Everything posted by Sunbeam
The red one is better? Show us how bad the blue one really is!
It’s a good thing I have so much time on my hands. I decided to remove and strip the Weber 32/36DGV from the MG. For a carb that hasn’t had fuel through it for 20 years, it didn’t look too bad. Just some reddish dust through it. I just methodically pulled it apart and took all the jets, aux venturis, emulsion tubes, basically everything that unscrews or can be extracted and then got busy with carb cleaner and compressed air. Researching the way it is jetted, it’s basically exactly the same as a Capri 1600gt and a host of other 100ish hp stuff, so it should work pretty well. It has the same base mount bolt spacing as the Solex carb. It’s a pretty wide thing compared to the stock carb though, so I had to remove the throttle link rod and unbolt the mount on the cam box to get it to fit. Shame it doesn’t fit well, because it’s a really nice carb. Simple, well made, and still available new. Despite having 20+ year old gaskets etc, the car fired right up and I could immediately tell things were 1000% better. If I had the gear to improvise a throttle linkage for it (would also need a longer choke cable) I would love to run this carb for a while, as I think it could work quite well with this engine. Anyway, this confirms the (original to the car) Solex carb body has something wrong with it. More investigation reveals another leak here: The casting is compromised. Then I decided to drag the other carb body out again and repeat the stripping process and put all the best bits in the other one. I’m a bit messy when I’m in the middle of a job. Refitted to the car, and straight away I could tell the rich idle was gone. I made some idle adjustments, and I thought it could use a bit more advance. I just set the timing with a vacuum gauge because the engine doesn’t have the timing cover on (has the marks on it). Got it to sit at 18” which is very healthy. Went for a thrash down the road and did a plug chop. Excuse focus or lack of... looks good to me. I did feel like the secondary wasn’t opening. If you try and open the secondary throat with the lever that the diaphragm works on, I found it had a significant stiction, so I suspect the vacuum diaphragm is not strong enough to overcome it. There is an adjustment screw in a prick of a place under the float bowl that works like an idle speed adjuster on the secondary butterfly, so I nipped that up until it just stops the butterfly from jamming when it shuts. Another quick thrash reveals it has done the trick. Personally, I still don’t like vacuum secondaries. So there we are. Days of pottering around, I think the stock Solex is running as well as it’s ever going to. It will have to do, because Covid-19 has taken a dump on my earnings. Twin Dellortos, I haven’t forgotten about you, promise.
Good news, bad news. Good news is it starts and runs, and the accelerator pump works, and it definitely feels like the secondary is opening. Bad news, it’s very rich at idle and low rpm. Even with the mixture screw tight on its seat, nothing changes and I’m roosting black smoke and petrol fumes. I’m eyeing up the weber 32/36 DGV on the MG. It has the correct orientation. The fuel inlet is on the wrong side but the hose should reach. It’s set up for a cable linkage but at least the rotation is correct for the Fiat. Might strip it today and give it a cleanout (not run for 20 years) and give it a whirl.
I really want to get to the bottom of why the accelerator pump won’t work. I tipped some fuel into the float chamber and operated the pump lever. Lightbulb moment! It’s pushing fuel back out through the inlet port, which means it must need some sort of check valve, right? Maybe it’s not working... Time to consult the manual again. It’s item 37 in the pic below Which belongs in the hole on the side of the float chamber as below There’s a grubscrew that goes in there too to stop the ball falling out. Thing is, there’s no ball in there. There’s not one in the spare carb either! Lucky my neighbour is an engineer/hoarder and he said he would drop a container of ball bearings in my mailbox, which he did. I have selected a 3.17mm ball, dropped it in the hole, applied grubscrew and tested. We have squirts!
- 126 replies
I have not been able to get this thing dialled in properly. Ages ago I swapped out the carb for one I got from @azzurro. It seemed to go well, with heaps more top end, but I never could get it to idle. On the weekend I swapped my old carb back in to have another play. This one had a kit thrown at it be me more ages ago. It’s still rubbish. For some reason the accelerator pump does not want to work, despite new diaphragm and seals. Also, it now keeps spitting back through the carb off idle. Plus, it only shows 12 inches of vacuum at idle, so I have an air leak somewhere I think. I have nothing better to do so I stripped them both and am trying to build one out of the best bits of both. I am using my original carb because it’s kitted, has all the correct factory jet sizes (and the other one has been bastardised in a couple of places so I can’t swap a couple of items), and it’s presumably only got 72,000 miles of wear. The first thing I was suspicious about was the diaphragm for the vacuum secondary, since it never had much top end with this carb. Eureka moment number 1. Ripped as. Swapped it for the diaphragm out of the other which was sound but covered in rusty coloured dust. Gave it a quick clean and fitted. Next, all the jets etc got taken out again and every orifice got a good blast of compressed air, which showed up another problem. When I blew through the idle mixture screw orifice, I could see bubbling leakage through the base of the carb body. Closer inspection reveals some micro cracking stemming from some corrosion. JB weld to the rescue (the dark grey in this pic) Now I have to wait 24 hrs before I can use it. Pretty keen to see if any difference has been made.
