had it laser cut and then @ajg193 machine the slots for the clips on the back side.
It has standard Deutsch DTM/DTP connectors which were a bitch to work out how to retain, and they still aren't quite right (but that's to do with the clips on the back and I think I can do something better).
But it will work for now.
Really happy with how it turned out.
It runs the following.
- 1: DTM12 (Front of engine) - Crank, Vtec, VTC, Oil Pressure, Oil Temp
- 2: DTM12 (Back of engine) - Exhaust Cam, Intake Cam, ECT, Starter, Alternator feed
- 3: DTM12 (Intake) - IAT, MAP, TPS Main, Fuel Pressure, ISCV.
- 4: DTM12 (Front of car) Transponder (can deal with lights etc in the future if required)
- 5 DTM8 (Gearbox) Speed sensor
- 6: DTM8 - Ignition Coils
- 7: DTM8 - Inboard Injectors
- 8: DTM8 - Outboard Injectors (not used at present)
- 9: DTP2 - ECU Ground to engine head
- 10: DTP2 - EWP
- 11: DTP2 - Fan
- 12: DTM4 - Can Lambda
Connector 3 has everything wired up for the ITB's as well so just need to change engine side to suit, also potentially supports variable velocity stacks (BMW S1000R comes with them as standard).
The idea is If I suddenly need a new sensor, I can easily splice it in to the engine side, and just run a single wire back to ECU.
I've also wired extra sensors into the steering columns for the pedal sensors and clutch in the future so they will be straight forward to add later.
Car is finally back together, It's running but I need to get it out on track again just to make sure everything is still good.
On 19/04/2023 at 19:42, ajg193 said:Just did a nice little machining job for @Hyperblade, adding a few features to a laser cut bulkhead plate for deutsch connectors
The little NC mill only had 1mm of extra Y axis travel to spare with cutting the features.
Hopefully it all fits together well when on the car.
Big thanks to @ajg193 for doing the machining for the connector clips on the plate, was very impressive seeing his setup and how quickly he managed to do it all.
Very happy with how it turned out.
Stick with J160, becoming more popular which is good for parts and some amount of crossover with other variations of it is good. It's a good box. And if worried about torque just do the fix the Silvia guys do something internal which I can't remember specifics of.
On 24/02/2023 at 17:57, kpr said:
If you wanted to try something in the meantime, you could take the spacers out of the plenum. Have some thick head flanges cut to space the manifold out at the head end, lengthening the intake runner. Maybe a couple at 25mm so can stack them see what works best. I'm guessing around 50mm would do the trick. Maybe could get them cut from something for some thermal insulation at the same time.
That's actually a really simple idea to increase the length.
But it would affect my bracing underneath and way more then i want to do to it at the moment.
My plan is to 3d print the top half and straighten up the throttle body + intake for the experience in doing that without having to take the whole manifold off and I want to see if it actually does make any difference.
Then I can get stuck into the ITB's which i know will be much better, but are going to take a lot of time playing around with redoing wiring.
16 hours ago, kpr said:
runner diameter being a bit oversized isn't actually much of an issue. unless its way oversized.
length is probably an issue though.you can see its doing something weird on the dyno sheet, which is most likely the intake runner length. looks like its wanting to work at 8500. which makes the dip at 7500. if the runners were a bit longer (most likely factory length) so it was tuned for 7800-8000rpm would make more power. its something that can be shuffled with the cam timing to a point also. your tuner probably should have already tried that though.
Ideally get those itb's on and make the intake runners way longer. nothing off the shelf will get you there either due to fitment issues, or too hard to make.
I'm pretty sure it's quite a bit larger then than stock, but hard to remember now as haven't had it off in a while.
Dave mentioned the same thing about the uptick at 8500rpm,
He estimated it's down 10 to 20hp at the top end, compared to what he's tuned before with stock manifolds.
ITB's require a bit of a rewire so due to being electronic and pedal changes so I'll plug away at it all and get it to a stage when I can then bolt them on at the right time and see how they go. But my quick measurements show I need to get them as close to the heads as possible.
Thanks for the feedback by the way, really appreciate it!
On 21/02/2023 at 21:56, kpr said:
Oh and the intake plenum size. probably aren't loosing any power there, unless your loosing some effect from the intake tube. bigger plenum damping out the pressure waves, unsure how much of a thing that is. There will be a little bit in getting the intake tube the right length and size. but wouldn't expect big numbers from it.
