spangleR Posted August 1, 2013 Share Posted August 1, 2013 Will add to this as I find things that I can't work.First up is vacuum lines for the tvis, got it hooked up but think its constantly open. if someone could explain or chuck up a drawing in paint of how its meant to be would be mint. Secondly where can I get water temp from? theres a single plug and wire coming from the front of the pump but don't want to just got casually plugging it into my dash wiring. Thirdly have a mysterious plug that broke off pulling the loom out of the box after getting it stripped out and have no idea where it screws into or what it does. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 1, 2013 Share Posted August 1, 2013 How the TVIS should be hooked up. Water temp for the dash should be the temp probe with the single male spade on the thermostat housing. That plug looks like it a water temp probe for the cold start injector or the water temp sensor for the ECU 1 Quote Link to comment Share on other sites More sharing options...
spangleR Posted August 1, 2013 Author Share Posted August 1, 2013 Thanks, just solved 2/3 things. Just can't work out where that water temp probe goes, engine doesn't piss water out anywhere and where the wires sit there doesn't look to be anything where it could screw in. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 1, 2013 Share Posted August 1, 2013 Where do the wires end up? Are there any parts numbers on the probe? Quote Link to comment Share on other sites More sharing options...
spangleR Posted August 1, 2013 Author Share Posted August 1, 2013 They end up just after the thermostat/pump. Will check tomorrow for a part number. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 1, 2013 Share Posted August 1, 2013 There should be 3 senders running off the thermostat housing 2 for the ecu and the one for the dash gauge. If you only have 2 then I guessing a bolt has been put in where that sender should be Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 1, 2013 Share Posted August 1, 2013 and while we are on the subject of 1GGEU engines could you take some photos of the 24p plug on the ecu showing what colour wires go where for me? Quote Link to comment Share on other sites More sharing options...
spangleR Posted August 1, 2013 Author Share Posted August 1, 2013 Going from memory theirs 2 rectangle plugs into the thermostat and 1 single male pin coming out, will check for a bolt somewhere around that area tomorrow and grab some pictures of the ecu + plug for you. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 1, 2013 Share Posted August 1, 2013 Awesome cheers. Looking through your build thread it looks like 2 square plugs are there so its not a water one then. Maybe its for air intake temp? Finding a parts number on the probe will be the best bet, might need to give it a light sand to make it show up under all the grime and blackness Quote Link to comment Share on other sites More sharing options...
spangleR Posted August 1, 2013 Author Share Posted August 1, 2013 Just did a google pic search and does look like there is supposed to be a plug into the intake(or it could just be the positive side for the p/s pump). Might just pop the lid off the ecu and have a look. Quote Link to comment Share on other sites More sharing options...
