adrian Posted May 18, 2016 Share Posted May 18, 2016 hi can someone tell if i take out the hydramatic box out of my pb can i put in a 3 or 4 speed box ,,,, are the flywheels the same manual/auto only thinking of changing as hydramatic trans playing up and not much info around on it thanks adrian Quote Link to comment Share on other sites More sharing options...
nobangmycar Posted May 18, 2016 Share Posted May 18, 2016 Auto will have a flex plate and torque converter, not a flywheel. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted May 18, 2016 Share Posted May 18, 2016 hi can someone tell if i take out the hydramatic box out of my pb can i put in a 3 or 4 speed box ,,,, are the flywheels the same manual/auto only thinking of changing as hydramatic trans playing up and not much info around on it thanks adrian What do you mean when you say playing up? Is it an issue with the shift from second to third and vice versa? That's a common Hydramatic issue. Or is it something else? Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted May 19, 2016 Share Posted May 19, 2016 Is it something new with the box or has it always done it? These boxes do weird stuff if they have sat round for a while. Getting it good and hot and then driving hard has been known to sort them out. Quote Link to comment Share on other sites More sharing options...