Agree on plenum size, everything I have read is that you can't really go too big.
But I do agree it's Intake system related.
Which is not unsurprising to me, I knew when I put that manifold on that it wasn't great, but it was the easiest one to do at the time and I knew I could fix it long term by going to ITB's (always the intention).
To be clear it's issues are
- Build quality was shocking, chunks out of the trumpets (which I had to fix)
- Everything was rough as guts
- The runners are HUGE
- Their own thermal gasket they provided actually blocked off the top of the port (yes seriously), so i used the standard honda one.
- It doesn't actually match the head ports perfectly (slightly larger if anything)
- The design of it is clearly more aimed at turbo cars.
The throttle body is 74mm,
- I don't think that's the issue.
- Although it's worth pointing out just to show how bad Skunk 2 is, that the gasket that comes with it doesn't fit correctly for the IACV port to their own manifold.
The intake filter and pipe
- The filter doesn't really have an internal velocity stack, and I did my best to improve it, but it wasn't a good job.
- The pipe has 2 bends opposite each other, then a 3rd bend after the throttle body for the air to get into the manifold velocity stacks.
- Most Hondas run a significantly longer intake pipe, mine is very short. Length helps the air to build up velocity before encountering obstructions like throttle body, corners etc.
The shitty pod filter velocity stack, bends and shortness of the pipe means the air is moving very slowly and never gets a chance to speed up so by the time it gets to the manifold and with that the runners being larger than they should be, the air never gets the velocity that the high RPM needs to fill the cylinders.
That's my current thinking anyway.
30 minutes ago, kpr said:
Yeah you can see the actual timing (yellow) misses the target (pink) by a little when you get back on the gas. but by the time your at full throttle its matching the target.
top one is your current "vvt" map. since race car and assuming you dont care about fuel economy, I'd run something more like the bottom. or a less aggressive ramp at least. so your always on target when get back on the gas. Not really much of an issue in your case but thought would explain it better.
Ive compared mine, which essentially mimics at 1j/2j setup vs @Roman daves 1nz setup and seems to react pretty similar. yours seems a little faster. either a honda thing or the control is a little better in g4xThat's brilliant, I understand what your getting at with the changes now. Even if it was 15 to 25 (assuming degrees) then it would take a big chunk of not being on target out of that curve.
58 minutes ago, kpr said:
I was going to comment about probably changing the cam timing map. so it doesn't go to zero cam advance when throttle is closed. due to the mechanical time it takes the cam to re advance when get back on the throttle.
but looked in the log and looks like it keeps real well. nice one mr honda. so isn't really that much of an issue. possibly a little more crisp on the throttle if changed it.As for what cam timing it needs. will need to be done per engine. unless 100% stock to 100% stock. as changes to the intake and exhaust will change what cam timing it likes.
The shape of the cam timing map looks right. starts to retard at high rpm etcThis as part of the log @Hyperblade posted. cam stuff at the bottom
The vvti control works real well even on my old g4 link.
Thanks for posting that screenshot, helps me understand what you are all talking about!
15 minutes ago, cbDrift said:
Had to sign up just so i could reply after i got your youtube reply and saw you uploaded your map.
Its a very similar tune to my jdm civic k20a timing wise - very close all the way through under load - a few deg more at the top end than me but im paranoid about not wanting any knock. generally within 2ish deg of mine under full load with mine running a bit less than you 99% of the time
But your cam angle map is totally different to mine - and on these k20a engines - it makes all the world of difference getting that right in all conditions with an n/a engine.
i gained a "buttload" (technical term) of top end when i got the target cam angle to actually match up with actual angle using this target cam angle map on my haltech
this is from my jdm type r k20a in a 2005 civic ep3 - the engine is untouched apart from intake and injectors and a decat
the difference between accurate cam tracking and having it waffle around vaguely in the range of the target is amazing - I got a tonne of drivability and my top end power when i had good control of the cam angle. 2deg can make a difference to how the car feels when driving - and cold oil heavily affects the cam angle tuning vs up to temp oil.
having said that - it looks like the link handled pid stuff totally differently to the haltech so i have no idea how accurate the link will track the target cam angle.
