Posts posted by Mof
1st Jan 1990
Mine is 1993 and has never had one
Wat it's none of those things
I can still read it
Hey what does your rear spring slipper look like?
I don't suppose the trailer might have once had a double eye rocker type? That might explain the long rocker bracket.
Doesn't look like it should to me.
It won't go far with an input shaft thru the middle, and a pressure plate up against it
Fanghill hut, up the Wilberforce River
Only fell in the river once. Didn't drown the bike but got water in the headlight
Took the farm bikes up the river
- 8
I got Sena spider st1. They bluetooth to phone but mesh only for comms. But a way better range for comms than bluetooth.
Also these are the cheapest I found for two and post didn't take long
@chasinthemirage get Bellamy and east to make up two main leafs with the same arch but the eyes the other way. Then swap that onto your spring pack.
Yes ok, but above that 80% it makes essentially a hot wire
4 hours ago, RUNAMUCK said:
Obviously a 10a fuse with a 10a draw doesnt leave much room for error.
Yeah that makes fire
4 hours ago, tortron said:
Potentially other than not sitting right the bearing has fallen to bits, or the fork has broken.
Or the fork is bent
1 hour ago, shizzl said:
Yes correct.
but I have noticed that the clutch fork has no free play now.it will all be coming out of the car in the next week or so.
any video will just show it running, wheel start to move then it all stalls out
Probably normal
Go on give us a video
Have you tried giving it more throttle?
Sounds like it belongs in the ocd Barry thread
On 13/09/2022 at 18:01, JustHarry said:
Loosely following.
Was kinda keen to ride this but have been given the hard word by @RUNAMUCK that I need to do backup again lol
What's Will doing?
Is that a double trailer combo?
Who's running that?
On 18/09/2022 at 13:58, ajg193 said:
Do you have a video of what is happening?
3 hours ago, shizzl said:No noises, just stalls on release
clutch fork and bearing has some movement at rest so feel normal.
Yeah can we get a video of it happening?
Can you push roll the car on the floor in neutral?
But you can fully rotate the diff input flange right?
I've had a box before where the input shaft had a bit of a whack in and it jammed the 4th synchro onto 4th gear. So it acted a bit like it was in two gears, maybe it had some slack like yours does I can't remember.
If it drives in 4th that'll tell you
Can you pick it up, put it in 4th and see if it goes further?
2 hours ago, shizzl said:
Definitely not brake related, that’s what I suspected first off. But spins fine when jacked up.
What do you mean it spins fine?
Can you fully rotate the driveshaft by hand with the gearbox in neutral?
The Pogs 1980 Nissan Uncivil Ian - Discussion
in Project Discussion
It's on the back of the trans, probably oil in it
