TA22 Daily Driver build/resto
  • Replies 78
So got the shortened Hilux diff all welded up and back in the car, forgot to take pics when it was out but you get the idea..
IMG_0923 by postlematt, on Flickr
this is it sitting 20mm off the chassis in the arse end.
IMG_0911 by postlematt, on Flickr
Rolled it out of the garage to give it a dust off and give the garage a sweep and a tidy up.
IMG_0916 by postlematt, on Flickr
IMG_0920 by postlematt, on Flickr
IMG_0914 by postlematt, on Flickr
Look at all that room for dish......
This is the 6.5's with 25mm spacers on the back.
and this is a view from back/underside
IMG_0944 by postlematt, on Flickr
and how it will look when the rear wheels are widened, when Gavin Bateman finally gets back to me.
IMG_0964 by postlematt, on Flickr
IMG_0967 by postlematt, on Flickr
Also made up some 10mm spacers for the front camber tops, just a pic to show how they looked before they went in.
IMG_0909 by postlematt, on Flickr
IMG_0910 by postlematt, on Flickr
Installed..
IMG_0949 by postlematt, on Flickr
Also mocked up the rear filler panel garnish to check clearance with the rear bumper, just waiting to here back about a possible trade of a drop tank in exchange for my factory tyre well/floor pan otherwise ill just but a 40l fuel cell then i can sort the filler positioning.
IMG_0937 by postlematt, on Flickr
IMG_0938 by postlematt, on Flickr
So basically just trying to track down some steel rhs to make up some rear strut towers.
Today was like my birthday and christmas combined..
After months of measuring and working out offsets, my wheels arrived
IMG_1051 by postlematt, on Flickr
I got the lip machined of the original rim and new outers made up for the front, and totally new inner and outer barrels for the rear.
IMG_1055 by postlematt, on Flickr
IMG_1057 by postlematt, on Flickr
IMG_1059 by postlematt, on Flickr
IMG_1056 by postlematt, on Flickr
Front are about 15x7.75 and rears are 15x8.5
Cant get onto the cnc mill to drill holes for the centres untill next week atleast so no photos of them on the car untill i can get that done..
I chose not to get them polished as they will be getting painted.
Cheers
Matt
So I couldnt help myself..
Found some handy sellotape and mocked up the wheels, sorry about the crap iphone pics and bad light, you tend to get that at 11pm.
IMG_1067 by postlematt, on Flickr
IMG_1082 by postlematt, on Flickr
IMG_1081 by postlematt, on Flickr
IMG_1065 by postlematt, on Flickr
IMG_1072 by postlematt, on Flickr
IMG_1074 by postlematt, on Flickr
  • Like 9
So ive run into at issue with the new wheel barrels and please note before you read any further Im not trying to bad mouth anyone because other than this im really happy with the product, just one of those things that happen i guess..
Anyway i went to go and get the centre bolt holes drilled into the new lips/barrels only to realise that the outer edge of the centres have been machined down in order to fit inside the new barrels, this wouldnt be such a big deal but now the bolt holes have been left with under 1mm of sidewall.
IMG_1084 by postlematt, on Flickr
this now means that the nut and bolt hangs out past the edge of the centre.
IMG_1090 by postlematt, on Flickr
Which means i cant bolt in the centre, note that there should be about 130mm of dish with the centre located and bolted in..
IMG_1085 by postlematt, on Flickr
IMG_1091 by postlematt, on Flickr
There is always the option of redrilling the centres but having paid in the region of $1500 for these i think its probably a case of getting them remade? (without sounding like a fussy cunt).
Whats are peoples opinion/possible ideas on this? (please note existing barrels, centres and nuts & bolts were sent to the workshop).
//oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-3
Once again not trying to bad mouth anyone!
But If you know of an easy fix then I'm all ears.
Cheers
Matt
Time to dig this thread up from the dead, nothings been happening.. still sorting the wheels etc.
Found a bit of motivation today.. cut out the spare tyre well to make way for the drop tank and make it easier to fabricate the new rear towers.
Got it cut out..
IMG_1169 by postlematt, on Flickr
but wouldnt it wouldnt drop.