Either way - if this helps to improve your drivability - mint! if it doesnt - just as mint
Have fun - your starlet is an awesome build and thank you for posting your map to take a look at
I'd be really interested to see how accurate the link is able to track the target cam angle with the actual cam angle (even a screenshot of the two traces overlaid)
Welcome to the forum!
Unfortunately your talking way over my head, i'm just not up to speed technically on all of that stuff as much as I want to be, I just haven't had the time to really sit down and understand it all and be able to tweak it.
I should mention Dave said he usually has the timing backed off a couple of degrees.
The other thing to mention is that on the Dyno Jon struggled to get temp into it including the oil (5w40) which sat at about 80 degrees if i remember correctly (on track oil is hitting 120+)
Due to:
- The sensor reading 9-11 degrees lower than what the engine temp actually was
- The electric water pump control just not working well at all (hence I put in new thermostat + bypass hose)
I can do you one better though, here's the full log from session 4, i basically have everything logged as it has heaps of memory.
https://drive.google.com/file/d/1x3suRFYwUip95PEAx97Et83RMrr0hbNC/view?usp=sharing
I haven't updated the main thread, but current plan is to redo intake piping to be straight which means new 3d printed top half of the manifold so I can straighten throttle body, this should at least eliminate that from being a possible issue as I think the triple bend for the air to get into the runner is actually the main issue vs the plenum volume. I want to do that first as it's just keeps niggling at me(and I would like to know if I'm on the money or not around that stuff) and and it gives me more time to plan the quad throttles to get best results.
Take a breath, step back, study it, think about it objectively what other issues are going to crop up if it's not positioned where you were originally planning e.g. steering, cooling etc.
Think back to your original goals with the swap, will it still meet those?
Now's the easy time to pull out if you think it won't work. If to fit it you need to cut up the car, that's a pretty major step and easily spirals into a lot of other things.
Whichever way you go I'm all in and following!
So things have moved along rapidly in diagnosing the power loss. Lol
I had Dave at Dtech motorsport look over the tune and logs, as he has tuned more then a few honda K engines.
He was fully happy with the tune and thinks it looks all good.
Best guess at this stage is the intake manifold (Skunk 2 Ultra Street with 2x .5L plenum spacers) is to big for the stock engine.
He advised removing the spacers initially, but unfortunately they are also used to get the throttle body into a position where I can get the intake pipe around the oil cooler duct.
So onto moving forward with my ultimate long term (now short term) plan which is ITB's.
Aside from the power gains (hopefully) they will mean I can do a really nice cold air intake setup. The car was built with lots of space in that area to play around as I knew I would eventually end up at this point.
The recommendation from him is Jenvey Tapered ITB's as they perform the best.
https://store.jenvey.co.uk/honda-k20-ep3-sf51-taper-kit-ckha07-kit
I don't have the money for that, so over the coming months (in no rush for this) I'm going to backyard build a setup.
I have aquired Roman's BMW S1000RR 48mm ITB's and will 3D print manifold, trumpets, airbox, intake to suit.
It's electronic and I currently run throttle cable, but I think I have enough outputs/inputs on ECU and can just buy an new linkage kit for my existing pedal (https://tiltonracing.com/product/600-series-throttle-pedal/), that it probably makes sense to keep it electronic and not need to put Idle up valve in.
Just going to be a lot more wiring i was trying to avoid. however the benefits probably outweigh the pain.
- 16
This is going to be so fucking awesome, and for what your doing which is not an all out racecar, makes a lot of sense.
And even if it doesn't work out, I'm along for the ride!
You are mid mounting it right?
7 hours ago, Roman said:
It's been bloody awesome fun alright.
But also it's a bit tapped out now.
You cant get any 1NZ cams bigger than 264 deg, and there were only "admin" sorta jobs left to do like sort out an air filter or tidy it up.
Things which made the car nicer but fundamentally didnt alter the recipe any further.
I'm actually really happy to end a project on a high note.
It seems a lot of projects end up being sad to look back on if they ended when a car was crashed, or motor blew up, or sold to have kids or whatever.
This has just been grin factor 10 nearly all the way through.
Also I've managed to infect some other people with the concept of vitz pesting, and the parts from this car are going to be used in some cool setups.
Also worth noting that back when this car was standard I came incredibly close to just giving it away as I no longer used it.
What an absolute adventure it's been on, at the tail end of it's life instead.
How good!
