matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 Load Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 So got the shortened Hilux diff all welded up and back in the car, forgot to take pics when it was out but you get the idea.. IMG_0923 by postlematt, on Flickr this is it sitting 20mm off the chassis in the arse end. IMG_0911 by postlematt, on Flickr Rolled it out of the garage to give it a dust off and give the garage a sweep and a tidy up. IMG_0916 by postlematt, on Flickr IMG_0920 by postlematt, on Flickr IMG_0914 by postlematt, on Flickr Look at all that room for dish...... This is the 6.5's with 25mm spacers on the back. and this is a view from back/underside IMG_0944 by postlematt, on Flickr and how it will look when the rear wheels are widened, when Gavin Bateman finally gets back to me. IMG_0964 by postlematt, on Flickr IMG_0967 by postlematt, on Flickr Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted March 24, 2014 Author Share Posted March 24, 2014 Also made up some 10mm spacers for the front camber tops, just a pic to show how they looked before they went in. IMG_0909 by postlematt, on Flickr IMG_0910 by postlematt, on Flickr Installed.. IMG_0949 by postlematt, on Flickr Also mocked up the rear filler panel garnish to check clearance with the rear bumper, just waiting to here back about a possible trade of a drop tank in exchange for my factory tyre well/floor pan otherwise ill just but a 40l fuel cell then i can sort the filler positioning. IMG_0937 by postlematt, on Flickr IMG_0938 by postlematt, on Flickr So basically just trying to track down some steel rhs to make up some rear strut towers. Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted May 14, 2014 Author Share Posted May 14, 2014 Today was like my birthday and christmas combined.. After months of measuring and working out offsets, my wheels arrived IMG_1051 by postlematt, on Flickr I got the lip machined of the original rim and new outers made up for the front, and totally new inner and outer barrels for the rear. IMG_1055 by postlematt, on Flickr IMG_1057 by postlematt, on Flickr IMG_1059 by postlematt, on Flickr IMG_1056 by postlematt, on Flickr Front are about 15x7.75 and rears are 15x8.5 Cant get onto the cnc mill to drill holes for the centres untill next week atleast so no photos of them on the car untill i can get that done.. I chose not to get them polished as they will be getting painted. Cheers Matt 5 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted May 14, 2014 Author Share Posted May 14, 2014 So I couldnt help myself..Found some handy sellotape and mocked up the wheels, sorry about the crap iphone pics and bad light, you tend to get that at 11pm.IMG_1062 by postlematt, on FlickrIMG_1067 by postlematt, on FlickrIMG_1082 by postlematt, on FlickrIMG_1081 by postlematt, on FlickrIMG_1065 by postlematt, on FlickrIMG_1072 by postlematt, on FlickrIMG_1074 by postlematt, on Flickr 9 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted May 17, 2014 Author Share Posted May 17, 2014 So ive run into at issue with the new wheel barrels and please note before you read any further Im not trying to bad mouth anyone because other than this im really happy with the product, just one of those things that happen i guess.. Anyway i went to go and get the centre bolt holes drilled into the new lips/barrels only to realise that the outer edge of the centres have been machined down in order to fit inside the new barrels, this wouldnt be such a big deal but now the bolt holes have been left with under 1mm of sidewall. IMG_1084 by postlematt, on Flickr this now means that the nut and bolt hangs out past the edge of the centre. IMG_1090 by postlematt, on Flickr Which means i cant bolt in the centre, note that there should be about 130mm of dish with the centre located and bolted in.. IMG_1085 by postlematt, on Flickr IMG_1091 by postlematt, on Flickr There is always the option of redrilling the centres but having paid in the region of $1500 for these i think its probably a case of getting them remade? (without sounding like a fussy cunt). Whats are peoples opinion/possible ideas on this? (please note existing barrels, centres and nuts & bolts were sent to the workshop). //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-3 Once again not trying to bad mouth anyone! But If you know of an easy fix then I'm all ears. Cheers Matt Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted July 13, 2014 Author Share Posted July 13, 2014 Time to dig this thread up from the dead, nothings been happening.. still sorting the wheels etc. Found a bit of motivation today.. cut out the spare tyre well to make way for the drop tank and make it easier to fabricate the new rear towers. Got it cut out.. IMG_1169 by postlematt, on Flickr but wouldnt it wouldnt drop. IMG_1175 by postlematt, on Flickr because of these suckers, this was welded to the front, the panhard rod mount bracing IMG_1172 by postlematt, on Flickr and this little bastard mount at the back behind the rear numberplate valance.. IMG_1180 by postlematt, on Flickr Couldnt get a grinder in there IMG_1181 by postlematt, on Flickr Finally got it out IMG_1183 by postlematt, on Flickr Oh harro hilux diff.. i also found a 4.1 ratio diff head.. finally.. IMG_1196 by postlematt, on Flickr Started working out the clearnces for the rear