Everything posted by Muncie
Daves new school holden shambles. (And finally a Turbo)
- 386 replies
- 7
- not as good as a barra
- ecoboost
(and 1 more)
Tagged with:
Since this has been fitted with VE wheels the speedo has been out by miles..... like 14ks out at 100 ive come close to getting a ticket so decided to sort it. The dash has always flickered and rattled so i decided to do a level 1 to level 3 dash upgrade and buying a license to reflash the body modules. This was fun as you can add the Hsv startup GIF and a cystom off message currently the "Blue whale" after the nickname it got from getting airborne chasing my work colleague in his sports car thing. Apparently Breaching is what my car does over undulations. So now i can plug in just like my VW and change shit in the BCM and ECU- 386 replies
- ecoboost
(and 1 more)
Tagged with:
Well ive tried to sell this after hitting rock at work and cracking the sump it sat on the lawn for 8 months getting nothing but a drink of oil and a short drive every now and then. I got sick of it been all forlorn full of water from been nose up on the drive and starting grow mould with no one biting on a low asking price. I got a offer for the 19" wheels i couldn't refuse so its now been put on 18s with new tyres and had some "more" money thrown at it so i can use it as my daily. ......... fuck it is quick. Ive got 2/3 of a 3" exhaust once i get warrant that can go under it for even more poke. A Sump a set of seal's and new cambelt kit are on the way from the USA to get it all nice again.
Something like this.... after the harley. Harley is sick
You absolutely should build a Harley with a 2 stroke in it.......
Kimjon - No13 (twin 49cc motors on a drift trike)
Muncie replied to Kimjon's topic in Other Projects
So those pedals should be pretty redundant then...... slippery slope once this one works -
So currently this is at work in storage while i sort the stuff that keeps breaking and work out of town. Anyway did some more turbo stuff, So i took a punt thinking surely if i move the spring from one side of the diaphragm in the actuator to the other side it will move under pressure instead of vacuum. Sure enough it does but now how the hell do i seal it?? Im thinking of using 2.5" triclover flanges to remake the can so i can crack it open to change springs easily as this one might not be quite right now its getting a different signal.
Thats the exact brake setup and rear wheel ive got my eye on. (Actually on my watch list) Ive come up with 3 options 1 fit the 10" pit bike wheel hope it works 2 fit the pit bike wheel shunt the engine forward and fit a seat. 3 fit another pocket bike wheel swap the engines from this and my sons mobility scooter and do huge skids on that. I have a 4th option of a golf cart im working real hard to get my hands on.
Received replacement wheel last night fitted the new hub brace bolted it it all together then proceeded to spin the rim inside the tyre just trying to crawl away from a stop. Fuck sake..... rim survived fine but new tyre is garbage it looked cheap and poorly made might be time to give up on the pocket bike wheel combo. Have found a 10" pit bike wheel that would go in the gap as a bonus has correct sprocket out of box. Its $ though and i am severely keen to fit it to a go kart or something else really soon.
Might be the easiest thing to do then add an external wastegate at least then if the vanes seize...... no matter. Will see if adding a vacuum port to the actuator will work first be cool if i can get the variable vane set up to work.
Yup its a vane turbo off a touareg cant see it getting cooked to quick longest ride it gets is 5 ks before its out of fuel. If it does die I'll parts bin something else on.
Back to the turbo...... everything is sorted for this i thought bar the manifold until i tried actuating the wastegate/vane thing it needs a vacuum signal not pressure. Got me a bit stumped maybe drilling a second port on the other side of the can will make it work. Anyone got an electronic boost controller floating around the shed? Just realized i will need one.
Yeah nah not this time i can't pop the tyre over the rim due to pocket bike wheels been made from some sort of aged cheese if i can find a split rim it will work The hub girdle thing will absolutely work too unfortunately the above chedder grade rim cracked trying to fit the pocket bike tyre to it so ive got another complete wheel on the way....... because i cant be fucked fitting tyres they really are a cunt to get on without damaging them or the rim.
Just discovered today that this rim will accept the tyre off a cessna 152 and the width is ok to clear the frame. Will try it and decide if it's worth doing is a pretty big baloony looking thing but would be similar size to front wheel....
Scored a new back rim for this to get it going again. Ive added this support to the drive ears and bearing carrier to take the drive directly to the hub instead of the 3x m5 bolts its a very snug fit i wont weld it on though so i can get it off to fit to the next wheel after vaporizing this one. It Will get 3x m8 bolts through it to bolt up to the sprocket.
Another thing ticked off. Turbo oil adapter yes 10mm plate is excessive but i threw it in with a job lot of other stuff through work so it was free cant complain. Fuck yes speedflow stuff looks the goods!!
End goal for this is building something road legal. A trike fits that bill for me so i could try avoid the exorbitant registration of a 600+ cc bike.
The engine is the real project on this eventually I'll pluck it off and put it in something else cool for now though I'll keep at it fix what breaks, brush up on my welding and get my head around turbos by building this whole setup from scratch. I need to figure out electronic ignition for this as well I'd like to use coil on plug for compactness and the decent output they can provide.
Ive been fucking around with it so long now its been refined if anything its overbraked and cant spin a wheel on anything but gravel because its got so much traction. The 2 guys at work who have ridden it are motocross riders no way I'd let anyone with no handling skills near riding it.... ever What it does well is make heaps of noise and makes going fairly slow a heap of fun standing up your sense of self preservation kicks in pretty early.
Well shit..... did this again blew another rim to bits ive got a permanent fix for this but i might go to a 10 inch rim first same as front. On the the upside ive got the oil feed and drain 80% done for the turbo just got to weld the AN4 next to the AN6 fitting and thats it then it just needs the exhaust made to get hot gases into it.
I quit my office job as a technical manager 8 months ago and am working on the tools as an engineer now. the quality of my work is going to go up with access to a proper workshop again.
Got this at work now im 3ks down a private road so its been used to drive between sites by everyone. Currently parked in the engineering bay getting attention on my lunch breaks. Going to start on a new inlet manifold as the original one is choking it stopping it from revving out. The burrs for porting the heads showed up last week as well as the weld on AN fittings for the turbo plumbing. Finally have a use for this thing and a place to work on it. Some photos will come soon.....
Is it possible the Ecu has shit the bed? Water old age.... perhaps its only commanding one injectors open. Bang an OBD reader in pronto! Will save hours of head scratching and point you at least to the system playing up.
Finally have this turbo back in one piece and have finished the flanges needed. Ive made up some -4 line for the oil to it and set up a tee from the oil gallery on the engine (yes this engine actually has a pressurized system) Waiting for some weld on AN fittings to finish the oil lines, then the manifold...... the manifold hmm i have the steam pipe to make a log style but thats so boring. If i hold off a bit i can make it two into 1 out of stainless i just dont think i can wait.
