Hey guys,
mrs has a ae111 with the 4age blacktop in it, it's auto as well if that changes anything.
This is the issue, car drives fine but if you turn the air con on you can get the vehicle to just die sometimes, same with any other electrical load. Doesn't always happen and when it does you can start it back up easy. I can be sitting at an intersection, idling fine, indicator on then all of a sudden engine shuts off. I barely drive the car so can't really describe it any differently.
Apparently it also dies just while sitting in traffic for a while but I can't get it to die unless I flick the air con on or off. Unsure if radiator fan kicking in causes the same issue.
where do I start? Cars only done 140ks
