matt_spitfire Posted October 1, 2014 Author Share Posted October 1, 2014 More parts arrived today, some old some new.. New alloy radiator and inner/outer steering ball joints arrived from Aus, got them sent to my mate in Vic and she sent them on to me along with a set of bonnet hinges and bonnet stay. IMG_1609 by postlematt, on Flickr Also a twin side draft throttle linkage set up and some used uni filters that ill give a clean up, linkage was made for dellortos but should be pretty straight forward to make them fit my Mikuni Solex. IMG_1592 by postlematt, on Flickr Radiator has a couple of bent fins from shipping but checked it and holds water sweet. IMG_1613 by postlematt, on Flickr IMG_1612 by postlematt, on Flickr 1 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted October 8, 2014 Author Share Posted October 8, 2014 New drive shaft shortened and balanced, still waiting on parts from over seas.. Welded in the new panhard rod bracket today got to cut down the old panhard rod and re-sleeve it to fit a rose joint to make it adjustable then weld the new mount onto the diff. Does anyone know where i can get a rose joint that is sweet for cert? regular ones dont meet the lvvta standards apparently. IMG_1694 by postlematt, on Flickr //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-4 1 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted October 21, 2014 Author Share Posted October 21, 2014 Small update, bought a vw golf front chin spoiler from the uk and trimmed it up to fit the TA.. IMG_1701 by postlematt, on Flickr Had to mock it up multiple times to get it sitting right, plenty of trimming but the fact is plastic made it pretty east to cut and file etc.. IMG_1704 by postlematt, on Flickr IMG_1722 by postlematt, on Flickr IMG_1720 by postlematt, on Flickr got my dad to cnc up some new rear caliper brackets, a lot easier to machine up to suit the hilux diff compared to the original t series ta22 diff! IMG_1730 by postlematt, on Flickr IMG_1735 by postlematt, on Flickr IMG_1738 by postlematt, on Flickr IMG_1740 by postlematt, on Flickr //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-4 8 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted October 23, 2014 Author Share Posted October 23, 2014 Has anyone converted a diff to disc brake in a car that was originally running drums? Just curious about how i should go about plumbing it up? Ive gone a got the pajero master cylinder which is a common upgrade for a ta22 running discs but can i get away with just fitting an adjustable brake bias valve and adjust the rear brakes accordingly? //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-4 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted October 24, 2014 Author Share Posted October 24, 2014 This arrived at work today.. IMG_1748 by postlematt, on Flickr Parts from overseas from my good friend on ebay! IMG_1750 by postlematt, on Flickr IMG_1756 by postlematt, on Flickr gota love genuine NOS toyota parts.. IMG_1755 by postlematt, on Flickr these clips go on under the front n rear window rubbers to hold the window chrome, little bastards cost $3.50usd each! theres 40 of the fuckers.. IMG_1753 by postlematt, on Flickr basically theres all new window, door, boot rubbers along with the rear quarter window rubbers that run vertically up the edge of the glass because pillarless (genuine toyota NOS) also front bonnet rubber and stops, headlight globes & halogen bulbs, clear indicator lenses, new ball joints, voltage regulator, interior light door triggers, toyota wiper blades, new window winder handles (chrome not plastic), window chrome clips and those sweet celica scroll badges! Im still waiting on my weather strips front the doors and rear quarter, they're in transit at the moment. Also sandblasted my headlight brackets along with the front filler panels and bonnet vent plates, will etch prime paint and reassemble over the long w.e. IMG_1759 by postlematt, on Flickr Cheers Matt 2 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted November 10, 2014 Author Share Posted November 10, 2014 Got sick of looking at the rough engine bay so ripped the motor out as i had to change the tail housing on the w55 as the bearing was poked. IMG_1760 by postlematt, on Flickr IMG_1762 by postlematt, on Flickr took everything out for a clean IMG_1763 by postlematt, on Flickr then got a bit carried away.. IMG_1770 by postlematt, on Flickr 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted November 10, 2014 