slayerbud Posted October 4, 2015 Share Posted October 4, 2015 has anyone rebuilt a type 9 5 speed gear box if so whered you get the parts? is there a gasket kit or do you have to buy them individualy Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 4, 2015 Share Posted October 4, 2015 you will be able to get parts from burton power in the uk they sell all sort of stuff like that you can also probably be a gasket and bearing kit from your local gearbox rebuilders ive done that in the past with the four speed boxes but rebuilding them is a bit tricky so i wont do it again good luck mate 1 Quote Link to comment Share on other sites More sharing options...
two_days_late Posted October 4, 2015 Share Posted October 4, 2015 If you want one quickly, Palmside have them: http://www.palmside.co.nz/product_cid_10824.html Otherwise I'd buy out of the Uk 1 Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 4, 2015 Share Posted October 4, 2015 Brought parts from the UK, was cheaper than Palmside. Think Ive seen them on Ebay nowdays. Depending on what your replacing/whats reusable it can get a bit pricey. Mine cost $550 in parts. Gaz Quote Link to comment Share on other sites More sharing options...
slayerbud Posted October 5, 2015 Author Share Posted October 5, 2015 I found this site and it has an exploded view of the gear box which makes it easy to see what parts i need. thanks all http://www.bearingkits.co.uk/FORD-GEARBOX-PARTS/FORD-TYPE-9-GEARBOX-PARTS/C1-10-4-0.htm 1 Quote Link to comment Share on other sites More sharing options...
