RX3UTE rebirth - throwback thing build
shizzl
  • Replies 47
  • 4 weeks later...
Put the chassis up on the table today.
then fired up the lightning scissors and whipped off the spring/shock pockets.
them found that the ball joint angle maxes out pretty quickly.
any ideas on legal ways to ease up on the ball joint?
by my calculations this limit only gets the frame 80mm off the ground. Weak as
pic is at the ball joints limit.
flipping and swapping upper arms doesn’t solve anything, thought about it, tried it, it failed.
  • Like 8
Just a quick stop in at the workshop today.
etch primed the tunnel, still want to clean it up some more before painting.
finally got the steering box out, had to lift one side of the cab to get it done by myself. Mega Kent.
sliced off the factory rad supports and mounted the radiator and oil cooler.
etched the cuts.
only have the tailgate to finish before I can start the final prep and paint.
i will remove the cab and deck for painting.
that way I can prep the chassis side of it before they go on for the last time. (Fit fuel tank back in, touch up the etch with top coat)
might even fit the engine and box onto the chassis and get the exhaust done with the cab off.
im not sure where I want the exhaust to run at this stage.
i have 2 flexi’s, 2 resonators, a 2-1 muffler and one of those ugly rotor shaped mufflers.
i will make a new set of headers for it for better clearance.
  • Like 9
So much for working today. First proper day back and had a mad case of CBF.
had a site meeting, made a plan. Went to the workshop for more ute shenanigans.
this time I decided to stitch in the new tailgate skin. Mainly so when it comes time to lift the deck it doesn’t just fold up without the floor.
turns out they built up the lower corner a fair bit with filler. Don’t know why. There are no dents.
Now it’s time to get the axles back in to get it rolling, and sweep underneath it.
it’s become a bit of a tip under there.
im actually pretty keen to make this one RX3UTE the more I work on it.
and make the 2nd ute mongrel as. Or an RX4UTE???