Author Share Posted November 10, 2014 Me and a mate (sparkie) got stuck in to some of the body work, main priority was the where the new sills meet the rear quarters in front of the rear guards and also the rear quarters theres still a bit to go and and might have another crack at the roof and give it a skim bog.. IMG_1795 by postlematt, on Flickr IMG_1796 by postlematt, on Flickr also got the doors stripped rear for some new sheet metal to be welded into the rusted areas, theres a few spots but theyre not as bad as i weas expecting which is a bit of a bonus divers door.. IMG_1821 by postlematt, on Flickr rust on the top edge (front) and where the chrome strip runs and also where a wing mirror was once mounted IMG_1825 by postlematt, on Flickr same door back edge where chrome stip was mounted above the door handle IMG_1826 by postlematt, on Flickr lower drivers door 3 small patches of rust IMG_1828 by postlematt, on Flickr IMG_1827 by postlematt, on Flickr passenger door IMG_1823 by postlematt, on Flickr 1 bit of rust in back corner where chrome strip sits IMG_1824 by postlematt, on Flickr 2 Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted November 10, 2014 Author Popular Post Share Posted November 10, 2014 so this is what $800 worth of paint, primer, thinners, clear, clear flattener, underseal and under seal gun looks like.. IMG_1807 by postlematt, on Flickr IMG_1817 by postlematt, on Flickr IMG_1818 by postlematt, on Flickr Sneak peak.. Mazda sunlight silver 22v IMG_1813 by postlematt, on Flickr 12 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted December 29, 2014 Author Share Posted December 29, 2014 Been a while, still slowly chipping away at this thing, trying to sort out new paelss for the front end from japan, i only get stat days off work so havnt been able to get as much done as i would have liked but thems the breaks.. in the mean time i got the adjustable panhard rod done and mounted (i recommend getting your teflon coated rose joints off ebay.co.uk, i got mine for about $13.50 nzd shipped, took less than a week to arrive). IMG_2025 by postlematt, on Flickr IMG_1832 by postlematt, on Flickr IMG_1841 by postlematt, on Flickr i got the inside of the door glass blasted and then i gave my doors to a mate to weld new steel in, got one of them back, the other one is still getting work done. IMG_2048 by postlematt, on Flickr IMG_2051 by postlematt, on Flickr IMG_2052 by postlematt, on Flickr Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted December 29, 2014 Author Popular Post Share Posted December 29, 2014 I had to notch the radiator support panel slightly to get some clearance between the radiator and underside of the bonnet. IMG_2044 by postlematt, on Flickr fitted the NOS celica badge to the rear filler panel and blacked it out along with the tail light sarrounds. IMG_2034 by postlematt, on Flickr IMG_2039 by postlematt, on Flickr also resprayed the under seal and primed the engine bay. IMG_2068 by postlematt, on Flickr figured i do a test spray with the new paint. IMG_2073 by postlematt, on Flickr dont think it turned out too bad at all, exactly the colour i was hoping for! IMG_2092 by postlematt, on Flickr 25 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 2, 2015 Author Share Posted March 2, 2015 Ive been lazy with updates and pretty slack at taking photos so will try get upto speed with this build thread.. pulled the diff back out and gave it a clean, new gaskets etc thena paint and reassemble. IMG_2186 by postlematt, on Flickr Welded in cross bars for the drop tank. IMG_2115 by postlematt, on Flickr stared mocking up the rear filler between the tail lights. IMG_2122 by postlematt, on Flickr IMG_2118 by postlematt, on Flickr IMG_2117 by postlematt, on Flickr bent up some steel IMG_2159 by postlematt, on Flickr Fitted end caps IMG_2164 by postlematt, on Flickr in the process of making up a filler neck that bolts inplace of the filler cap on the tank, also go to install the toll over valve and get some an fittings for the tank IMG_2167 by postlematt, on Flickr bend up some brackets and test fitted the hinged cover. IMG_2279 by postlematt, on Flickr 2 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 2, 2015 Author Share Posted March 2, 2015 Theres a lot of minor thiings i didnt take photos of, blasting bits and pieces painting them up etc, these are just what i remimbered to take pics of haha. cleaned up the interior floor and gave it a paint IMG_2181 by postlematt, on Flickr IMG_2201 