Got a wee bit of time out in the shed tonight got a few things done.
Fitted up the flexplate spacer to run an older series 700R4 box to the LS1. Fit a spacer between the crank and flexplate and some longer bolts an the ls1 flexplate mounts direct up to the the torque converter on the 700R4.
Bolted up no problems so that was good.
Engine has been sitting for a while and had a bit of crap all over it, took to a couple of spots with the wire wheel on the drill and cleaned it up mint, going to get a air die grinder and the small bits off that to get in the nooks and crannies and clean up prior to paint.
Had a heap of bits land last week so waiting for them to come out, also got a heap sitting in port in LA waiting to ship to NZ.
Panelbeater is well underway, will get some progress photos on Friday when I head over to TGA.
700R4 VN SS Commodore Trans
Flexplate spacer fitted up to the crank
Factory LS1 flexplate fitted up to spacer
Trans fitted up to engine
Cleaned up bits on the block
talking stuff http://oldschool.co....la/?hl=westpala
  • Replies 75
Fri arvo was mint day so went for blat on the Harleys to Tauranga to check out progress.
New floor pan and sills are all in. Currently working on the rear end now, new tubs, boot floor etc.
Cant speak highly enough of Phil at Fraser St Panelbeaters.....got a german guy working for him whos a gun at this sort of work, had to make a heap of hand made shit and man hes done a top job.
Give it another couple of weeks and should be bloody close to going off to paint.
Also had a huge order of shit turn up from the states on Fri so hopefully get that next week and ready for when the car comes home.
Can do 2 wheeled skids.
Broom broom.
Bought this posi rear end of the tard.
In other news had like half a car worth of parts turn up from america....waiting return of the car to fit them all.
Well things have been progressing along reasonably well....All taking longer than expected but i guess thats to be expected with projects like this!!
Panelbeater has been working away getting things closer to being ready for paint. Has had to hand make a heap of pieces luckily hes incredibly talented and its looking real good. Rear tubs and rear quarters have taken a bit of time and modification as you can only buy 2 door coupe guards & tubs which are slightly different to convertible ones. Hes had to modify these to suit which takes a bit of time!
Basically all the bits I need to finish the car are here now or on the way from the states.
Massive thanks to 64valiant for coming over and stripping the old seat coverings off my seats to make way for  the new ones from the states. Need to get the frames sandblasted and a few springs repaired but thankfully they are in not to bad nick considering their age.
Couple of pics of the panelbeating and interior.
And a mountain of bog on the original rear quarters!!
http://oldschool.co....la/?hl=westpala Talk away!
So fitted up the engine into a spare chassis i had to test start it.
Bit of rigged up wiring and fuel pump and we were away!
Then took the engine and 700R4 to the car and test fit to make sure the mounts worked, work out the mount spacers required and check the trans cleared the tunnel.
All fit bloody good so im happy with that.
Got some headers from the states from a LS1 S10 Chev truck  conversion. $200USD compared to the Impala conversion ones for $600USD. Cleared steering and everything so that was a good score!
  • 5 weeks later...
Lots happening over here.
Cars getting close to panelbeating being completed ready for paint
Have had a new thought on a colour,
Seen a few of these roll past and for some reason colour has jumped out at me.
Think black interior, black roof and chrome trim/bumpers etc.
http://www.trademe.co.nz/motors/used-cars/ford/auction-693385234.htm
Thoughts??
Have got the LS1 one to go, after a bit of dicking around, a small fire, a smashed spark plug and flat batterys the planets alinged and she fired into life!
Such a good moment!!
So finally getting closer to the light at the end of the tunnel.
Engine is getting pulled apart over the next week or 2 (once the tools i need turn up) to do the cam and valve springs, waterpump, gaskets and seals then paint to be ready for the engine.
Talk about paint, engine, car and bitches! Talk! http://oldschool.co....la/?hl=westpala
Great success 232/234 kelford cam is in and new valve springs also.
Gave her a fire up last night and all went to plan!
Ready for a clean up and paint/ready to go in car!
So things have been flat out and havent put an update up for a while but the cars progressing real well.
