matt_spitfire Posted November 16, 2013 Author Share Posted November 16, 2013 Finally made it to page two.. Long time no update.. Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted November 16, 2013 Author Share Posted November 16, 2013 So ive been trying to figure out if i can get all my car certed before revin, thanks to the help of other members i found out i can. Went and got a declaration of ownership and got it signed by a Justice of the Peace and talked to the gy at VTNZ he said just get it all upto standard then book it for a revin, he knows my cert guy so he'll just give him a bell to make sure its all legit. So ive bought some Apexi adjusties with spring and platform and dampner adjustment just waiting for them to turn up which should be this week if all goes to plan. ive worked out i need to shorten my dif housing 40mm each side to run the n14 rear disks and calipers, will be making up some caliper mounting brackets when the cnc's at the old mans work are free. the impul meshies will be going 9.5" bead to bead did some mocking up to work out the kind of dish ill be running, clearances etc. just flepped the centres and spaced them out. want to keep the factory guards and will be rolling the inner guard and if i ever decide to run flares etc i can just run spacers. Anyway, photos.. Uploaded with ImageShack.com Uploaded with ImageShack.com Uploaded with ImageShack.com Uploaded with ImageShack.com Uploaded with ImageShack.com Uploaded with ImageShack.com Uploaded with ImageShack.com 2 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted November 27, 2013 Author Share Posted November 27, 2013 My adjustables showed up in weekend, theyre apexi out of a dc5 integra, 3 way adjustable, sleeve, platform, dampner. rears are 295mm from pillow ball mount to top face of the top hat. fronts are totally sleeved and ill be doing a similar thing to what Brennan did in his ke70 with the max adjusties. I'll be machining up threaded sleeves and weld them onto some mx7* struts that i already have 1 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted November 30, 2013 Author Share Posted November 30, 2013 Polished up the two front rims today, they were oxidized and caked in shit. didnt bother doing the rear two as theyre due to be widened. Left rim is polished right rim is before polishing. IMG_0438 by postlematt, on Flickr IMG_0437 by postlematt, on Flickr IMG_0436 by postlematt, on Flickr both rims done.. IMG_0441 by postlematt, on Flickr IMG_0443 by postlematt, on Flickr IMG_0444 by postlematt, on Flickr hopefully get a bit of work done on the adjusties tomorrow. Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted December 5, 2013 Author Share Posted December 5, 2013 wednesday after work i sand blasted the impul mesh centres (right has been sand blasted, left hasnt. Also started on my sleeves for my coil overs but now i have to wait until next week for one of the cnc laithes to free up which is a bi frutrating was hoping to have them running. Thanks to OS GC smokin'joe i have have a mechanical dizzy and fuel pum for the 2T so i will try get the engine firing this weekend and will post a video if im successful. Untitled by postlematt, on Flickr Untitled by postlematt, on Flickr Untitled by postlematt, on Flickr Untitled by postlematt, on Flickr Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted December 7, 2013 Author Share Posted December 7, 2013 So did a bit of etch priming and painting on the two front wheels today.. IMG_0464 by postlematt, on Flickr IMG_0466 by postlematt, on Flickr Satin black.. IMG_0479 by postlematt, on Flickr IMG_0482 by postlematt, on Flickr Then reassemled two of them for the front, 40 gorilla bolts/nuts per wheel.. and will get the 195/45r15s fitted early next week. IMG_0526 by postlematt, on Flickr IMG_0528 by postlematt, on Flickr Also cut down the mx7* strut casings and mocked up one of the front coil overs, sleeves will be cnc'd next week hopefully.. IMG_0477 by postlematt, on Flickr IMG_0493 by postlematt, on Flickr Wheels mocked up on the 22 IMG_0519 by postlematt, on Flickr 7 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted December 13, 2013 Author Share Posted December 13, 2013 So idid a bit on the celica after work this week. Got my sleeves finished for the adjustables, ill let the pics do the talking.. IMG_0539 by postlematt, on Flickr Drilled holes for spot welds. IMG_0545 by postlematt, on Flickr Spot welded. IMG_0557 by postlematt, on Flickr Mocked up, going to need to run some spacers probably 15-20mm. IMG_0561 by postlematt, on Flickr IMG_0560 by postlematt, on Flickr Also spent a bit of time wiring up the dizzy.. After a bit of fucking around and trial and error i got spark but it wouldnt fire, so i set the point gaps and had another crack. and.. http://www.flickr.com/photos/110232587@N08/11348784594/ First start up vid!!! pretty happy to have it running. ignore the part where the dizzy pops out.. its a t series dizzy but not a 2tg one so i can lock it down, just had mole grips holding it and the vibrated loose. If anyone has a 2tg mechanical dizzy im keen to buy! 