Guypie
Posts posted by Guypie
  1. I had a friend who used to do the recycled engine oil thing. He would settle it for a few months and then run it through a centrifuge and a filter. He had a 1kz prado and did some 180,000km or so on it if I remmeber correctly.
    He originally used transformer oil as he was a industrial electrician, I mentioned this to someone once and they said something about that stuff being super carcinogenic.
    I heard some nightmare stories from him too though, hoses popping off the centrifuge and staying up until 4am on a work night to clean up the mess. I always kind of thought it was in the too hard basket really.
    • Like 5
  2. Dang that is a sweet power hammer. VFD might be just the ticket for getting it moving without popping a circuit breaker, mine has a soft start which would probably work well for getting that moving. I presume it only hammers when you stomp on the ring round the base?
  3. So once the mill had a VFD bolted to the side I welded in a sleeve for the main pivot and bored out the bearing pockets. I very nearly stuffed it up by trying to take to light a cut but with some advice from @Geophy I managed to get an acceptable surface finish and clearance for the bearings.
    Mocked it up on the drawing and it was looking pretty good! The pivot location had moved a little bit from the original design but I changed my linkage x3 save to match and it didn't look like it will cause any issues. This is why next time I will bore the pivot hole after welding the triangle together. Though I didn't have the mill running at the time either so not sure how I would have done it anyway.
    I didn't want to invest too heavily in this bike so its mostly made of stuff I had already. When I ordered the tube for bike #1 I ordered extra so I already had the top tube , seat stays, chain stays and seat tube. I ordered a length of 44x.9mm 4130 for the down tube. The wheels are an old 26" set that I already had, the fork is one we got free off facebook ages ago. The shock is also one I already had. I will probably be looking to upgrade the fork once I finish the bike as it is a damper rod/ orifice style which doesn't have speed sensitive damping. So if anyone has a boxxer/fox 40/rcv888/dorado or prettymuch any 200mm double crown fork with shimmed damper you want rid of let me know.
    Next up I needed to make a jig for the rear triangle. This is what I came up with:
    The dropouts are from bike fab supply because making my own last time took way too long and these were pretty cheap
    • Like 7
  4. 10 hours ago, NickJ said:
    Buy a bit of this for old leather, works a treat on boots.
    https://www.saddlerywarehouse.co.nz/index.php?route=product/product&product_id=1050
    I second this movement, neatsfoot oil is excellent.
    Also, when we ordered it last we got it under @hampie's name and they kept sending saddlery warehouse advertising stuff to her. Got to tease her about being a horse lady whenever it turned up til we moved house.
    • Sad 1
  5. 17 minutes ago, johnny.race said:
    Those threaded cutters sound like the ones a Clarkson Auto Lock (chuck system) uses. My take on things - depending on what you are doing, I wouldn't waste my time using HSS anything ... I'd be setting myself up to use tungsten carbide indexable cutters. This is my personal experience, but then again I have a pretty narrow scope of what I use mills and lathe to do, plus I've never had any formal training.
    I dont disagree with you on carbide vs hss, but I have a bunch of hss and no experience so I think will crash all my hss lerning before spending the money on carbide.
    I mostly just need a 5/8" collet cause theres quite a few endmills and ball mills in that size.
    I will probably replace what I have with carbide when I run out of sharp cutters in a given size. I have a 20mm capacity jacobs chuck that is stuck in a mt2 arbor at the moment that should hold an endmill ok, I just need to go get some dry ice from a lab that I have friends at to try and shrink it out. By the time I need it I might even be able to splash out on a chinese er32 setup.
  6. 51 minutes ago, yoeddynz said:
    Yeah I have that collet system on our little drill mill. Its called posi-lock. Was all the rage when I was learning my trade and works really well. Nelson polytech had it, as did all the machine shops.
    But..
    Everything to do with it is kind of expensive now and from what I know most firms have moved away from them, now using the more standard ER setups etc.
    You can still get the bits and if you have a collection then just keep using it.
    https://www.warco.co.uk/collets/303196-individual-collet.html
    I'm missing one collet from my set. You might have a spare?
    I'm so jealous of your mill. When I grow up I want to own a big boys mill like that :-)
    Cool, it seems like its a pretty good system. I am just missing a few common sizes and I have a decent collection of threaded shank cutters so I will probably go through my cutters and figure out what sizes I'm missing. Well once my wallet recovers from the beating the milling machine has already given it! Its not a cheap hobby but at least most of the stuff I need to get for it a re buy once/cry once type deals
  7. I got my mill up all back together and its running. I didn't end up getting the gearbox off. I wasn't willing to commit any more time to it so I cleaned everything up and threw it all back together, which in itself is a massive improvement. Long term plan is to get one of those bridgeport style power cross feeds that goes on the end of the table and modify it to fit my machine. Anyway, everything moves much more smoothly with clean fresh oil now so thats nice. I fitted a vfd to the spindle and made a little bracket out of some stainless sheet from a commercial coffee machine (recycling!)
