  • Replies 62
Loud pedal floor repair - now i can really mash it without fear of pushing it through the floor
Cleaned all the remaining crap off the floor and blinged it up a little
And sand, sand, sand all the engine bay paint
Booster and brake plumbing all done - I previously deleted the bias valve and replaced it with a wilwood adjustable, and upgraded the master to a bigger MA70 one
Brakes all round means the front steering and suspension is all in too
I previously disliked the wiring and relay/fuse for the electric fan
As the alternator is internally regulated now - I figured up-cycle the old regulator housing to sneak the fan gubbins in...
Next mission is to test fit the bigger W55 gearbox and apply clearance to any parts, and run a return fuel line that also clears it. Then onto checking the engine and see what needs freshening on it.
  • 6 months later...
Long time update:
Gearbox fitted, and engine dismantled for some tricks and refresh
Testing a 3D print timing gear drive for bottom end
  • 1 year later...
So... a little yarn at  @sheepers place about his motor build and also borrowing a large valve spring compressor from him inspired some work on the motor for this.
It has sat a long time and nothing was done - the gear drive became a "too hard basket" and i got put off trying to get it sorted. So it has a chain put back in there for now.
There were valve to piston clearance issues with cam timing and some light touching happened. Big end bearings are now replaced, cam lifter buckets replaced and valves checked for bentness found to be ok.
So in a "roadkill garage" style fix(found on youtube), an old stainless valve was fashioned into a rough as guts cutter and piston cutout reshaping has been done.
Result is a nice reshaping of the cutouts slightly bigger
at the same time - the engine has been blinged up to go into the nice clean engine bay
Engine mostly assembled - water pump, alternator, and flywheel/clutch still to sort. Headers might get an acid dip and repaint too.
trial of a Kameari 2T-GEU cam chain tensioner in this 18R-GEU head also happening
  • 1 year later...
:scratch: Gremlins in the ignition system have prevented it running... for now.
#1 spark plug was Doo Doo out of the box with the insulator loose once it was tightened down. Never seen this before.
MSD ignition wasnt doing what it should - seems that the voltage is dropping under 8V when cranking so this is being investigated.