shocks. between the calipers, diff mounting brackets and chassis rails theres farrrk all room.. IMG_1192 by postlematt, on Flickr IMG_1194 by postlematt, on Flickr IMG_1195 by postlematt, on Flickr 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted July 22, 2014 Author Share Posted July 22, 2014 Got my wheels back today, Im real stoked with them! Big shout out to fellow OS member XSVWGN for hooking me up some volk centres at a sweet price. Just spent 3hrs out in the garage fitting them up.. it was only -2 degrees out in the garage had to wait half an hour for my hands to thor out so i could type.. anyway pictures! IMG_1223 by postlematt, on Flickr IMG_1221 by postlematt, on Flickr Already had some 195/45r15 good years for the front (left) and managed to track down some 205/45r15 toyos for the rear (right) IMG_1226 by postlematt, on Flickr Fitted up, ill be running some 15mm spacers up front if anyone has a pair they want to part with? IMG_1208 by postlematt, on Flickr IMG_1216 by postlematt, on Flickr IMG_1219 by postlematt, on Flickr 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted July 22, 2014 Author Share Posted July 22, 2014 Also found a 4.1 hilux diff, 4 spider that ill try find an lsd for but happy to run open at the moment.. IMG_1228 by postlematt, on Flickr scored these fendor mirrors for $60 too IMG_1230 by postlematt, on Flickr and last but not least, new leads $1.50 tardme special, cost more to ship them then it did to buy them hah! IMG_1232 by postlematt, on Flickr 1 Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted July 24, 2014 Author Popular Post Share Posted July 24, 2014 My Birthday present from myself to myself showed up today.. IMG_1237 by postlematt, on Flickr Got a bunch of stuff off ebay, did a bulk buy and the seller was good enough to combine shipping rather than charging me crazy shipping costs. he sent them as a "gift" and although the combined cost including shipping was probably slightly ove the threshold he put the value on the box at $97 and also put a birthday card in the box incase customs got nosy.. but like i said its a birthday present from myself to myself.. IMG_1238 by postlematt, on Flickr The card cracked me up, the guy seems like a genuine GC haha IMG_1239 by postlematt, on Flickr its mainly small mechanical parts, bushes and a few other bits and pieces IMG_1246 by postlematt, on Flickr ill do another big buy an a month or two and get all my rubber seals, weather strips, badges and other stuff that will go on after panel and paint.. he sells a lot of old toyota reproduction parts so if anyone wants to check out his ebay store and make purchase when i do to save on shipping then give me a PM and can sus something out. Cheers 14 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted July 26, 2014 Author Share Posted July 26, 2014 Got into my old mans work before football this arvo and drilled the valve stem holes. GetInline by postlematt, on Flickr GetInline-1 by postlematt, on Flickr Went for the stealth look and put them in the back lip of the rim, 45 degree bend with an extension. GetInline-4 by postlematt, on Flickr GetInline-3 by postlematt, on Flickr GetInline-5 by postlematt, on Flickr 6 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted July 27, 2014 Author Share Posted July 27, 2014 Celica sunday... put the fender mirrors on.. IMG_1262 by postlematt, on Flickr IMG_1259 by postlematt, on Flickr IMG_1256 by postlematt, on FlickrIMG_1263 by postlematt, on Flickr Tyres should be going on the rims tomorrow, ill buy some 15mm hub adaptors this week and rear strut tower fabrication will commence next weekend, can wait to have it sitting back on the ground with the coil overs all round! 2 Quote Link to comment Share on other sites More sharing options...
Popular Post matt_spitfire Posted July 28, 2014 Author Popular Post Share Posted July 28, 2014 So tyres fitted today, forgot to take any photos of them before i chucked them on the car, was too chuck them on the ta.. ill get some of the stretch etc next time theyre off. Anyway, photos.. hope you enjoy seeing it finally sitting on the rims half as much as i do haha. IMG_1279 by postlematt, on Flickr IMG_1266 by postlematt, on Flickr IMG_1265 by postlematt, on FlickrIMG_1281 by postlematt, on Flickr IMG_1273 by postlematt, on Flickr IMG_1276 by postlematt, on Flickr IMG_1270 by postlematt, on Flickr Currently running no discs on the back at the moment so that will push the rears out atleast another 10mm, front are spaced 10mm, will probly space them another 5mm for cert thn maybe got 20-25mm. Discussion here: //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-3 Cheers Matt 10 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted August 6, 2014 Author Share Posted August 6, 2014 Started on the 1st stage of the rear strut tower, markin shit up and cutting shit out! Half done with grinder and half done with plasma cutter for those hard to reach spots. IMG_1322 by postlematt, on Flickr IMG_1311 by postlematt, on Flickr IMG_1320 by postlematt, on Flickr Im going to use part of the original shock towers as support/bracing then will reinforce it with some 1.6 zintec. IMG_1341 by postlematt, on Flickr Worked out the height the new towers will be set at IMG_1328 by postlematt, on Flickr IMG_1337 by postlematt, on Flickr IMG_1335 by postlematt, on Flickr Some of