rob.121 Posted May 14, 2016 Share Posted May 14, 2016 Has anybody had experience with fitting rear seat belts to a car that had none from the factory? how did you go about it and is there any specifics regarding things like the backing plate size/thickness when you bolt thru the floor? Just wanting to fit some basic 3point belts. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted May 14, 2016 Share Posted May 14, 2016 What kind of car. You will need to use doubler plates and it will need a cert. http://www.lvvta.org.nz/documents/standards/LVVTA_STD_Seatbelts_&%20Seatbelt_Anchorages.pdf Quote Link to comment Share on other sites More sharing options...
