PedRac3rs 1985 AE85 Levin
PedRac3r
So Im pretty much up to date with where the car is at right now, managed to summarize four years into a single page haha. Car has been running great with the new motor and Link G4+ Atom, could not be happier with it at this stage. Had another drift day at Meremere again in September (2014), car went well, I was struggling to get the hang of the ever changing weather, and first time back in the seat drifting with a turbo. Managed to get a couple okay runs done at the end of the day.
After looking over the car after the drift day I noticed the brace for the intake manifold had lost a bolt which caused the manifold to crack through the first runner again. Decided this time I would make a good, 3 point, triangulated brace, to really support it properly.
So intake manifold off, cleaned, weld prep’d the crack and welded inside and out, cleaned up the port with die grinder to keep the flow smooth. I also welded another tapped boss onto the first runner to use as my third point for the bracing. Last step was to set the intake manifold up in the mill and face the flange to ensure that its nice and flat for a good gasket seal.
With the intake fitted back up, it was time to make a brace.
img_1374.jpg?w=625&h=469
img_1376.jpg?w=625&h=469
Was also tired of the lack of rear brakes and handbrake its always had. Did some research on the rear calipers I was using, turns out they were early Corona stuff, with S13 rotors, quite an odd combination. I had some Nissan S15 rear calipers lying around for a while now so I figured Id put them to use, as they are much easier to source brake pads for.
Dug up the S15 Calipers, stripped them, cleaned them and a fresh coat of high temp paint (Dulux stuff, same paint I have been using on my manifold and exhaust, holds up really well). Decided to cross drill the rear rotors too, mostly because racecar, but it may serve a purpose on the track. Had to draw up and machine some new caliper mounts to suit the S15 calipers, made from 10mm mild steel plate. Project Mu pads turned up, so started to re-assemble everything so I could get some measurements for brake lines.
img_1404.jpg?w=625&h=833
img_1405.jpg?w=625&h=833
img_1402.jpg?w=625&h=833
Was really happy with how it all turned out! Although it wasnt over yet…! Quick test run on the hoist and I noticed that the calipers were moving back and forth on their slides as the wheels spun around. Brought my DTI home from work to see where the run out was coming from. Long story short, both rear axles were slightly bent (would have always been this way since Ive owned it), one had 0.3mm run out on the bearing diameter when held between centers. Managed to straighten them and get down to 0.01-0.02mm run out, then took a light skim off the hub face to ensure a true running brake rotor and wheel. Installed some new bearings while they were apart, put them back together, new brakes back on and everything was mint!
Got to test the new handbrake at Meremere again in December, it was perfect! Project Mu pads work crazy good. The rain held out. and it was a mint day at Meremere, first time I really felt comfortable in the car, and pretty stoked not to have single mechanical fault for a change!
Had to search to find this. Still here! Have been keeping busy as usual... Did a Zero Class drift day at Taupo back in March. First time I had driven there in a few years. Was a good day overall. Forgot how to drive properly in the morning, couldnt get it right. Spun a few times and collected a tyre when I ran too wide once. After all that I decided I would drive it how I should have been. Managed to burn through a few tyres, was getting pretty comfortable in the car by the end of the day.
10629506_756665917786737_330091051044020
11181788_756665984453397_550035665642034
11187347_756664967786832_293580227247214
11255790_756664887786840_307582940723904
Got some in car footage from the day too. Just a quick run:
Next time Ill give fourth a go exiting the sweeper along with some high boost engaged haha. Discussion: //oldschool.co.nz/index.php?/topic/48043-pedrac3rs-1985-ae85-levin-discussion/
  • Like 8
After Taupo, the car was still in one piece and running good. But it got a few battle scars and few other issues arose that I want to sort out. After clipping the tyre in the morning it had bent the exhaust some where, along with scratching up my freshly painted fuel tank and denting some of the panels/floor under the car. Tried to tweak the exhaust back into place at the track but it no longer sat where it used to, which caused the hot muffler to melt a wider cut out in the bumper. So new exhaust was in order.
Other thing that bugged me was the lack of suspension travel in the rear. So I pulled the springs out and start moving the diff through its travel to see whats what. From ride height to bumpstop is only 25mm. Bumpstops have been trimmed to as minimal as possible, the diff head hits the floor the same time bumpstops bottom out. A bit of a major cutting the floor out for clearance, so decided to put it back to how it was for now. Long term plan will be to equal length the rear arms and add some diff clearance into the floor. May add some coilovers to the rear in the mean time and raise it ever so slightly to get a touch more room.
The exhaust manifold had developed a few cracks also. The cause I believe is inadequate and improper bracing.  You can see on the picture below, I have 2 small braces between the collector and runner.
img_0986.jpg?w=625&h=469
They both cracked around either side of the weld. This is just and educated guess, but I think the cause for these cracking was that the runner would be heating up and expanding in one direction, and the collector heating up and expanding in the opposite direction, creating a bending force through each weld, combined with many heat cycles has caused the metal to fatigue and crack. The whole point of the braces was to reduce harmonics and vibrations to stop the collector shaking about between the runners.
