kpr Posted December 24, 2017 Share Posted December 24, 2017 10.8 on 98 pump gas, easy. probably even be fine on 95. but as above depends on a lot of other things not just compression ratio. In saying that, on an na engine what you really dont want to happen is run into knock before before ignition timing is where it needs to be. else will be throwing power away 1 Quote Link to comment Share on other sites More sharing options...
