chris r
Everything posted by chris r
I thought I had photos of the harness but didn't. I decided to try swapping the ecu plug on the adaptor harness to the genuine as its less work and soldering everything. The pins were quite loose in the Chinese connectors so there might have been something dodgy there. But when putting it back in I noticed that Then wire might have snapped when I was rough and pulled the twist and tape out or it was damaged internally after the big swap/surgery. Seems to be fixed for now. Let's hope it stays that way
Finally had another look at the rear brakes as pedal was getting soft again and handbrake had heaps of travel. Turns out whoever did brakes last time replaced the auto adjuster on the left hand side with the wrong one(lh has reverse thread) so it was auto adjusting in not out. If grabbed a couple from pap when I was there and fitted the correct one in and adjusted up and all is well. Probably was the same mekenik who left the hard line into the prop valve loose. No pics becuse break dust etc. I thought I'd try patching the exhaust leak in the beagle so I could take it for a wof One patch turned into two, then four. Then I found more holes and decided the whole pipes rusty and fucked and I need to redo it so it's back to sitting on the lawn for a few months
I'm calling the vacuum leak fixed. Well as fixed as it can be with the alix manifold. I noticed a thin/undercut bit for the idle motor feed port meets the throttle body bolt This Bluetooth connection makes setting tps easier. Get tps roughly in the ball park and then adjust the min/max values on your phone
Pick a part mission was a success. Someone had mostly removed a crv swaybar so I pulled the last link off and nabbed it. The Internet says they are the same as the "type r" bars at 26mm thick. It's certainly thicker than the existing one, for $16 I figured I'd give it a shot. I'm hoping it'll make it a bit 'flatter' around the corners. A fiends in the states with a orthia has confirmed the rear trailing arms from the shittles are exactly the same as the orthia ones so that makes me thing the rear subframe will be the same too. So all going well if I came make a 'bolt in' bracket on the orthia/shuttle they should interchange Also nabbed some obd1 ecu plugs and bit of loom so I can get rid of the harness and speedo issues. I don't think I have any of the crimps to suit so will probably have to cut and solder everything
Finished off the heat shrinking and soldered the rtc module on with the nice 90 deg pins. Ran out of caring getting the shrink identical lengths Trimmed some bolts so the top plate fits. Screwed the back plate on so it's as done as it can be I'll order another tube when I have some spare project money and it'll actually display the time
And for shits and giggles I got all of the clocks in one place
Spend some time this morning. Turns out the rtc (timer/clock) module was faulty. Soldered another on and it's all good now. I had the anndoes the wrong way around so it was seconds minutes hours instead of the correct orientation. Quickly loomed and cable tied the wiring I need to finish up the heat shrinking and mounting stuff and then it should be pretty much finished
I still need to wire in the setting switch, power switch and socket, and the light sensing resistor. And figure out why it's counting like it is and not doing clock stuff
So in procrastinating cleaning the car/carport i found the other nixie clock I started/ put aside as I cbf with the wiring. Had some multicore scrap with numbered cores which made the process significantly easier Progressing All the cathodes soldered in Couple of anodes soldered in for testing and labled so I know/remember what's what next time I touch it And test is a partial success. I'll solder the rest in and double check no shorts as it should be 10s and 1s of seconds so more investigation needed
If on a budget Mx5 probably easiest/cheapist rwd setup imo. Honda K series are great motors with decent power potiental but quite tall and all the accessories add up quickly
So the intermettent speedo signal to the ecu finally became more permanent. Tested everything and found the adaptor harness had a shit connection. Wanged a wire across and taped it as a test and it has worked for a week now. When I have more energy and time I'll source some ecu plugs and repin/replace the connectors and put the harness in the bin
I've been dreaming up a rear swaybar mount for the shuttle for a while. Some high spec 2wd Facelift have a rear swaybar but they are rare as rocking horse shit and looking a factory diagrams will interfere with the diff and driveshaft The orthia subframe looks pretty close/almost identical to the shuttle one so I'll start on that and see how it goes The crv has(had) a rear swaybar with mounts welded onto the subframe from factory. He crv subframes do bolt into orthias but makes them crv height. I've got a couple of end links from a civic and one from the crv. Current imaginings are dummy them up and attempt to replicate the crv brackets and weld something onto the subframe
Had a grand plan of replacing the lower control arm bushes today. I ordered a kits while ago. I really rate the energy suspension stuff, got a lot of their bushes on the shuttle Noticed a split tiretod end boot and wrong nut while I was in there Ran out of fucks pretty quickly (and need the car back together to use for work) so just ended up replacing the main rear bushing Managed to cross thread on the the bolts fighting the arm back in so shot to pick a part to grab one. Got lucky and there was a civic with the bolt and a near new upper control arm so I grabbed that. (easier than replacing the bushes and ball joint boot) All back together with fresh split pins and a new tierod boot Also was a barry and gave the inner guards a jizzing of underseal
chris r replied to yoeddynz's topic in Project Discussion
Headers look great! If you want to go full dairy spec just splash some acid on the welds and hit it with scotchbrite and it'll look mint. -
I've had the speaker box thingy on site for the last two days and it's been going for a 9 hr shift and not drained the battery. Wasn't mega loud but the sound traveled surprisingly far. I orderd another Bluetooth board off alix which has a different amp chip. It's the same Bluetooth receiver module/Id but doesn't have as loud of a Chinese voice saying Bluetooth has been activated. And more importantly its louder than the old one so I can win the site noise pissing contest. (I'm not that petty/a dick normally) Will mount it in and test it out next week. It also has a volume control and aux in if I want to use it. Had it cranked up high and hit some safety/cut offs so it'll be set to a safe level and left that way
Battery holder is on. Brackets are barry af but who cares Even closes with the battery fitted
Another year of oil burning ahead of me. I'll need to look at the speedo input into the ecu as it'll intermettently have no vtec as ecu won't see the signal. The speedo works 100% of the time so I'm guessing it's in the adapory harness. I checked continuity between the ecu and gearbox sensor and it was fine (and worked at the time). I'll have to spend more time on it
