maxted Posted March 7, 2014 Share Posted March 7, 2014 I have scored some disc brakes of a b2000 to go on the front of my b1600, just wondering if anyone else has done the same or similar, going from drum all-round to discs on front, theres not much room between original brake and clutch cylinders 80mm max so could maybe squeeze a 160mm diameter booster in. keen to hear what other people have done, cheers Quote Link to comment Share on other sites More sharing options...
1977jdm Posted March 7, 2014 Share Posted March 7, 2014 Hi if clearance is a problem use a pbr vh40 remote booster these have a bigger diaphragm which are designed for disc setup, the vh 44 which are smaller are more suited to drums I used a vh40 on my 1300 theres a bit of mucking around plumbing it in, but well worth it works a treat ! Quote Link to comment Share on other sites More sharing options...
maxted Posted March 8, 2014 Author Share Posted March 8, 2014 awesome thanks mate, just had a read up that sounds like a good solution cheers! Quote Link to comment Share on other sites More sharing options...