This thing is not easy to roll around on the tractor grips, so I fitted some low rolling resistance tyres I had on a spare set of rims. I also wanted to drain the diffs. Rear diff will have to be done off the car, because some animal managed to shear off the square head on the drain plug. Front diff was easy, but this came out: Probably not supposed to be there.
- 27 replies
- 7
- land rover
- 109
(and 1 more)
Tagged with:
They still do weldsmart. Seems like a sort of 2 tier thing. The weldsmart has 12 month warranty, the weldpro 24 months. Good to hear of your experience.
Anyone had anything to do with Weldpro? Been eyeing up a Weldtech as some of you are running, then I stumbled on this one from an outfit in Nelson. Seems good value https://www.onlinetools.co.nz/products/weldpro-digital-mig-205-migarctig-gasgasless-spool-gun-ready or a combo deal mig and plasma cutter for under $1k https://www.onlinetools.co.nz/collections/welders-1/products/weldsmart-combo-mig-200-inverterplasma-40-two-machines-freight-free
Still happy with your purchase?
If you end up with a complete gearbox/t. Case and don’t want the main gearbox let me know. My transfer box is fine, but the gearbox sounded like a coffee grinder with rocks in it.
If it were me, I’d risk a second hand transfer box, even if you need to throw seals and bearings at it. They usually last better than the main gearbox, particularly if you get one that was behind an original Land Rover engine.
Not much actual work done today, but a massive cleanup of the workshop. I spent a few hours going through my shelving unit, having a purge and a re-pack and managed to get enough space to store bits of Land Rover in some semblance of order. Also drained the fluids from the engine and tucked it in the corner. Then I did the same with the gearbox/transfer case. This is how much oil came out of the gearbox: This goes some way towards explaining the horrendous noises it made. Anyway, that’s a problem for later. A good half litre came out of the transfer case (still a long way shy of a proper fill) and it was very black indeed. It will be interesting to see inside it when I eventually get around to cracking it open. Plenty of work to do before worrying about the gearbox.
- 27 replies
- land rover
- 109
(and 1 more)
Tagged with:
This morning I arranged a divorce There are no rivers of oil etc, so just normal Imperial seepage. The clutch looks quite new, a Borg&Beck. The release bearing also feels new. I think they can go another round. Winning!
- 27 replies
- land rover
- 109
(and 1 more)
Tagged with:
I managed to get hold of an engine crane today, observing social distances etc. This happened so I thought I may as well take the engine and box out. Finally some bolts that were easy to undo, as they are all coated in liberal quantities of various lubricants. A couple of disturbing revelations, which made me very glad I never drove it faster than about 30km/h. The bolts connecting the driveshaft flange to the diff were less than finger tight. Also the left engine mount wasn’t bolted to the chassis. Definitely a bit of weight in this lot Voila. One nekkid Land Rover
- 27 replies
- land rover
- 109
(and 1 more)
Tagged with:
LOL. I think it’s a sheep remedy. I’ll keep it in mind, but the kids may veto.
I took the dash off yesterday too. Pretty straightforward really, though some of the screws are in awkward places. Also, slotted screws are of the devil, and should not be allowed in any automotive application. The lower dash panel obviously contained a lot of detritus, so I shook it out on the workshop floor... Actually a bit comical really. More live ammo too. .22, .22 magnum, and 12 gauge shot gun. The whole lower dash is rotten. It’s made of thin steel, lightly painted, covered in foam and vinyl. This could be a challenge as this is not a spare part that is made by anyone, and second hand ones can be hard to come by/expensive/worse than what you’ve got. I’ll put it aside and when I get creative I might try to rebuild it. I think the rat piss from aforementioned nest accelerated the corrosion, and also a corresponding bit of rust where the lower dash touches the bulkhead. Land Rover also did torque to yield way before it was cool. But of course they screwed it up and got it backwards. These ones yielded pretty good, if a bit suddenly. Next, The chassis got dragged outside for a waterblast so I can find the rest of the nuts and bolts I’ll need to undo later. The chassis is covered in bits of steel that I’m pretty sure aren’t supposed to be there, like this bit where the rear crossmember is The crossmember needs a lot of work anyway because it’s both bent and rusty, probably save up for a new one with extensions, then it’s just a case of choppy chop, weld. Pics Also, I have finished preparations for bulkhead removal. Those two main bolts were seized in there good and proper, but I won. It turns out 21mm is the perfect fitment for whatever shithouse Whitworth size that bolt is.
