nzstato
Sams MkII Mini
Handful of jobs done this week....
Small spot of rust in the boot that needed a wee patch.
One of the previous owners had done a patch in the spare wheel well but only stich/spot welded it in, couldn't deal with it so went round the whole thing.  A new battery box has been made for it also, its ok but a tad on the rough side.  Debating if I drill the spot welds on the one out of the yellow car (its good in that area for some reason...) and repair it back to factory....
Pulled the doors, they will need some slight work arround the hinge bolts etc.
Floor pan has had a bash, needs some work.
Probably another week worth of work and then I can sand the lot back ready for paint.
Share this post
Link to post
Bit more work done.
Lower skin is complete, got to use a new set of toys
The lower part of the frame also needed a new section, made this with my folder and via clamping it to my bench with some RHS and folding it over.
The corner of this boot has been given a bit of a shunt and was full of bog, was able to pull it out a bit so it wasnt too bad, kind of difficult as you cant get to the back of the panel... welded up those extra holes too
The removable panels are now done, have a bit of work to do on the body including a patch for the tunnel.  I see a couple of other patches in this area from previous work - assume to be part of mating a honda drivetrain (which is what this was previously set up as, not sure how much more work will be needed to  return it back to std.
Share this post
Link to post
Ok so I bought just one more.... (was too cheap to pass up....)
This is best described as rust held together by paint
A lone fern had been able to propogate itself in the back seat.
It does however have the subframe in it which I need, plus a rear bumper and a handful of other parts.  The running gear might be marginally better to rebuild than the yellow one also.
A bonus was finding this 1970s accessory goodness - clip on headrest
Work on the green shell continues, time for filler and I have a kit of 2k primer ready to goIMG_4686.JPG.4dd5ae945d73bc6fa4f02eaa1160a07e.JPG
  • Like 8
Share this post
Link to post
Primer #2 is done.  Ordered some colour, hope to get the jams etc sprayed by the end of the week.  IMG_4941.thumb.JPG.5bdda40cf50a652d9692f52fb5696923.JPG
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