So after getting the manifold off, removing those braces and repairing the cracks I needed to come up with a better idea. I decided to do this:
img_1718.jpg?w=625&h=833
I used 15x3mm flat bar and welded it like so, so when the manifold heats up and wants to expand in the direction of flow, there should be enough flex in the flat bar to allow for that, but the flat bar should have enough lateral strength to stop the collector vibrating about. Thats the plan anyway. You may also notice I welded some tabs on too. These will be to brace it back to the block, to take the load of the header flange.
Also added a wastegate flange brace too.
img_1717.jpg?w=625&h=833
I had a bent exhaust to fix now… I decided to redo the whole lot, from the down pipe flange back. I went with V-Band Flanges all around now, makes it a lot easier to remove and refit. Only problem with V-Band flanges is that they wont take a beating (or scraping) like a steel flange will, which meant I need to get the new exhaust up nice and high. So at the front it kinks to the right and up into a bit of a cavity in the floor, then maintains that height throughout the length of the exhaust, which is about 10mm below the sill.
img_1732-e1439195304362.jpg?w=625&h=689
img_1733-e1439195330671.jpg?w=625&h=671
With the exhaust up nice and high I had to work out a way to keep it up there. Because I had moved it so far up, it had become quite difficult to hang the usual way with hangars. Decided to still use the hangar bush, but like this instead.
img_1734.jpg?w=625&h=833
It allows for a sturdy exhaust mount, which wont swing around like a normal hangar, and should give good vibration dampening. I was going to try my luck using a lock nut and sandwiching the hangar, but ultimately I may need to add some crush tubes. I currently have a solid mount at the front, so I may chop that off and do the same up front, and most likely the same on the third and final rear hangar, when I decide what I should do with the rear of the exhaust.
With the brake booster gone and compact Wilwood master cylinder now mounted on the firewall with the adaptor I machined, I had a heap of space behind the strut tower to fill. Enough space I could fill it with a catch can. Made a paper prototype to check the fit and then as usual left it in the good hands of Adam at C's Garage. Hes become my regular ali welding expert lately haha, works out good though as he often needs bits and pieces machined up here and there.
img_1868.jpg?w=680
img_1878.jpg?w=680
Quality workmanship as always... Made up some -10 AN lines and it was done. Catch can crossed off the list!
Next thing which has been bugging me for a while, was the shabbiness of the front panel. Obviously been in a crash (or two) before I bought the car, and the less than average repairs were starting to show with seam sealer peeling away from rusty bare panels, cracks in the upper rad support and even in the lower crossmember where the castor arms pick up from. So I went to the extreme and rather try to repair crap, I chopped the front off decided to start from scratch with some tube instead.
Start of the top tube bent up. This is a bolt in piece. Hoping to make it so I can unbolt it and remove it with the headlights, grille, intercooler etc all attached to make engine removal and maintenance a breeze.
img_1881.jpg?w=680
Lower tube (38 x 2.6) welded in place with some gussets. Made up the castor arm bracket  mounts. Notching them was a little tricky to get a nice fit, first one took over an hour, and the second one only took 15mins to get right haha. Evidence of the damaged panels there. That will get some more hammer and dolly work before it all gets painted.
img_1883.jpg?w=680
Added some 3/4" tube to the lower tube so I could weld the lower rad mounts on. And playing with the idea of doing some small tubs with the cardboard template. They take up a bit more room, but I dont have a lot to put in that space.
img_1889.jpg?w=680
img_1894.jpg?w=680
Made up some end caps for the front tub/wings. This will add alot of strength back to those front tubs, also tidy up the front a bit also. They are just taped on atm as I need to dimple die those holes.
img_1893.jpg?w=680
Will have some more updates soon!
It has been a few weeks since an update, I was hoping to have everything done and painted by this point, but theres still a fair amount of work to do. I finished off the rear end/diff rebuild on my brothers car and got that all back together and driving, which has free'd up some space and cleared my plate so to speak. With my attention focused back on the front clip for my car, I was able to finish off a majority of it.
img_1984-e1458872518724.jpg?w=840
Got the front tub end cap panels welded on which added a lot of rigidity back to the tub section. Picked up a new intercooler from Fenix. This one is slightly larger with 500x300 core, instead of the old 380x230 core. So intercooler and oil cooler mounts were added to the front clip, along with radiator and bonnet pin mounts. Made up some headlight mounts and got those welded on. The plan was originally going to be to have the entire head light mount to the front clip, so removing the front end was easy. At this stage only the inner mount of the headlight is attached to the front clip, and the standard outer mounting bracket still attaches to the front guards.
img_1987-e1458872602577.jpg?w=840
Got the new tubs mocked up, they still need a little more trimming and tweaking here and there. Will remove the engine before I go ahead cut the factory tubs out and weld these ones in, which is pretty much where I'm up to at this stage.