- 27 replies
- land rover
- 109
(and 1 more)
Tagged with:
- 27 replies
- 6
- land rover
- 109
(and 1 more)
Tagged with:
I decided today would be a good day to pull some more bits off the Landy, rather than doing gardening. The deck looks easy to remove. Only 6 bolts, and some tail light wiring. The wiring was carefully disconnected with a pair of side cutters. On the subject of the deck, its big. 2300x1800 big. This seems great, however it puts the tow ball a long way under the deck, and I forsee high head injury risk. Also, the deck is high. It’s been lifted to clear the LPG tank. I would love to see pictures of a properly mounted flat deck, as I don’t think British Leyland had 6 tall stilts bolted through tabs arc welded to the chassis in mind. Anyway, I digress. The bolts are METRIC!! And galvanised, and undid very easily. At this point I gave the deck a test lift and thought yeah, that’s not too heavy. So I stacked some spare wheels on the floor next to the deck, and tipped it off the side. Easy peasy. But then it suddenly got very heavy and not well balanced. Luckily the children were playing in the shed, so while I held on for dear life brewing up an aneurysm, I got the kids to move the cab roof, toolbox, some trestles, and my drop saw out of the way so I could finally lay it on the floor upside down. Stupid idea to do this by myself in hindsight, but here it lays. It is also rotten and not very well made, so maybe I will build one from scratch.
- 27 replies
- land rover
- 109
(and 1 more)
Tagged with:
What did you use to strip the chassis? Looks pretty good now. I’m going through this exercise (although a lot more slowly) at the moment. I’m planning on doing the absolute minimum to the bodywork, and concentrate on the chassis, brakes and running gear.
Rockauto is epic and really good shipping rates. Do you remember the alternator application? I’ve seen Midwest Bayliss, do you remember what the shipping was like? I once put together an order from Autoricambi for a driveshaft guibo, some shims and a couple other small nick nacks, would have fit in half a shoebox and shipping was over $100USD. Cancelled that one real quick.
Continued from previous. Another protracted battle then followed with more nuts and bolts. There is a sill trim that runs along the bottom of the cab that is in two sections. A short section attached to the lower rear cab and a long section that runs along under the door, and ends at the rear of the front wheel arch. These trims are thin aluminium and were already quite wrinkly. Removing them has destroyed them. They would be quite easy to remove if the bolts weren’t rusty and seized, but the brackets are quite flimsy and will not stand up to high torque situations. Finally, having extracted all the bolts, the rear cab lower half lifts away, and is a bit awkward to remove without a helper, as it is a decent weight, and the galvanised sill frame now has no rear support, so you can’t put weight on them. It’s a good thing Land Rovers are not fast, the seat belt mounts don’t look like much. But hey, there’s a sticker that says they are approved by Her Majesty so they must be OK. Factory toolkit: Exploratory choppy-chop. To be fair the end caps were just about weet bix anyway Til next time
- 27 replies
- 7
- land rover
- 109
(and 1 more)
Tagged with:
I’m on a roll. Some more dismantlation has occurred. I’m struck by how simple these cars are, but how bloody difficult at the same time! The following represents about 5 hours work, but then again I tend to work like this I can tell you all I’m thoroughly sick of getting dirt in my face, up my nose, in my eyes, ears, hair (what’s left of it), etc. once again, every single bolt was a knuckle skinning, rusty shit fight. The seat box is quite light, and easy to remove by oneself. Next was the fuel tank. The front tank outrigger was quite bent, so application of earmuffs and vicious assault with a large hammer was called for, followed up by several different socket and spanner sizes and the trusty angle grinder. I found some hieroglyphics
- 27 replies
- 6
- land rover
- 109
(and 1 more)
Tagged with:
Another semi productive day in the shed. As well as replacing front wheel bearings on the ride-on and cutting the grass, I have managed to pull some more bits off the Landy. Pretty simple stuff really. A couple of the hinge screws wouldn’t budge so I just smacked the hinge pins out. The rest of the hinge screws came out very easily. The roof bolts are also a doddle, and the whole thing is very light once you break the seal. The windscreen then comes off very easily. Many archeological discoveries were made too. A pocket knife, numerous ancient, live .22 rounds and bits of Nana’s finest china. Next was the rear cab panel which also didn’t put up much of a fight. I might do the seat box next. I should get one of the kids to lie under the truck and hold the 7/16ths spanner on the nuts while I go to town with the impact driver and socket. Other observations: the driver’s door is pretty wrecked. It needs a new door top and the frame is also rusty and has some large structural cracks in it. Passenger door is fixable. The bulkhead will need some patches and new footwell panels. It’s going to be a big job...
- 27 replies
- 9
- land rover
- 109
(and 1 more)
Tagged with:
Oh wow yeah, $6 for a Lada regulator is pretty bloody cheap.
Those solid state regs are quite a bit cheaper too so that might be the way to go. Where’s a good place for Lada parts? I once tried to make an order from Autoricambi as they have some good stuff that’s compatible with the 125, but the shipping was twice as much as the value of the parts so I gave up.