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted December 15, 2013 Author Share Posted December 15, 2013 Installed both adjusties on saturday cut some coils out of some spare rear springs i had lying round from the ra23 and dropped the bac end of the axel stands. Then cleaned the garage as there was tools and shit everywhere.. IMG_0573 by postlematt, on Flickr IMG_0570 by postlematt, on Flickr then today i borrowed some 25mm spacers off a mate and shoved the meshies on the front and dropped it off the axel stands, coils overs were wound down most of the way ill probly raise it another 30mm or so. IMG_0575 by postlematt, on Flickr IMG_0576 by postlematt, on Flickr Its just running the standard ta22 top hats on the adjusties at the moment, going to cnc up a new plate for the apexi camber top as its running a fair bit of positive camber as you can see from photo below.. IMG_0581 by postlematt, on Flickr Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted December 28, 2013 Author Share Posted December 28, 2013 The positive camber needed sorting so my dad the GC that he is went into his work while its closed for the xmas break to do some stuff and while he was there he machined me up some new camber plate tops. I only get stat days off work so progress is a bit slow. IMG_0626 by postlematt, on Flickr IMG_0632 by postlematt, on Flickr looks like its sorted the positive camber problem. Before.. IMG_0581 by postlematt, on Flickr After.. IMG_0635 by postlematt, on Flickr Also rolled it out the garage for the first time in a year to give it a dust off and clean the garage a bit. IMG_0643 by postlematt, on Flickr IMG_0638 by postlematt, on Flickr Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted February 17, 2014 Author Share Posted February 17, 2014 One of the members on toymods was kind enough to bring me a bumper over from Aus when she came to nelson for a holiday in january, it wasnt cheap but i couldnt find any replacements over here. had a few dents bit its pretty much rust free. I did some panel beating on it in the weekend and it came out alright. IMG_0734 by postlematt, on Flickr Also went into my old work on sunday with the old man and cnc'd up my rear caliper brackets and did a few other bits and pieces, will be modifying my camber tops tomorrow after work to allow from more -'ve camber Anyway, rear caliper brackets.. IMG_0729 by postlematt, on Flickr IMG_0719 by postlematt, on Flickr IMG_0721 by postlematt, on Flickr IMG_0723 by postlematt, on Flickr IMG_0726 by postlematt, on Flickr IMG_0725 by postlematt, on Flickr 4 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted February 18, 2014 Author Share Posted February 18, 2014 So i picked up my w50 for the Ta22 today, also bought a w50-T bell housing a while back, missing a cluch fork and thrust bearing if anyone has spares of these then im keen to buy! IMG_0737 by postlematt, on Flickr IMG_0739 by postlematt, on Flickr This also showed up today from ebay japan.. IMG_0741 by postlematt, on Flickr a GT front grill. It was listed as a TA22 grill but its actually a Ra23/28 grill. IMG_0743 by postlematt, on Flickr Im going to see if i can find someone who wants to swap for a ta22 grill otherwise ill keep it for the Ra23. In other news, i milled out the camber plates after work to give me more adjustment. IMG_0750 by postlematt, on Flickr basicly im going to relocate it 180 degrees which means drilling new holes in the strut tower.. So made up this plate. IMG_0752 by postlematt, on Flickr Bolted up to redrill holes.. IMG_0757 by postlematt, on Flickr camber tops bolted in, will have to do a bit of cutting/slotting IMG_0761 by postlematt, on Flickr IMG_0760 by postlematt, on Flickr Dropped it off the jack and presto! Finally.. Negative camber! IMG_0759 by postlematt, on Flickr IMG_0763 by postlematt, on Flickr Cheers! Project dicussion here: http://oldschool.co....ver-buildresto/ Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 1, 2014 Author Share Posted March 1, 2014 Fitted up my new front bumper and test fitted the rear caliper brackets today. Untitled by postlematt, on Flickr Untitled by postlematt, on Flickr Untitled by postlematt, on Flickr Also spent most of the day working out rim sizes and hopefully i will get it all finalised tomorrow. looking to get new lips for the front to take them from 6.5" to 8" which should give me between 2-2.5" of dish on the front. The rears will be going to 8.5" so i can run a legal size tyre for cert and will also