RotaNate
New Members-
Content Count
20 -
Only update I have of recent . Been stuck at work and havnt had time (like I said I would make) to do anything, so I had a tiny bit of time last night so cracked into a few small tidy up jobs To stop rust I gave the plate I welded in a lick of paint! Also while I was there I mounted my ignition barrel in the hole where the oil level gauge would normally sit. Other than that, all I have really done is bolt the motor back up to the frame. I think next on the list will be making a tidy loom to stash under that plate, wire it all in and ride
2018 and back at it! And this year I’m going to make a bit more time for this. It won’t be for a few months as I over spent over New Years and need to catch up I did manage to finally finish my under seat electronics cover though! I had to tidy up the edges but got it fitting snug Feels good to be back with my welder! Welds aren’t that great looking (I really need to get some gas) but it does the trick. Also over the break my genuine filter elbow finally turned up! Looks a shit load better than that shitty thing I had on before!
UPDATE FINALLY I have been pretty busy this week so havnt really touched the FA50 in a while...I do finally have those picks of her all cleaned up though! All I’m waiting for now is my sheet metal to turn up so I can get onto welding up my under seat electronics cover On the positive side though a few weeks back I ordered a NOS intake elbow! I was sick of the random one I had on there that I was just making work. So when that arrives I will get a new filter to suit and go from there. What else.... I finished welding up my exhaust too, so while I’m waitin
Yeah mate that’s the one! That farm hack story sounds familiar too so must be your old one! Yeah it was just spark. Had to do a bit of re wiring and a new plug and she ran. Did a compression test on it not so long ago too and it was at about 100PSI
Today I got around to cleaning up the frame First step was get some degreaser on the years of shit that is caked on there! The degreaser didn’t quite get everything off so I went to my back up of some foam wash my brother in law had. Sprayed it on and left it for a few minites and with a quick waterblast it came up as good as it could could do (I will get a pic tomorrow as it got too dark to get a good one). Next up clean up the motor
Yeah I noticed that once I sat on it! Lol I was planning on adding a bracket on after I got it running. I had cut the factory one off the stock exhaust and was going to weld that on but glad to see you guys are watching carefully in case I miss something haha
So to start off I didn’t make the Raglan ride my babysitter fell through and I had no back up! Buuuut time to focus on the next big ride....Tauranga So tried starting her up with that pipe on and no go. Kicked and kicked and kicked but it would splutter and spit flames and die. After a bit of thinking I loosened off the exhaust and boom started up first kick! Conclusion....The pipe was too restrictive. In the rush of trying to get the FA ready for the Raglan ride I just cut the pipe off and welded the factory exhaust back on where ever it sat at the time of welding it (which to be honest
So, was just chilling at work and this showed up! I totally forgot I had ordered it! It is just a cheapie from trademe (I think it was about $30 including shipping). Of coarse I had to fit it as soon as I got home, so I chucked it in the vice and began chopping The sparks went flying!! Once I got it cut where I wanted I mocked it up and luckily the bracket for the silencer lined up nicely with a bracket on the rear frame. I mounted it up and marked where I would cut the old muffler off and the factory exhaust got the chop as well With a bi
Wheres the updates at??!! Lol @rivalrx
It could just be that then? It’s my first 6v Moped so was thinking there wasn’t enough juice to power them up properly Yeah man if you can bring that filter as a back up that would be sweet! I’m going to try source one tomorrow so hopefully they have one in stock
Plans are, once she survives the Raglan ride, will be to strip her down again and get her looking spify! This will include paint job and just a cosmetic tidy up of the motor/gearbox. While that’s all going down I will try get to the bottom of a lighting circuit issue I have but for now I will be using this....
Forgot to add the aftermath of my victory burnout that I did when I finally got her running properly! When I had got it running at idle it wouldn’t rev up very well/wouldn’t get the power to drive itself forward. After many laps of taking the carb off and cleaning it out, taking the exhaust off and trying to burn it out and whipping the plug out and cleaning it I figured it wasn’t any of those. Then a mate was over and we took the rectifier out and she purred up and took me round the block! (Hence the picture above I got a bit excited haha) Next up is to make the cover for all
