chris r
Posts posted by chris r
9 minutes ago, shrike said:
Able to get a tap in and put a grub screw in with some sealant?
It's a weird angle so drilling/tapping would be beyond my skill set
Had some barry time in the shed.
Drilled/chamfered the oil sammich plate holes. Factory finish didn't leave me confident bits wouldn't fall out/off. The fitting didn't even have holes lined up so drilled that and stopped just short of the taper on the an end
Same deal with the center fitting
It blocks the holes somewhat so it'll get a trim to suit
Got a better photo of the manifold issue
Tip of the file is where the hole is, it'll be major surgery to get there with a welder so I'll give it a go with some cold weld epoxy and really hope it sticks
It's the least bad option
Had a play in the shed for a bit today, the 32nd keeper just fell out when I moved the head which was nice.
I had a look at the manifold to see if there was any loose bits that'd cause sadness if the motor injested them.
This lump was weird but I figured shit casting or something
Looks a bit shit on the inside
Blocked the other end of the port off (idle control valve inlet) and blew through it and it was not air tight
Shoved a light in the plenum and there's a gap. Dunno if casting shifted or they machined it wrong or just China qc
That grey looked a bit 'off'
I noticed a bit of a scratch and figured it was paint. So gave it a jizz with brakeclean
Have started communication with the seller and will see what they come back with
- 5
Orderd a aliexpress manifold, vtec oil feed kit and valve compressor tool.
It doesn't look too shit, casting looks okay, bolt pattern even matches the head
Valve spring Compressor works, they our the nice thread taper on the wrong side of the tool but it still functions
I've got a bunch of leftover gaskets etc from the turbo motor build, stem seals I'll use on this head.
One keeper has escaped and is in the head so I'll fish that out later.
Ordered rock autos C̶h̶e̶a̶p̶e̶s̶t̶ finest muffler and reso as the guy I called at the exhaust suppler was rude as fuck and it was double the price.
Somehow a 2.5" catalyst converter appeared at work and noone claimed it so I took it. (2000 means I should keep it) and its free and will hopefully keep it quiet. My aim is to have close to oem vokume system as I'm old man spec
Got some liquid gold today
Strangly enough with the correct type and volume of fluid things work much better.
It was two litres low, shudder is gonw now, it still surges a bit but I'll ignore that until it gets worse.
Changed the atf in the orthia while I was on a roll
- 5
Ac doesn't work in the accord and the beagle has a intermettent miss/still is leaking oil.
I was trawling marketplace for a manual crv to pillage for parts and saw something tempting. The guy was hard to deal with and a bit abrupt/rude. We took it for a spin around the block, tired a lowball and he didn't accept it. We counted out the cash and he kept ignoring us. His kid came up to us and was like "excuse me are you going to buy the car or not" umm yes we aren't standing here with cash for no reason
Ticks all my boxes, cheap uncommon, awd high km, ex damaged auction.
Had typical cvt shudder but I'll service it and ignore it.
Lisa loves it and has claimed it, she wanted something tall and small ish so it Ticks those boxes too
- 15
1 hour ago, Roman said:
Oh man the ultimate Vitz fanatic (Pat Norris) lives in Nelson... I think that might be one of his cars?
He's got like 20 of them.
Including a full blown 1300cc class rally car which is cool as.
If you ever meet him, brace yourself for some full blown vitz barrying
Can confirm pats barrying. Spent a good 30+ mins on the phone with him.
34 minutes ago, DB8-TypeR said:
All good, i just know that in every manual Honda ive had a fresh box of Honda MTF is like magic, especially in my old CRV tnat had just been serviced with some mystery gearbox fluid and was very notchy and noisey, fresh honda MTF and it was like a brand new gearbox.
Thread for reference
https://nzhondas.com/topic/189765-reliable-and-accessible-alternative-found-for-honda-mtf/
+1 with me and genuine fluid.
I've also used torco and its as thin as genuine and shifted waaay nicer than the other stuff that was in the box
Such a excellent blend/colour match you'd never even guess it had been painted
Boots on and lined up. A tweak of the latch and its actually shutting nicely on the first attempt now
- 6
Right hand side came up good.
I got a bit keen sanding and got down to metal so it's got another coat of brunox
Left side still has a dip but it's good enough.
- 6
The metal was so thin it was either blow a hole instantly or tame some seagulls then blow holes.
Cut a patch out and seagulled it in
I should have cut a another patch out for the roof but mig wire worked in the end.
Ground smoothish and etch primed.
Seam sealed all the holes etc and first skim of bog
Sand and second coat
I'll give it a sand and another prime tomorrow
While I had the seam sealer out I redid the orthia. I've got some silver on the way
- 6
Had a nosey at the rust in the beagle
Didn't look too horrible initially
Wire brushed/treated/ignored the rest of the inner rust
- 5
Sub is working,I used Anderson connectors on the box so I could remove it easily if needed and they weren't seated properly.
Only the finest side of the road kitchen cabinets for material to make the sub box
Fitted a alarm as there is no boot let lock and it's annoying havering to open it from inside the car
https://i.imgur.com/5cBF7FJ.mp4
I suspect the sub is nfg as its no worky. Tried two amps and two seperate rca cables, power where it should be etc. Will do some more testing tomorrow and go from there
Kinda keen for another awd honda... Pm me if you do decide to find another house for it
Eugh non rock auto prices suck. I wanted this sorted before the holiday so had to pay the price.
I've now doubled my spend on the car
Pulled these out of shuttle (have konis to go back in) so time permitting they'll go into the orthia. Mugen damper adjustable shocks so some honda foamers will think I'm fancy
I went back and forward a few times but that's close as I could get them
- 16
30 minutes ago, yoeddynz said:Can you please do the right thing and rotate then so they all line up (I know it wont last/ #avoid corners)
Will do next time I have it on the hoist
But for now
The mechanics were laughing when I collected the wheels. "fucking teddies" I didn't know they were real wheels
10 minutes ago, kicker said:
Nice, I used to have an Orthia a few years back, always thought they were one of the better shaped 90's wagons. I spied a manual one the other day, mustn't be very common.
http://noriyaro.com/wp-content/uploads/2011/06/noriyaro_honda_orthia_minor_car_002.jpg
There are a few 2wd manwell ones around, my ex had one.
I want to find a manwell crv and Rob all the bits out of it
Nice Xmas list
Got tyres swapped from the other wheels
So glad we have a hoist at work
End links done
Tightened wheel bearing and fixed the buckled wheel
- 16
Chris R's various honda thread including punishing modern non os daily driver updates
in Other Projects
People seem to want moonbeams for a awd honda manual gearbag.
Found one for not a horrible amount of money. (still more than the orthia cost)
It even came with wof/reg and a car around it
I figured all mounts and small stuff would be annoying to find so may as well have it all in one place.
Hopefully can slam the auto into the crv with minimal effort and sell it on. I'll need to figure out the linkages as the autos are Colum shift and that stuff is welded/mounted to the column
