Jeff's 1989 Toyota Hiace Supercustom TC24 build
  • Replies 41
I'm pretty keen to remove the enkei rp01 from it for something a bit more classic. 20230302_200812.thumb.jpg.466008fd6357a43ae58c840598b4770f.jpg
picked up these gzg50 century 16x7 +45 alloys. Sadly I didn't check center bore of van first which is 66.1 and these are 60.1 so the foul on hub, they also look pretty close to front upper arms. Trying to decide if I invest in getting hubcentric spacers machined to fill the guards a bit more or move them on for something that's an easy fit.
After a piss around with a freight company I decided to drive this thing filled to the absolute brim with a coupe 60s mopeds and other possessions including almost 2 year old son to Christchurch. Got to Taupo and got the old canceled ferry with no rescheduling available. I'd already booked accommodation at foxton beach and a flight home from Christchurch Wednesday morning so decided to push on through and see what I could organize. I wasn't going home when i have to do the trip in 3 other vehicles over 16 days.20230307_164047.thumb.jpg.811d4cdda6af696e0c4b06cd0d2bb235.jpg
  • Like 9
I've been busy 20230507_134832.thumb.jpg.a1617e08015716061b2b4c24f8c2f8c3.jpg
not in the intended way either. I suspect this has always had a minor leak into cylinder 4 which got to the point compression was coming out radiator cap.
While I've secured the late model 1GGE that will replace the 3Y now isn't the time to pull it so I've dropped the head off to get checked and resurfaced to keep it going while I get some rust/bodywork sorted.
I've also dropped the radiator in to get a 3 core upgrade over the rotten 2 core in anticipation for the 2 extra cylinders.
It feels like pissing in the wind fiddling with the Y but hoping I can recover some costs when it comes time to part with it. Water doesn't seem to have made it to the sump fortunately but will give everything a good flush out.
  • Like 9
In positive news I have dropped the hoodlining looking for rust and it appears OK. 20230501_150513.thumb.jpg.5db7f45ff671918ae018e7d6cf179cee.jpg
The sunroof cartridges are pretty impressive taking up the entire ceiling space front to back with drains in each corner. I'll be looking at getting these both operational again. Both sunroof skins have unsurprisingly come back as discontinued
  • Like 9
While I was awaiting some other parts I popped out the digital dash and took it to Get electronic down here to see why tacho wasn't working and temp seems temperamental20230515_113249.thumb.jpg.d8b53239df53ce8b7e867cd68325a2b3.jpg
they didnt seem to find much other than a couple of suspicious solder joints so hopefully that sorts it
  • Sad 1