IMG_1175 by postlematt, on Flickr
because of these suckers, this was welded to the front, the panhard rod mount bracing
IMG_1172 by postlematt, on Flickr
and this little bastard mount at the back behind the rear numberplate valance..
IMG_1180 by postlematt, on Flickr
Couldnt get a grinder in there
IMG_1181 by postlematt, on Flickr
Finally got it out
IMG_1183 by postlematt, on Flickr
Oh harro hilux diff.. i also found a 4.1 ratio diff head.. finally..
IMG_1196 by postlematt, on Flickr
Started working out the clearnces for the rear shocks. between the calipers, diff mounting brackets and chassis rails theres farrrk all room..
IMG_1192 by postlematt, on Flickr
IMG_1194 by postlematt, on Flickr
IMG_1195 by postlematt, on Flickr
Got my wheels back today, Im real stoked with them!
Big shout out to fellow OS member XSVWGN for hooking me up some volk centres at a sweet price.
Just spent 3hrs out in the garage fitting them up.. it was only -2 degrees out in the garage had to wait half an hour for my hands to thor out so i could type.. anyway pictures!
IMG_1223 by postlematt, on Flickr
IMG_1221 by postlematt, on Flickr
Already had some 195/45r15 good years for the front (left) and managed to track down some 205/45r15 toyos for the rear (right)
IMG_1226 by postlematt, on Flickr
Fitted up, ill be running some 15mm spacers up front if anyone has a pair they want to part with?
IMG_1208 by postlematt, on Flickr
IMG_1216 by postlematt, on Flickr
IMG_1219 by postlematt, on Flickr
Also found a 4.1 hilux diff, 4 spider that ill try find an lsd for but happy to run open at the moment..
IMG_1228 by postlematt, on Flickr
scored these fendor mirrors for $60 too
IMG_1230 by postlematt, on Flickr
and last but not least, new leads $1.50 tardme special, cost more to ship them then it did to buy them hah!
IMG_1232 by postlematt, on Flickr
Got into my old mans work before football this arvo and drilled the valve stem holes.
GetInline by postlematt, on Flickr
GetInline-1 by postlematt, on Flickr
Went for the stealth look and put them in the back lip of the rim, 45 degree bend with an extension.
GetInline-4 by postlematt, on Flickr
GetInline-3 by postlematt, on Flickr
GetInline-5 by postlematt, on Flickr
Celica sunday... put the fender mirrors on..
IMG_1262 by postlematt, on Flickr
IMG_1259 by postlematt, on Flickr
IMG_1263 by postlematt, on Flickr
Tyres should be going on the rims tomorrow, ill buy some 15mm hub adaptors this week and rear  strut tower fabrication will commence next weekend, can wait to have it sitting back on the ground with the coil overs all round!
Started on the 1st stage of the rear strut tower, markin shit up and cutting shit out!
Half done with grinder and half done with plasma cutter for those hard to reach spots.
IMG_1322 by postlematt, on Flickr
IMG_1311 by postlematt, on Flickr
IMG_1320 by postlematt, on Flickr
Im going to use part of the original shock towers as support/bracing then will reinforce it with some 1.6 zintec.
IMG_1341 by postlematt, on Flickr
Worked out the height the new towers will be set at
IMG_1328 by postlematt, on Flickr
IMG_1337 by postlematt, on Flickr
IMG_1335 by postlematt, on Flickr
Some of the left overs "weight reduction"
IMG_1333 by postlematt, on Flickr
stage one complete!
Cheers
Matt
  • Like 8
A pretty boring update really..
Got the tops welded onto the new rear strut tubes, still got to chuck them into the lathe and spin them down to the correct height (80mm from the floor + 20mm on the underside of the floor)
IMG_1342 by postlematt, on Flickr
Earlier in the build thread i posted a GT front grill i bought from japan, listed as a ta22 grill but was actually and ra23/28 grill (too wide) ta22 GT grills a RARE and go for about $400-700 usd.
Solution... cut down the gt ra23/28 grill to fit the ta22!
