SOHC Posted September 12, 2022 Author Share Posted September 12, 2022 I took the sump off and removed the oil pump and used a spare pump shaft to see if the cam gear has broken loose and even if I turn it with pliers its not slipping so thats not the problem. I now think its cavitation or something to do with my remote filter or me leaving part of the oil pick up out. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 12, 2022 Author Share Posted September 12, 2022 Pump looks good inside, I fitted an Argentinian made rebuild kit that was about 50 years old when the motor was done, but i didn't fit that little tube, the Fords dont have it but the Mercurys do, and I have the Mercury witch had all the fittings to run a remote filter and oil cooler. 3 Quote Link to comment Share on other sites More sharing options...
Popular Post SOHC Posted September 15, 2022 Author Popular Post Share Posted September 15, 2022 I took the sump off and removed the oil pump and used a spare pump shaft to see if the cam gear has broken loose and even if I turn it with pliers its not slipping so thats not the problem. Fitted that extra pick up tube, and put it back together, plugged the oil pressure take off port and have run a copper line to the port in the filter housing, filled it with 20w50 and its got about 30 psi at idol and 40psi driving, it had about 40psi with 10w40 driving to but lower at idol. I got a gauge from Blackwoods and brazed a fitting into the back for a light bulb and wile it was apart I deleted where it sed blackwoods. Also I cut the filter open, nothing inside so it wasn't trying to destroy itself. Have I fixed the problem? I dont know, might of just been a crappy ali express gauge and line, and the pump might of been sucking air because thatnmissing tube gives another 1.5" more into the oil. 14 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 21, 2022 Author Share Posted November 21, 2022 I got this small AC oil barth filter, I took it apart and some of the dimensions inside were too small for a V8 but I am reworking the whole inside, my carb is a Holly 94 witch is like 180 CFM, I am ditching the wire filter as small bits of wire can come off, I hope to find some filter foam with large open cells, I hope it won't block with oil, I can test it with the vacuum cleaner 1st. 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 21, 2022 Author Share Posted November 21, 2022 4 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 22, 2022 Author Share Posted November 22, 2022 I think its sorted now, welded a 1/4" stud and made a little tube in the top of the cap and brazed it in so if it gets water on it it wont leak into the carb, the cap was crimped on before but now its totally rebuildable, I will put oil and foam in it and check it agents the old filter with a vacuum gauge on the vacuum cleaner, it may need silicon where it use to be swaged together, I am worried how the oil barth and the foam will behave together. 6 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 22, 2022 Author Share Posted November 22, 2022 I some how zinc plated every thing, I have a phosphoric acid barth I use for cleaning copper and it use to eat steal but now the acid is a dark green and just plates steel, I put some rusty bolts in and forgot and a few hours they looked like brand new. 7 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 23, 2022 Author Share Posted November 23, 2022 That was a total waste of time, its restrictive, I jammed a hair shampoo bottle on the end of the vacuum that fitted the air filter base and punched a small hole in the side to check vacuum, believe it or not that little filter I am using at the moment has no restriction, I did make a foam filter for it a few years ago, oil barth dosnt flow enough and it did just what I thought and fill the filter with oil. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 30, 2022 Author Share Posted December 30, 2022 The oil pressure relief valve is in the front of the valve chest under the intake manafold, thought I better check it. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post SOHC Posted December 30, 2022 Author Popular Post Share Posted December 30, 2022 The spring and plunger on the left is what was in the motor, had a much stiffer spring that was about 3/8" shorter than a stock spring and it was much stiffer, I had about 40 PSI at 1000 RPM with this and 25 at idol. I got another plunger and a brand new stock spring rated to blow off at 30 PSI, now when hot at 1000 rpm I have about 27 PSI and 25 at idol. Thees motors were not designed to have over 30 PSI. 12 Quote Link to comment Share on other sites More sharing options...
