Yeah I'm going to see if I can find some of those small self adhesive see through rubber dot things to put on the 6 raised bits of the base
The current version has a bowl mounting plate that looks like this. I'd say it would be super easy to retrofit said plate to your existing base. And then the new style bowls would fit. They come in two sizes, but both are wider than your current one, which will be why your attachments are a bit big... You can also get a glass bowl.
Good thinking batman! I shall investigate and see what I can find
