Steelies Posted June 26, 2013 Share Posted June 26, 2013 discussion: //oldschool.co.nz/index.php?/topic/39017-steelies-sweet-road-legal-coffin/ i nabbed this little sweety from Seedy Al's quality autos at hawkes boes mk5 never ceases to put a smile on the dial. 800cc (F8A) 4stroke 4spd unboosted drums, naturally 10" bolt together 2-piece reyums, as in you take just the rims off the drums for wheel removal composite body, 50/50 bog and rust yeah thanks Beaver for piccies Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 26, 2013 Author Share Posted June 26, 2013 4 Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 26, 2013 Author Share Posted June 26, 2013 Al replaced the head before i got it. thanks Al! /bummer. Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 26, 2013 Author Share Posted June 26, 2013 spruced up the feet and shoes. rears assembled backwards. didnt want the front hangin' out so left em the correct way haha. 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 26, 2013 Author Share Posted June 26, 2013 yay, flintstones welded it up and set the underside of the van on fire in the process. fist time i've used a fire extinguisher on a car. messy! melted some shit, including throttle and choke cables. throttle worked again after some stuffing around but ended up with no choke cable. bought generic replacement 'super long' choke cable, about 600mm too short. horied up a half-n-half fix that worked till the next thing failed - brakes. 3 Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 26, 2013 Author Share Posted June 26, 2013 next up, some of this. once it lost the ability to lock up, ie standard braking procedure, i figured something was up. by thta i mean sludge and corrosion in the master cylinder. if anyones interested it was $225 for master cyl rebuild - sleeve, seals and cleanup. and $160 for the hoses. waaa. dont ask what suzuki charge for a choke cable, but i'd had enough of my hory-fix. see above for choke failure story. next episode will involve slam. 7 Quote Link to comment Share on other sites More sharing options...
Popular Post Steelies Posted July 1, 2013 Author Popular Post Share Posted July 1, 2013 brake parts in, choke in, yay no more catching lifts to work! also put 2" blocks in rear and removed 1" from upper spring perch up front. passenger spring is juuuuust uncaptive, by about 3mm and drivers is captive. haha 14 Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 13, 2014 Author Share Posted October 13, 2014 4 Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 13, 2014 Author Share Posted October 13, 2014 this is up for grabs now, sucky. //oldschool.co.nz/index.php?/topic/45472-fs-79-suzuki-st80-carry-van-wgtn-city/ Quote Link to comment Share on other sites More sharing options...
