Jesse's 1983 rx60 hack
Made a start on the suspension this evening by grinding the spring perches off the spare strut casings/stub axles i have, will find some 50id steel pipe to weld on for the sleeves to seat on and buy some decent inserts and rcas.most likely will just roll the standard tophats with a locating piece tacked in
This week I purchased a gx61 that ive had my eye on for the past year, it features coil overs,f series irs,w55, some 15x8 sportmaxx eyesores and a 1ggte with a BHG my theory is that it will pay for itself being that the price I purchased it for is what decent suspension and diff setup wouldve cost me. I have a second 1ggte that will be swapped into it in the coming weeks, if its a lemon it will be removed and the rx60s 2jz will be bolted in place.
decided to get this moving again, swapped both axles and diff head for manual ratio
while i was at it tried on one of the watanabes
the width and offset is perfect for non irs so i will be stripping them and painting them shortly, was pretty sure i wanted to paint a gunmetal colour but now seeing them in black on the car i think that might suit it more
Swapped the coilovers from the gx61 into the rx60, this was a pain in the ass!
I had to swap the top hats as one of the bolts is off by about 5mm, i also had to swap the calipers as the mounts are slightly different then once that had been sorted i went to bolt the stock rims back on, also failed as they foul on the spring on the inside.
Grabbed some slipon spacers off a friend to remedy this in the short time while my watanabes were stripped and painted
awesome day at hampton for the drifjunkies vs driftkana x, here are my favourite pics pinched from a few of the photography pages.
so much fun on full track, car behaved well staying at low temperatures went for a solid 3 or 4 30minute sessions, diff has developed a clacking noise between acceleration and decceleration, have found this is due to the driveshaft having to turn half a turn before engaging wheels so on the lookout for another diff head i think!
