chriscross Posted July 13, 2013 Share Posted July 13, 2013 iv just pulled my waste gate of my rb20det, it was leaking so just a gasket. just wanting to know what port is best, witch I mean were you hook the vac hose in! there's a bottom port and top port. what's the difference? and what one do it use? its currently on the bottom port, that's how I hooked it up when installing it. any help cheers! Quote Link to comment Share on other sites More sharing options...
DJZ Posted July 13, 2013 Share Posted July 13, 2013 Are you using a boost controller? If so, what type? The top port is above the diaphragm where the bottom port is below it, applying boost pressure below the diaphragm when the top port is open will open the wastegate when it overcomes the spring pressure. Applying boost to the top port only will make the wastegate not open, also don't block the top port off when using the bottom port or the wastegate might not open. If you have an electronic boost controller you can usually use both ports, it applies boost to the top port until it reaches full boost, this keeps the wastegate shut longer, in normal operation they will tend to start opening early. I'm tired so this may not be accurate or actually make any sense at all. Quote Link to comment Share on other sites More sharing options...
chriscross Posted July 13, 2013 Author Share Posted July 13, 2013 yep I got what your saying, just running waste gate spring pressure 14 to 16 psi depends on temp, just to keep it simple. cool man ill just leave it how it is, don't want it not to open and do something nasty! cheers mate for your help! Quote Link to comment Share on other sites More sharing options...
