77lancer Posted March 16, 2023 Share Posted March 16, 2023 Hey guys, Just been trawling through the options for a 5 speed on a 4g36 engine. I have seen a 5 speed from a 4g52 engine from a Celeste. Is this a possible option for a easy fit, or would I have to change quite a few things out? I haven't been able to find any info yet, so apologies if this is a topic that comes up often. Cheers guys Quote Link to comment Share on other sites More sharing options...
bigfoot Posted March 17, 2023 Share Posted March 17, 2023 4g52 celeste box will bolt straight in, you need to change the gearbox mount to the wider 5 speed mount or slot the holes to fit Quote Link to comment Share on other sites More sharing options...
77lancer Posted March 19, 2023 Author Share Posted March 19, 2023 On 17/03/2023 at 20:45, bigfoot said: 4g52 celeste box will bolt straight in, you need to change the gearbox mount to the wider 5 speed mount or slot the holes to fit Is this box the same fit for the shifter and driveshaft? Or will these need some adjustments as well? Cheers for the reply Quote Link to comment Share on other sites More sharing options...
bigfoot Posted March 19, 2023 Share Posted March 19, 2023 Shifter and driveshaft fit Quote Link to comment Share on other sites More sharing options...