allow the rim and tyre to tuck up inside the guard without having to smash the guards out. They'll be getting new inner barrels and outer lips and have an offset well into the negatives, the diff will be shortened roughly 50-55mm a side. and the rear rims should have roughly 115mm of dish about 4.5" Photos to follow tomorrow.. Cheers Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 9, 2014 Author Share Posted March 9, 2014 Not a lot has been happening waiting on some parts to arrive so just been playing around with wheel fitment once again.. decided to ditch the 9.5" rear rims idea at this stage as theres no specified tyre that a can get certed on with a 9.5 so settled on a 7.5" fronts (new outer lips with existing rear barrel should drop the offset to around 15 and 195/45 tyres). 8.5" rears (new outer lips and inner barrels about -35 offset 130mm~ish of dish, 225/45 tyres) tyres and rims will tuck no problems and can always go wider at a later date. IMG_0837 by postlematt, on Flickr and just cause i got bored.. flipped centres and painted black barrel as i wont be using these barrels 100mm of dish so there will be more with new barrels.. IMG_0857 by postlematt, on Flickr IMG_0852 by postlematt, on Flickr 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 11, 2014 Author Share Posted March 11, 2014 Look what showed up today.. Shortened hilux diff housing and axles 1260mm hub to hub so i can run my low offset rims without ruining the factory lines of the rear guards. Also looking for a 4.1 diff head open or lsd hit me up if you have one going cheap! IMG_0869 by postlematt, on Flickr And also this, it wa sititng in customs for over a week while they sorted theyre shit out. they had classed it as commercial goods as it was addressed to me at my work so i had to do some chasing up and convince them it was personal goods.. Can you guess whats inside? IMG_0872 by postlematt, on Flickr How about now? IMG_0873 by postlematt, on Flickr 71' Flat tail lights with fold down fuel filler centre garnish! IMG_0875 by postlematt, on Flickr These things are pretty hard to get a hold of, they only came out on the 1st year of production 71' and early 72' models, doesnt help that these cars werent sold in NZ and i was told the first shipment of the 71 celicas to Aus never made it, the cargo ship capsized or something along those lines and all the cars were water damaged and written off. Theyre from L.A. and werent cheap but will allow me to get rid of the fuel tank beind the rear seats so i can modify my rear strut towers to fit the rear coil overs and ditch the spare tyre well and run a drop tank plus i can delete the fuel filler on the rear passenger pillar.. On another note is anyone in the Auckland city area able to pick up 2 tyres for me and drop them off to a shipping depot, they're on trade me and the auction finishes this thursday (pick up only). Payment will be made in order for you to purchase beers to replenish your thirst after a job well done. Let me know if you can help. Cheers Matt 1 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 17, 2014 Author Share Posted March 17, 2014 Had a go at fitting the new tail lights over the weekend, centre garnish doesnt fit flush because of the hinges used, this will be sorted once ive bought another drop tank. IMG_0882 by postlematt, on Flickr IMG_0885 by postlematt, on Flickr In the mean time i started cutting the diff link mounts off the ta22 diff to fit to the new shortened hilux housing. has to use a plasma cutter as i cound get the angle grinder in there Mounts cut off IMG_0888 by postlematt, on Flickr Should give some idea hilux housing is about 100mm norrower than the stock ta22 housing IMG_0897 by postlematt, on Flickr lower mounts sit quite far outboard IMG_0891 by postlematt, on Flickr Had to make a spacer up because of the step between the bears housing and axel housing IMG_0907 by postlematt, on Flickr IMG_0906 by postlematt, on Flickr I got the lower mounts properly welded on after test fitting then spot welded the top mounts and test fitted the diff again. i was getting some real shit welds checked the gas was on and feed was all good, it was at this point one the spot welds holding one of the top mounts failed and i then realised id run out of gas.. So no more welding untill i can get more gas which sucks, i would have had it in the car had it not been for that. should give me something to do next weekend though.. 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 This Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 page Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 Takes Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 too long Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 to Quote Link to comment Share on other sites More sharing options...
