UP2DAT Posted December 3, 2013 Share Posted December 3, 2013 Hi Guys, I may have scored an L20et with manual box for my 260c, it was 3speed column change manual with benchy but the seat is long gone, does anyone know what’s required to make it floor shift?I’m hoping it’s as simple as making a hole in the tunnel and installing individual seats though I am being very optimistic. Cheers, Ash Quote Link to comment Share on other sites More sharing options...
Snoozin Posted December 3, 2013 Share Posted December 3, 2013 You should be ok, pull the carpet up and take a look when you get back to the car, if it's like what I found converting manual to auto, instead of having a plate spot welded on to suit the auto shifter over what normally was a manual shifter hole in the tunnel, yours will hopefully have a blanking plate spot welded in. Simply remove and voila! Hole in tunnel! Probably a good idea to remove the column shifter mech and chuck a shroud off a non column manual model on there to tidy it all up. I have one you can have for nothing if you wish. Otherwise I can't see much being a problem, you already have the clutch pedal and master in place and TBH that was the trickiest part of my conversion. Quote Link to comment Share on other sites More sharing options...
UP2DAT Posted December 3, 2013 Author Share Posted December 3, 2013 Excellent I do recall seeing that it had factory mounting points for individual front sears so surely it's got a plate like you have said, what are my options for front seats I currently have nil, cheers Quote Link to comment Share on other sites More sharing options...