the left overs "weight reduction" IMG_1333 by postlematt, on Flickr stage one complete! Cheers Matt 8 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted August 12, 2014 Author Share Posted August 12, 2014 A pretty boring update really.. Got the tops welded onto the new rear strut tubes, still got to chuck them into the lathe and spin them down to the correct height (80mm from the floor + 20mm on the underside of the floor) IMG_1342 by postlematt, on Flickr Earlier in the build thread i posted a GT front grill i bought from japan, listed as a ta22 grill but was actually and ra23/28 grill (too wide) ta22 GT grills a RARE and go for about $400-700 usd. Solution... cut down the gt ra23/28 grill to fit the ta22! Measured up the ta22 ST grill and marked out the difference IMG_1098 by postlematt, on Flickr Then cut the honey comb and cut and shut the grill. IMG_1101 by postlematt, on Flickr IMG_1103 by postlematt, on Flickr Cut and shut GT grill sitting next to the factory ST ta22 grill IMG_1105 by postlematt, on Flickr Luckily the GT grill is steel so tigged back together, Photo for reference. Top: ST ta22 plastic grill. Middle: cut and Shut ra23/28 GT grill. Bottom: Ra23 LT plastic grill IMG_1350 by postlematt, on Flickr Also Bought a 40L drop tank. IMG_1351 by postlematt, on Flickr //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-3 Cheers Matt 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted August 19, 2014 Author Share Posted August 19, 2014 Got some of the plates cut to shape and towers spun down to the correct size/height. IMG_1359 by postlematt, on Flickr IMG_1362 by postlematt, on Flickr IMG_1363 by postlematt, on Flickr Still mocking up and fine tuning but its not far off, hopefully get it all welded in this week/weekend IMG_1366 by postlematt, on Flickr IMG_1369 by postlematt, on Flickr IMG_1368 by postlematt, on Flickr IMG_1370 by postlematt, on Flickr 2 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted August 31, 2014 Author Share Posted August 31, 2014 Got some adjustable diff arms from a mazda ute.. diff links by postlematt, on Flickr solution, machine them down to fit the ta22. IMG_1371 by postlematt, on Flickr Football season officially finished saturday s now i have my whole weekends back to focus on the ta22 got stuck in this arvo. Welded some plates into the told towers to locate the new towers, not pretty but its definitely not going anywhere anytime soon and itll be hidden.. IMG_1375 by postlematt, on Flickr IMG_1376 by postlematt, on Flickr got on a bit of a roll and it was all on! IMG_1382 by postlematt, on Flickr IMG_1392 by postlematt, on Flickr IMG_1386 by postlematt, on Flickr Theyre both in and just have to weld the front plates on for a bit more strength, it was getting dark and wasnt the best light to weld in so hopefully ill have another crack at it after work tomorrow. IMG_1395 by postlematt, on Flickr Got to machine up some brackets to weld on the diff now that the suspension is in place. IMG_1398 by postlematt, on Flickr IMG_1397 by postlematt, on Flickr 3 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted September 9, 2014 Author Share Posted September 9, 2014 Rear shock diff mounts cnc'd and rear to weld on.. IMG_1455 by postlematt, on Flickr IMG_1459 by postlematt, on Flickr Welded on.. IMG_1461 by postlematt, on Flickr IMG_1501 by postlematt, on Flickr Also welded on the extra bracing for the towers.. IMG_1507 by postlematt, on Flickr IMG_1505 by postlematt, on Flickr 2 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted September 9, 2014 Author Share Posted September 9, 2014 Diff in and rolled her outside for a dust off, think i got the ride height pretty spot on 90mm all round. Also gave me a chance to clean up the shed haha. IMG_1469 by postlematt, on FlickrIMG_1487 by postlematt, on Flickr Also plasti-dipped two of the wheels to get idea of what they look like black.. and a few too many photos of her sitting under her own weight, enjoy haha IMG_1474 by postlematt, on Flickr IMG_1481 by postlematt, on Flickr IMG_1477 by postlematt, on Flickr IMG_1485 by postlematt, on Flickr IMG_1495 by postlematt, on Flickr IMG_1498 by postlematt, on Flickr IMG_1497 by postlematt, on Flickr //oldschool.co.nz/index.php?/topic/38745-matt-spitfires-ta22-daily-driver-buildresto/page-4 8 Quote Link to comment Share on other sites More sharing options...
matt_spitfire Posted September 30, 2014 Author Share Posted September 30, 2014 Not much to update.. I got a new windscreen today, 2piece driveshaft is in the shop being shortened up and having the hilux flange welded on , new radiator and inner/outer steering ball joints are on their way from australia. I've just done another bulk buy of parts from ebay, window seals, weather strips etc etc. I coated the inside of the sills in fish oil then folded up some sheet metal to sort out the sill caps it was a bit of a mish to weld, kept blowing through the original sheet metal. have another plate to go on the end of the sill aswell.. IMG_1593 by postlematt, on Flickr IMG_1594 by postlematt, on Flickr IMG_1602 by postlematt, on Flickr IMG_1603 by postlematt, on Flickr IMG_1603 by postlematt, on Flickr IMG_1599 by postlematt, on Flickr welded up the old fuel filler on the pillar IMG_1597 by postlematt, on Flickr 1 Quote Link to comment Share on other sites More sharing options...