I think what you have done is bloody amazing!
It's been so cool to watch as you have progressed with the development and tried things.
I agree it's reached it's natural conclusion without a lot more major work.
I don't believe you can ever work on 2 project cars at the same time and give them both serious attention, so it's going to be awesome to see you get back into the carina.
10 hours ago, Roman said:
Ahh man there's always something eh!
Drive from last shakedown looked good, stoked to see it's making steady improvements.
Would love to check out your car one day, love it.Anytime your down here in Chch (or anyone else who wants to see it) just give a yell.
So I went for a shakedown with new clutch, which overall went pretty well.
I got a comment on one of my videos which I thought I would answer here as it's long and complicated and may interest others.
Quote@cbdrift5864
Its the first time ive seen it driven in anger - this thing has some serious front end bite and sounds like its VERY enthusiastic Good job! From the looks of your dashboard your running a link ecu? Have you had this dyno tuned or just doing it yourself from the basemap? I have a jdm k20a on a haltech and im always curious to find/swap/get more info on tuning the engine on an aftermarket ecu - especially the cam control side of things which i spend a lot of time on.Map
First up, I don't mind sharing my MAP so others can learn, It's for a LinkEcu G4X XtremeX and you can download it here
https://drive.google.com/file/d/1-M1MXHnkJxH2A30xRdFbANd65I309fiA/view?usp=sharing
Tuning was done on a dyno by a specialist, so can't add any extra info there, other than maps were done for non vtec/vtec then it was worked out where the crossover made the most sense (4500 rpm).
Driven in Anger
The comment about it being driven in anger is a good observation. With the BEAMS in the car, I always felt the car was hard to turn in, and if I tried to be aggressive it would just understeer. That plus suspension valving issues, rear brake pads accidently being to aggressive, I never felt comfortable pushing it into a corner and so was reasonable gentle on the inputs to give lots of margin for error.
I have finally reached a point where we have made major suspension changes, lengthed wheel base, anti dive, shocks valved correctly, rear pads correct, and 30kg taken directly off the front end, where I'm finally feeling comfortable in the car.
However I'm still used to driving the car fairly gentle, which you would see in 2nd shakedown video from the same day on my channel.
I got Brent who did the fabrication and who has driven a wide range of very fast race/rally cars into it for the 3rd shakedown video to see what he thought, he came away absolutely loving it the handling with no changes required to valving, or sways bars or anything major which we are both stoked about.
But he did have the following comments:
Could do with Power steering (will explain why below)
- Suggested Suzuki Ignis mid 2000's electric steering column as you can get the aftermarket modules to control them and they are small.
Power is not what it should be in the top end (suspects down 20hp)
- suggests shortening secondaries.
- Suspects that they are to long and it's affecting scavenging at high rpm.
- Whole logs/fueling needs to be looked at to see what's happening first before going down that route (but i need to learn how to read them and adjust them first)
- Can easily see it on the dyno sheet, I've just lived with it for now as other priorities, but obviously something not quite right.
The watts linkage should be lowered to improve the angles
- this will increase grip on the rear end on exit of corners
- Shakedown video 5 has it lowered by 15mm, which may have felt slightly better.
- But have reach limit of adjustability, so need to lengthen the slots.
So the power steering is the interesting bit, the reasoning is that when turning for a corner the power steering moves quicker for less input, with the tyres I run if you turn in very quickly initially (you can back off afterwards) they hook and get a lot more grip then you would normally get.
I have never had the car in the state before where I felt like throwing it in would work or that I could safely control it.
So Session 4/5 I changed my driving style to try initially turning the wheel into a corner really fast.
Holy hell, it was an amazing feeling that i have never experienced before, it blew my mind, it was hard to compute how much front end grip it suddenly had and the rear just felt like it slipped slightly then hooked up too, it's hard to convey how big a difference it felt but felt like I had at least double the grip on the front end.
As you can see in the videos (4/5), I was missing apexes all over the place as trying to time it was really hard. And that's why power steering is recommended as it means you just turn into the corner and the natural movement will cause it to hook at the right time. Where as doing it manually is slightly slower and timing it is harder.
Clutch:
So the aftermath of a clutch spring letting go.
Bit's also made a small hole through the bellhousing.
That was a new Exedy HD S2000 clutch, there were warnings on the internet about using them, I thought it would be ok as light weight car, and previous Exedy with the BEAMS handled a ton of abuse.
