Flash Posted March 21, 2021 Share Posted March 21, 2021 I'm in need of some guidance from those who know a lot more than I do about lower control arm bushes. I've fitted a Mitsi L300 front suspension to my project. The original lower control arm bushes were pretty shagged so I ended up getting some aftermarket replacements from Whiteline. I fitted up one side this morning and I'm getting quite a bit of forward and backward movement on the arm. I haven't yet fitted the strut rod so I'm guessing that will reduce this movement, but I'm still alarmed at how much movement there is. Is this normal or should I be worried ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