    Still needs enclosure/strain relief/cable glands for saftey reasons so thats pretty high on the agenda. Next question is this:
    This is the collet chuck that came with the machine. I have 5 collets for it but I really need a few more sizes. I have no idea what kind of collets these are and theres no markings on the chuck, the collets or the box they came in to indicate what they are. Anyone know what they are? And if you are familiar with them are they worth buying more of or should I look at getting a different collet chuck setup (ER** collets?)
  8. my 2c - for the home handyman type stuff straight co2 is the best.
    Downsides:
    -It has its limitations in that it wont spray transfer, most little welders probably won't get there anyway.
    -about 5-10% more splatter (in my limited experience)
    -Probably other things, I'm not an expert
    Upsides:
    -owner bottles in the form of fire extinguisher bottles are cheap, usually around the $300 mark full.
    -it stores as a liquid unlike argoshield mixes. this means that you fit a whole lot more in the bottle. This is a massive upside in my book, when I want to run mig I want it to be cheap.
    -Last fill I got was at gaspro, cost $45, a lot better than the $130 swappa bottles for argosheild. The chap there said its $10 per kg, its a 5kg cylinder but it was a bit too warm to get the whole 5kg in one hit that day.
    -Apparently runs a bit hotter than argosheild mixes would for the same amperage on short circuit mig. For little machines this might be handy. In saying that I haven't had any issues welding panel steel either so not an issue for rust repairs.
    I have put a good number of hours on the mig over the last few years, built a couple of trailers and lots of random crap with co2 and haven't had any cracks/breakages or weld related issues. I guess the caveat is that I also have a tig so if I want a fancy weld I can use the tig but generally I use mig for most fabrication type things.
    Also, I'm just a guy in a shed sticking stuff together for fun so I don't really know what I'm talking about hahaha.
    • Thanks 1
  9. Not sure about the FB but on the F series with a little bit of work you can fit MG b gt front hubs. Combined with lowering springs it corrects the camber due to the angle of the spindle and adds extra low cause the spindle is higher on the hub. win win!
    Edit: Scrap that got confused between a couple of old cars I used to have, that was a morris oxford. duh.
  10. I started stripping down the table and saddle on my vertical mill today but I have gotten stuck. It was all fairly smooth until I got to the point of needing to remove the cross slide power feed gearbox. It sits on the right hand side under the saddle and appears to be held on by 4 cap screws down though the saddle, and theres a shaft that crosses under the cross feed drive nut. Cannot find anything else holding it on, it will drop down a little with the screws removed but I can't get it to slide to the right to get the shaft out of the saddle casting. super annoying, Will probably end up just cleaning what I can with it in place and chucking it back together. If anyone has any bright ideas please share. It is an Elliot Milmor super 16.
    Annoyingly its a rare machine and is its own design, not a bridgeport clone. There's many videos on youtube how to pull down a bridgeport, it seems a lot simpler than this machine. The gearbox doesn't want to come apart either and one of the feed speed selectors is stuck so it really needs a service or to be removed altogether. The good news is that I managed to clear out all the congealed oil and goo out of the galleries and ways for the cross slide, and will be able to reassemble the backlash adjuster correctly so that it works. I am going to order some turcite sheet off aliexpress and shim the y axis gib because it is out of adjustment. it has a fair bit of wear and tear on it. Long term I would love to have a go a scraping the ways back in, but realistically I will probably never do that because I have found I am more of an object oriented shed dweller and I really don't need much in the way of accuracy to make the things I want to make.
    Anyways, pics because no one likes a picless post:
    • Like 8
  11. I was watching a machine shop tour and they were showing a dude around their machine rebuilding facility. They were talking about those big magnetic chucks on blanchard grinders and they have to be rebuild every so often because the coils in them flog out over time. Wonder if the electromagnetic clutch in your old lathe is suffering the same kind of issues?
    Somewhat irrelevant now anyway, new machine looks good.
    That video was really interesting (if you are a weirdo who likes machines), here's a link if anyone wants to have a look:
    I put couple of coats of 2k primer on the frame (no colour coat yet) and after looking at it sitting in the corner of the lounge for the working week dreaming and pretending to ride it much to the amusement of @hampie, Friday came around. I don't work Fridays so I was free for the day, so I took stock of what I needed to get the bike all together and all that was left was a length of shift cable. So I made a click and collect order and popped down to Te Awamutu and came back and got everything all assembled.
    Sorry pics are fuzzy, crappy cellphone life.
    The drivetrain is a deore 11 speed, it's actually destined for a different bike but for now it can go on this one. There are some issues around shifting I think partially due to the B screw end point pawl on the hanger being too far to the rear of the bike. I have shortened it a bit since my first ride and it has improved a bit, I think I probably need to check the hanger alignment again as well. Also, there's a weird combination of boost standards with a 68mm bb shell so I think the chain line needs a bit of attention.
    In the next exciting instalment: how does it ride?
    • Like 6