Wow was I wrong, DO NOT use this clutch, after taking it out we could see wear on the posts and clutch springs where they were binding, it's just not designed correctly for the loads.
Decided to try an Action Clutch (Considered Xtreme Clutch, but had a friend who's plate exploded on his car and made a bigger mess...) this time, at least the springs shouldn't be able to come out...
Adapter Plate/Flywheel
So while we were swapping that we found the input shaft bush was showing a lot of wear and was no longer concentric.
I run a standard adapter plate (with flywheel to suit), they say on their product page "Precision machined from 6061 this adapter features perfect dowel pinned alignment and all hardware needed."
Of course when I went to bolt it on one of the dowel pins wouldn't go in, I was in a rush for various reason and it become a one is in, that should be enough...
Turns out yeah no, you really do need 2, we think movement between gearbox and engine has caused it to wear, which damaged flywheel where the bushing sat.
The adapter plates also don't have a huge number of bolts holding everything together, especially at the bottom where their is the highest load.
Adapter Plate
Originally the gearbox bolted up to the adapter flange with 3 bolts (yeah I wasn't to impressed by that at the time, but a lot have been sold, so figured it would be ok), it's now been all modified to have 7, and more coming in from the engine side. We also managed to get one bolt at the bottom to go all the way through from the gearbox to the engine sump bracing (highest load). It won't be moving anywhere now...
We machined the flywheel to fix it up and put a proper bearing in it (2032 6 series - I think from b series), so that should also take some mis alignment better.
Engine mounting points, top of adapter plate sits above the top ones.
Gearbox Shifter Linkage
For any one interested, here's a good photo of shortening a gear lever linkage on an Honda S2000 AP1 gearbox to move it forward which i took while it was out.
- 9
18 hours ago, xsspeed said:
lush, did you snap pics of all the cars too? would be cool to associate engine bay to particular gen/class of touring car
Na was way to hot for my brain to think of smart things like that!
On 27/12/2022 at 00:16, Roman said:
So I happened to snap a lot of pictures of the intakes on the old touring cars at Scope Classic on the weekend.
If you like seeing endless dollars spent on fancy carbon you can view them here...
5 hours ago, yetchh said:
Ok bro cheers, do I name drop?
Just say Ben sent you.
Just be clear with your requirements about when you need it done, and your expectations on quality (long term don't want it to happen again) vs speed (e.g. just fix it as cheap as possible now).
22 hours ago, yetchh said:
Is he an exhaust company?
Not a dedicated company, but he has many many years building exhausts and a lot of experience in the area, he's done full systems for our race cars, and can rebuild mufflers from scratch. He works for himself so is reasonably priced. He's done a wide range of cars from my little starlet to ferraris.
John at Canary Automotive will be able to sort you out, he's in woolston.
On 23/12/2022 at 16:57, Roman said:
I remember reading something from a BTCC guy who said they looked into ram air type setups and said there was no point.
As in ideal conditions its only a millibar or two of extra pressure, at maximum speed. Then you lose that as soon as you are following someone else.
I don't believe they didn't use it, you only have to look at the insanely complex carbon intakes across a wide range of touring cars that they created for many $$$ and look at how much $$$ they spent on the cars, your telling me they wouldn't have done it for say 5hp more? Agree running behind someone you lose the effect, but you don't want more hp when your at the front to stay in front? Doesn't compute in my brain. but i've been wrong before...
On 23/12/2022 at 17:17, Spencer said:Yeah I think its just for clean/cold air, but the later 90's cars all seem to intake down from the bumper, making me wonder if the grill is just a bad spot for some reason. But then the later ones all have magic duct work up front also that they tie into.
Just a excuse to look at BTCC engine bays really /ling
You will get high pressure zone just above the splitter/spoiler where the air is hitting the air dam but with a trade off of potentially higher air temps (as closer to the track). If you think about the huge amount of work to duct the intake to that area, it must have been worth all the effort/$$$ in performance to get to that high pressure.
This is a good article on it all from Willem Toet (F1)
https://www.linkedin.com/pulse/air-ducts-down-earth-guide-motorsport-applications-willem-toet
12 hours ago, Roman said:
Got this sorted, and it's awesome. Thanks again Stu!
The extra room gained is incredible.