Rear tubs, boot floor and drop panels all in and welded up and sealed ready for rear quarters.
Doors have had rust cut out and partially reskinned followed up by being fitted up.
Now have the rear quarter on one side test fitting it up. Needs to be cut and modified as its a 2 door coupe quarter as this is the closest thing you can buy to a convertible quarter.
Stoked with the progress its coming along real well and cant wait to get the quarters on and ready for paint!!
The week at beach hop has given me a few ideas and extra bits to do.
Panelling my firewall now and running a wiper motor under the dash or small one in the cowling, removing my heater box also.
For the brakes have got a Alloy Willwood tandem master cylinder and will run a VH44 remote booster under the  dash or similar.
Should make for a super clean engine bay once it all gets painted and back in!
Talk some shit down there  > http://oldschool.co....la/?hl=westpala
Stumbled across a set of ITB's on TM this week which turned up today.
Should be something different and make for a clean bay with some alloy trumpets.
Got a few bits to remove to tidy up the engine and give it a paint but if it goes to plan should be good.
Off to check on the body tomorrow so hopefully there has been some progress made there!
Disucss here  > http://oldschool.co....la/?hl=westpala
  • Like 9
Went and had a check up on the 64 on Friday.
Bodys done bar the rear quarters.
Front ends being sorted rust/gapped up at the moment.
Starting to resemble a car a little bit more which is exciting!!
Need to get in the shed next week and clean up LS1 and paint block. Sort out bits nad pieces i need to make ITB's work and bolt down and shell be ready to go into the car.
700R4 trans is off being checked out and built up a bit better at present. Getting beefed up a bit got a mate in the auto industry so sorting it out for a suwweett deal.
Might as well do it while its on the floor rather than put in the car and find its poked!
So a mate works in the auto trans business and offered to get my box checked out and rebuilt as necessary for deals!
Luckily i did as the 700R4 was burnt out between 3 and 4 and the drive was poked.
So have got a whole heap of new bits, shift kit, stall converter, converter recondition and a heap of upgraded parts to handle a bit of power!
Getting put back together as we speak should have it back by next weekend to hopefully bolt up to the engine for the last time!
10262122_10152390258941138_8177727683177
Discuss here  > http://oldschool.co....la/?hl=westpala
So thinks are still happening!
Had a hold up with panelbeating as miss placed somewhere the body mounts that go  between body and chassis so they couldnt bolt up front and do rear quarters. Ordered some more from the states and they turned up on Monday so back into it last week.
Cant wait to see the body finished and back together ready for paint!
Am shaving the firewall so removing heater box, and getting rid of the wiper motor. Have managed to find a kit that alot of hot rodders use that runs off a worm drive, have ordered from the states and is on its way at the moment so hopefully it will do the trick!
Trans has been rebuilt and shift kitted, stall converter and a few bits and pieces to handle a bit more power.
10383684_10152409774306138_5928428432335
Had a wee package from Spun By Hutty AKA bulletz off the forum today.
Spun me up a couple of trumpets to test fit.
Super stoked with how they look going to look sweet with a full set on there.
Also had my sounds turn up today got some pioneer gear for a decent deal but will post pics when it comes time to fit it. Should do the trick!
10397829_10152418707136138_4258763204001
  • Like 9
Went for a wee visit last week. Shits getting real close now!
Tail light panels in. Remaining minor steel work will be done this week.
Spending the day with it on sat test fitting/drilling holes to fit all the trim and dummy up before paint.
Blank out firewall/heater box etc and its time to prep for paint.
Much excite!
Good progress.
Body panels have been epoxied and ready for filling/primer.
Body shell should go in the booth this week.
Any week now shell be off to get painted which is exciting.
Pic of hows shes looking at the moment.
10696325_10152675443126138_6742782714846
10687100_10152675443101138_8095299452391
Also my airbag kit turned up.
Bought a full accuair kit with Elevel set up. Super stoked with the quality of all the gear its well built,  compact and looks the part.
The complete valve box and control unit is below + the remote.
Cant wait to get it in and get some slam!
10378266_10152650643201138_7338651809787
Discuss here  > http://oldschool.co....a/?hl=westpala�
  • Like 8