by postlematt, on Flickr IMG_2197 by postlematt, on Flickr Started fitting the front end and enginebay accessories, big thanks to Mike (sleeektoy) for the passenger side headlight bucket and filler panel. IMG_2173 by postlematt, on Flickr Panel beated the roof IMG_2103 by postlematt, on Flickr Made up this badboy for the throttle linakge/cable IMG_2183 by postlematt, on Flickr IMG_2160 by postlematt, on Flickr 1 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 2, 2015 Author Share Posted March 2, 2015 Dropped the motor back in finally.. degreased and painted up the block while it was out IMG_2209 by postlematt, on Flickr IMG_2208 by postlematt, on Flickr IMG_2210 by postlematt, on Flickr I bought a factory ta22 t50 cross member off Mike (sleektoy) as it has a radius in one side for the exhaust to run under, as my extractors sit so close to the floor this is going to be handy to tuck the exhaust up as high as possible for ground clearnce but im running a w55 which mounts further back and fouls on the cross member.. solution.. cut it to pieces and make it work.. IMG_2284 by postlematt, on Flickr IMG_2287 by postlematt, on Flickr IMG_2294 by postlematt, on Flickr IMG_2299 by postlematt, on Flickr IMG_2302 by postlematt, on Flickr //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-4 4 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted June 2, 2015 Author Share Posted June 2, 2015 Long time no update, ive still been working on the car here and there, lost motivation for a bit while i was waiting on parts, got shit loads of photos so ill have to look through them to find the ones that look like ive achieved something haha.. Anyway tank filler needed sorting, i bought a flexi fuel hose, filler neck and roll over valve from the uk, got here in under a week. then worked out the angles. IMG_2291 by matt postle, on Flickr got a 90 degree stainless bend along with a bit of 6mm stainless plate and cnc'd it to suit the old fuel filler. IMG_2349 by matt postle, on Flickr took the photo before it was bolted down as i still had to drill the hole in the tank for the toll over valve. Also baught some an fittings for the tank, block off caps along with an an10-an6 fitting so i can run braided hose to the fuel pump. The fuel level sender was also reading backwards to it was saying empty when it should have been reading full and vice versa, i switch the wiring between positive and earth but didnt make a difference so in the end i rotated the sender 180 degrees then bend the bit of stainless wire that hold the float and that worked a treat. IMG_2442 by matt postle, on Flickr Next up i noticed that the diff head had bugger all cleance with the tunnel at the back where the rear seat is fitted (about 20mm) so i cut a hole.. IMG_2308 by matt postle, on Flickr IMG_2326 by matt postle, on Flickr IMG_2309 by matt postle, on Flickr then realised i probably would pass cert with a hole where the back seat should be so i bent up a bit of steel, was a bit of a mission as i only had a vice, angle grinder and hammer.. IMG_2330 by matt postle, on Flickr IMG_2335 by matt postle, on Flickr bent it up to fit.. IMG_2359 by matt postle, on Flickr IMG_2357 by matt postle, on Flickr spot welded it into position then borrowed an oxy acetyline torch to warm it up and gammer it around the contours of the existing floor pane/tunnel IMG_2428 by matt postle, on Flickr IMG_2424 by matt postle, on Flickr etch primed and under sealed.. good as new! well nearly, its not pretty but the seat and diff head/drive shaft will hide most of it.. IMG_2450 by matt postle, on Flickr IMG_2443 by matt postle, on Flickr ive also spent alot of time checking out the wiring etc, had to rewire the tail lights from scratch to suit the pre facelift flat tail lights, i also had a real mission trying to find the plug for the reverse lights.. checked all the plugs and wiring under the dash etc, ended up hooking a battery unto the reverse light wiring at the tail lights and tried to trace it with a volt metre, it turned out the plug was in the engine bay hidden right under the brake booster where the engine loom comes out the firewall.. anyway my tail light wiring came up sweet! Reverse lights by matt postle, on Flickr Ill have to upload some more photos and get onto some more updates tomorrow. Cheers Matt //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-5 8 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted June 3, 2015 Author Share Posted June 3, 2015 So here are