So the next thing to decide is how a filter or airbox or whatever is actually going to work.
On the engine bay side I've been tossing up some ideas but not 100% sure yet.
However ahead of the radiator and crossmember, I think it's going to be best to completely divide the engine air and radiator air intakes.
Looking at the front grill area, there's a decent cross sectional area available through the holes in standard grill. More than enough to feed the motor.
So sketching it up / cardboarding it up, hopefulling something like this works
Printed out a test piece for one side and fitment is nearly there. Should be good!For the intake if you can try and get it to expand gently over the entire length up to the stacks.
e.g.
And ease the radius from the bumper into it, even if you have to reduce the entry of intake down.
It should increase pressure over the the throttle plates at speed, giving you a boost in power if you do it right.
9 hours ago, Roman said:
(apart from avoiding blowing up the motor)So that's a good point... What's your sump/pickup like, as on those slicks you will run the very real risk of having all the oil disappear.
I think your going to be pleasantly surprised at how much performance difference there is with them compared to even good semi slicks.
Hyperblade's KP61R - Toyota Starlet with Honda K20a
in Projects and Build Ups
ITB's Next Step
So the wiring is now done just needing testing.
The ITB's are a long term thing I need to slowly work through.
So while rewiring I pulled the manifold off so I could measure the ports and create a flange in CAD so I could slowly work on the manifold adapter.
So much crap on the internet
I did a lot of research on the internet around K20 ITB's and the port sizing, and can confidently say some manufacturers have both the port angle and port size wrong in their drawings (and that's their job to get right) Jenvey are definitely the ones who have it the dimensions right and that's backed up by feedback from someone who has tested a few and found them the best.
The jenvey ones are 48mm and everyone says that bigger then that is better (e.g. 52-54mm), but that ultimately depends entirely on where the throttle blade is positioned with the system.
e.g on the following diagram, A, B and C are all different plate sizes but really have no impact on the amount of air being ingested, however position does have an impact on response and driveability (closer to head being better).
So the Honda K20a CL7 port size is equivalent to 46mm throttle plate, which means if you put the throttle plate at B (48mm) you have accounted for the restriction it causes.
Jenvey looks to keep a straight section (no increase/decrease in size) of 46mm diameter for a length of 85mm from port to throttle body flange. I suspect that is because you don't want to take energy away from the air by trying to increase it's velocity just before it goes into the head, but could also be packaging etc. I'm just speculating here.
Additionally Jenvey have the port angle at 17.5 degrees, which when I measure is perfect for dead center (vertically) of the port as it narrows. Where as they others have 14/15 degrees which means the top side has a sharper angle then the bottom (which is flat).
So I can see why Jenvey perform, their experience shows in actually getting the basics right.
So they are the ones to copy as I can't afford their full kit
BMW S1000RR ITB's
Now the S1000RR ITB's are 53mm entry, 48mm plate and 42.84mm exit with a 3.5 degree taper on walls.
The exit is not good if port size is 46mm., however I'm confident I can bore them out with a little effort on the lathe to 46mm which would be perfect, I only need to bore 10mm into them, so don't have to worry about the throttle plate.
So I pulled them apart to see how hard it was and if it was possible to put each half on the lathe as is without having to completely dismantle the plates
Then they wouldn't go back together, a small bit of panicking later I was thinking I would have to dismantle them which would then mean they needed to be resynced.
But in the end I 3d printed a tool that now allows me to put them back together as they were from factory, so that's a massive win.
Bore spacing was the other worry the ITB's are roughly 83-82-83mm and the CL7 is 94mm, but it turns out that it's close enough that it will be fine.
So I can proceed with the ITB's and the design of the manifold to suit them.
My intention is to mount the standard Honda injectors into the manifold in the same place as the Skunk2 manifold (close to head) so that the transition of the tune to the ITB's is easier, then setup outboard injectors at a later stage (and just block up the BMW ports).
I'm not rushing this so it will be done when it's done.
Just in comparison here is what others have done to fit bike ITB's to a Honda K series.
https://www.jimbositb.com/product-page/throttle-body-adapter-plate-k24
https://danstengineering.co.uk/Honda-Civic-Type-R-K20A-Bike-Throttle-Bodies-Kit-GSXR1300-46mm-STARTER-PACK
Feel free to tell me I'm an idiot here;
