bobdylan Posted October 14, 2013 Share Posted October 14, 2013 I used to own an Ae101 and the rear lateral arms are two different types. One is adjustable and will have pillowball mounts at the ends. The other had rubber bushings. To get a cheap handling upgrade you replaced the rubber one with another pillowball one. Having just picked up an Ae82 I was woundering if anyone knew if the same trick would work with it? Quote Link to comment Share on other sites More sharing options...
bobdylan Posted October 14, 2013 Author Share Posted October 14, 2013 AE82s don't have the same style arms as the AE101s, they have pressed steel arms with eccentric bolts for toe adjustment instead of the tie-rod and bushes that the 101s have. Just found out they dont. Quote Link to comment Share on other sites More sharing options...
AE25 Posted October 14, 2013 Share Posted October 14, 2013 different length unfortunately. but can mix match ae92/ae101 rear suspension/brakes to have an upgrade. Quote Link to comment Share on other sites More sharing options...
