hachiroku Posted April 18, 2020 Share Posted April 18, 2020 Has anyone looked at using a KR42 Townace or SR40 Liteace Noah diff for a KE70 / AE86 swap? Axle codes A04A and A03A seem to indicate that it’s an F-series? They are 4 stud (assuming 4x114.3), no idea on width. Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted April 19, 2020 Share Posted April 19, 2020 Yes they are an F series (or interchangeable enough) The A on the end means they are open. B would indicate a torsion LSD. A03A is 4.1:1 A04A is 4.3:1 If you want LSD go flogg it out of an altezza. most of the manual 4 cylinder cars have a torsion unit in them. According to wheel side data yes the townace is 4x114.3 Quote Link to comment Share on other sites More sharing options...
hachiroku Posted April 19, 2020 Author Share Posted April 19, 2020 Perfect, thanks for confirming. Took a trip down to the wreckers today to have a look for myself. Width is right on 1500mm drum to drum, so about 90mm wider than KE70. Stud pattern is definitely 4x114.3. Might be a good option with rolled guards and suitable offset wheels, but definitely wider than ideal. 1 Quote Link to comment Share on other sites More sharing options...
