I have converted a FX to manual from auto.
Struggling to find any info on using the auto shafts.
I am using a C52 from a ae100. The equal length shaft bolts to the block but I feel it's out of alignment, although online parts catalogs say it's the same for manual and auto.
Any one done the swap, is the manual equal length driveshaft bearing different to auto?
I have a rotating noise relevant to ground speed when test driving and it feels bad, but can't tell.
Yeah by the looks on silvertops manual to auto driveshaft bracket is different (axles are the same). Unsure if there's enough meat to slot the holes. Toyspeed seems to be down but the answer should be on there. It's been too long since I've done any of these swaps I can't remember anymore.
https://www.tapatalk.com/groups/ae111_forum/driveshafts-interchangeability-t6172.html
If you don't have any luck finding a manual hanger bracket, I've got a 1-piece driveshaft sitting here for you. Might get you going/rule out
