88fc3s. 1988 fc3s rx7
Done the gearbox mounts first. Was a easy straight forward unbolt/bolt in application.
The engine mounts on the other hand required a press so I took them into work and pressed out the old mounts. Then got the gas torch onto them to clean off the old leftover rubber then bolted the new mounts in
  • Replies 71
Got the loom all sorted. This job was massive I had a lot of help from a good mate of mine as wiring is not my strong point. The first picture is what I'm left with now and the second is the wiring that's been removed. Note this is not the engine side just the car loom for electrics etc.
So my orginal plan with the engine setup was going to be a factory new fd3s block from mazda. Then run some sweet bolt on for a nice reliable setup. But after pricing one up and talking with Warren from PPRE I ended up getting a new race block from them for a good deal! Things getting pretty serious
It's a bridge port block. 3 mm seals and doweling
Time came to really get stuck into the panel work we finished up the rear guards then ended up giving the front guards a skim along with the doors. I also brought a set of series 5 tail light, s5 front bumper and front indicators
Spent a bit of time under the bonnet removing the last few bits. Welding and bogging up some un used holes like the old heater holes then we hit the hole car with a heavy solids primer.
Oh and before we primed the car I scotched the rollcage then used a wattles etch spray can primer then we coated that with the h.s primer
So I made a lockable stand for the motor. Since it will be sitting for a wee while before she goes in
Also my old block came with a lightweight flywheel so I took it to a local business in town to give it a skim and balance it...
Then brought myself a clutch. Something not overly un drivable because it still needs to be street driven so I went for a single plate setup
As you can see from the above picture I got my father to machine up a rx7 specific clutch alignment rod
Another big spend up. This time for the turbo, bov and Wastegate.
First off was the turbo. It's a Garrett 3582r with a 1.06 rear. Some people said it might be a bit small but I'm not chasing massive power I'd rather a reponsive reliable power range
Then I went for tial for the bov and Wastegate. 50mm bov and I went for a 60mm for the Wastegate. The reason I went for 60 was that tial only make a 44 then they go up to 60. Rotarys flow a lot of exhaust so thought it'd be safer to go bigger
Enough of me typing here's some pics
So I started putting stuff back in. Pretty sweet feeling! Got a new brake master and clutch master. Had issues getting the brake master in nz so I ended up buying one from the states..only issue being for left hook. It's ok though because I was going to run new front brake lines anyway due to the tubs
Also brought a Gilmer belt drive kit!
Time to install the bc golds and the supernow toe arms and camber arm
Was a easy job to install! Noticed how badly split one of the universals on the half shafts were so I've ordered 4 new ones so I'll remove them all and re pack them
Got some paint layer down on the rear hatch and s5 front bumper! Also pushed it outside into the sun!
Love the s5 front bar over the s4 one. Plus the previous owner hacked up the old bumper to show off the awesome front mount lol so had to replace it
Started sorting out the brake department this week. Really wanted to go big on the brakes but couldn't really afford it at the moment. So I just brought some semi decent pads and heat treated slotted rotors for the front and back. Also gave the calipers some green goodness
Got myself a s5 bonnet! For free! It had a badly damaged center vent. I wanted to run the s5 because there alloy.
So I brought a 40$ vent off trade me and started making a cheap light bonnet!
Cut a big hole then glued the vent down with this custom as clamping setup