Measured up the ta22 ST grill and marked out the difference
IMG_1098 by postlematt, on Flickr
Then cut the honey comb and cut and shut the grill.
IMG_1101 by postlematt, on Flickr
IMG_1103 by postlematt, on Flickr
Cut and shut GT grill sitting next to the factory ST ta22 grill
IMG_1105 by postlematt, on Flickr
Luckily the GT grill is steel so tigged back together, Photo for reference.
Top: ST ta22 plastic grill.
Middle: cut and Shut ra23/28 GT grill.
Bottom: Ra23 LT plastic grill
IMG_1350 by postlematt, on Flickr
Also Bought a 40L drop tank.
IMG_1351 by postlematt, on Flickr
Cheers
Matt
Got some of the plates cut to shape and towers spun down to the correct size/height.
IMG_1359 by postlematt, on Flickr
IMG_1362 by postlematt, on Flickr
IMG_1363 by postlematt, on Flickr
Still mocking up and fine tuning but its not far off, hopefully get it all welded in this week/weekend
IMG_1366 by postlematt, on Flickr
IMG_1369 by postlematt, on Flickr
IMG_1368 by postlematt, on Flickr
IMG_1370 by postlematt, on Flickr
Got some adjustable diff arms from a mazda ute..
diff links by postlematt, on Flickr
solution, machine them down to fit the ta22.
IMG_1371 by postlematt, on Flickr
Football season officially finished saturday s now i have my whole weekends back to focus on the ta22 got stuck in this arvo.
Welded some plates into the told towers to locate the new towers, not pretty but its definitely not going anywhere anytime soon and itll be hidden..
IMG_1375 by postlematt, on Flickr
IMG_1376 by postlematt, on Flickr
got on a bit of a roll and it was all on!
IMG_1382 by postlematt, on Flickr
IMG_1392 by postlematt, on Flickr
IMG_1386 by postlematt, on Flickr
Theyre both in and just have to weld the front plates on for a bit more strength, it was getting dark and wasnt the best light to weld in so hopefully ill have another crack at it after work tomorrow.
IMG_1395 by postlematt, on Flickr
Got to machine up some brackets to weld on the diff now that the suspension is in place.
IMG_1398 by postlematt, on Flickr
IMG_1397 by postlematt, on Flickr
Rear shock diff mounts cnc'd and rear to weld on..
IMG_1455 by postlematt, on Flickr
IMG_1459 by postlematt, on Flickr
Welded on..
IMG_1461 by postlematt, on Flickr
IMG_1501 by postlematt, on Flickr
Also welded on the extra bracing for the towers..
IMG_1507 by postlematt, on Flickr
IMG_1505 by postlematt, on Flickr
Diff in and rolled her outside for a dust off, think i got the ride height pretty spot on 90mm all round.
Also gave me a chance to clean up the shed haha.
IMG_1487 by postlematt, on Flickr
Also plasti-dipped two of the wheels to get idea of what they look like black.. and a few too many photos of her sitting under her own weight, enjoy haha
IMG_1474 by postlematt, on Flickr
IMG_1481 by postlematt, on Flickr
IMG_1477 by postlematt, on Flickr
IMG_1485 by postlematt, on Flickr
IMG_1495 by postlematt, on Flickr
IMG_1498 by postlematt, on Flickr
IMG_1497 by postlematt, on Flickr
//oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-4
  • Like 8
Not much to update..
I got a new windscreen today, 2piece driveshaft is in the shop being shortened up and having the hilux flange welded on , new radiator and inner/outer steering ball joints are on their way from australia. I've just done another bulk buy of parts from ebay, window seals, weather strips etc etc.
I coated the inside of the sills in fish oil then folded up some sheet metal to sort out the sill caps it was a bit of a mish to weld, kept blowing through the original sheet metal. have another plate to go on the end of the sill aswell..
IMG_1593 by postlematt, on Flickr
IMG_1594 by postlematt, on Flickr
IMG_1602 by postlematt, on Flickr
IMG_1603 by postlematt, on Flickr
IMG_1599 by postlematt, on Flickr
welded up the old fuel filler on the pillar
IMG_1597 by postlematt, on Flickr