some photos of the restored.jp frp panels as requested by Kyteler who was also a real good sort for putting me onto Ewan at stacked. Pretty happy with the build quality only a couple of minor imperfections and a small amount of damage on the the front drivers side corner of the bonnet which is to be expected when shipping something of this size from japan to nelson. Anyway photos!! (taken the night i got the panels so will get some better photos in the day light). IMG_2542 by matt postle, on Flickr IMG_2545 by matt postle, on Flickr IMG_2553 by matt postle, on Flickr IMG_2560 by matt postle, on Flickr 7 Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted June 4, 2015 Author Popular Post Share Posted June 4, 2015 more updates from the last month or so in no particular order.. sent the doors to creative colours in nelson to be professionally panel beated, i didnt really want to do them myself as they're such a big panel it would have taken me days to do and i never would have been happy with them, top job done by these guys though! IMG_2307 by matt postle, on Flickr Genuine toyota rear quarter window rubbers IMG_2527 by matt postle, on Flickr Few other parts off ebay.. washer bottle. ta22 radiator hoses easier than trying to make something else fit! ta27 side indicators (these wont fit without modding the new restored.jp guards so might just run the ta22 ones for now). speedo cable (doesnt fit so will roll with the old one this suits a ke20 so it says so if anyones after a new one hit me up! rear numberplate lights that sit behind the rear bumper. also not pictured is the new drive shaft centre bearing IMG_2525 by matt postle, on Flickr new drive shaft centre bearing fitted IMG_2524 by matt postle, on Flickr reconditioned brake callipers my mates brother works at a brake specialist place so got him to rebuild them for a sweet price! IMG_2580 by matt postle, on Flickr gave the front discs a skim, also put new wheel bearings and seals up front, rear bearings and seals in the hilux diff were new and replaced by the guy i bought it off so didnt need to do these. IMG_2596 by matt postle, on Flickr front sway bar was sand blasted and painted, now back in with new bushes etc. IMG_2581 by matt postle, on Flickr Went and saw Ben aka Maxted here on the OS forums, supplied him with some exhaust tubing and templates and being the GC he is he bent it up for me, Cheers man! IMG_2573 by matt postle, on Flickr mocked up under the car. IMG_2576 by matt postle, on Flickr IMG_2575 by matt postle, on Flickr took the vw front lip i modded to a plastic welder to get welded up in the centre, added heaps of strength just needs a bit of a file to tidy it up.. IMG_2586 by matt postle, on Flickr IMG_2587 by matt postle, on Flickr not a good photo but sand blasted the bonnet hinges, bonnet latch, and a few other bits and gave them a prime and paint IMG_2585 by matt postle, on Flickr Majority of the wiring is done now and fuel lines run, just need to wire the fuel pump up! IMG_2583 by matt postle, on Flickr built up some courage and drilled holes in the new front guard to fin the fendor mirrors IMG_2590 by matt postle, on Flickr Cheers Matt 10 Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted February 9, 2016 Author Popular Post Share Posted February 9, 2016 Because im lazy.. and havnt made any updates in 8 months or so.. its close but still got a bit left to do. ill fill in the blanks when i get time.. image by matt postle, on Flickr image[1] by matt postle, on Flickr image[2] by matt postle, on Flickr image[4] by matt postle, on Flickr image[3] by matt postle, on Flickr image[5] by matt postle, on Flickr 23 Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted August 1, 2016 Author Popular Post Share Posted August 1, 2016 Sorry.. its been a while.. over i year i think.. the car is still alive and in my possession, it drives and stops etc but no cert yet as i keep changing my mind, hopefully she'll be back on the road this summer. Pic for bump reasons.. spot the difference photo by matt postle, on Flickr On another note, can anyone point me in the right direction for rear louvre clips auger or similar??? 11 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted September 11, 2016 Author Share Posted September 11, 2016 flikr wont let me upload images to forums now can anyone give me a good recommendation for an app i can use to upload and code images for a forum? cheers Quote Link to comment Share on other sites More sharing options...
