Sambo Posted May 15, 2013 Share Posted May 15, 2013 I'm a bit embarrassed to ask this, but I really can't be bothered fucking round on the driveway in the dark when the air is thick with mosquitoes. Brake lights (both sides and high stop light) have decided not to work. I remember that most cars have a fuse labelled 'tails' or something, but I can't find that on my carina (same as *t14* corona). No other blown fuses on the board. Is it likely to be the switch on the pedal or fuse located away from main board? Basically just looking for most likely causes to try and make this quick. In the time it took me to check the fuses I got more that 30 mozzy bites Quote Link to comment Share on other sites More sharing options...
fuel Posted May 15, 2013 Share Posted May 15, 2013 find the plug to the brake light switch under the pedals and then short the wires together. Check brake lights. If they are still off then it's likely a power feed/fuse issue. If the brake lights are now on then you have a faulty or mis-adjusted switch. Quote Link to comment Share on other sites More sharing options...
Sambo Posted May 15, 2013 Author Share Posted May 15, 2013 Awesome. Cheers for that. I was hoping there would be some simple test. Sounds like a job for smoko tomorrow. Quote Link to comment Share on other sites More sharing options...
