unboosted brakes to boosted?
maxted
I have scored some disc brakes of a b2000 to go on the front of my b1600, just wondering if anyone else has done the same or similar, going from drum all-round to discs on front, theres not much room between original brake and clutch cylinders 80mm max so could maybe squeeze a 160mm diameter booster in.
keen to hear what other people have done, cheers
Hi if clearance is a problem use a pbr vh40 remote booster these have a bigger diaphragm which are designed for disc setup, the vh 44 which are smaller are more suited to drums
I used a vh40 on my 1300 theres a bit of mucking around plumbing it in, but well worth it works a treat !
