cletus Posted June 23, 2012 Share Posted June 23, 2012 discussion thread - viewtopic.php?f=18&t=34448 Picked up a new project today VH valiant ute. 273 V8/auto, is pretty good for one of these rust wise, has had a few repairs which need finishing. plans= dont spend too much, going to give the panelwork some attention and squirt it a flat/satin colour, slam, wheels. the green VJ was included as parts its ROTTEN. has a few good bits on it though. Quote Link to comment Share on other sites More sharing options...
cletus Posted July 8, 2012 Author Share Posted July 8, 2012 got some time to work on this masterpiece of commercial vehicles pulled front sheetmetal off, borrowed a waterblaster and cleaned 40 years of crap off the underside of it, and started patching some rust this bit was slightly rotten Quote Link to comment Share on other sites More sharing options...
cletus Posted July 15, 2012 Author Share Posted July 15, 2012 Made some progress- worst of the rust all done, just got a couple of little patches in the floor to do now. also strengthened the welding around the front upper arm mounts, these things are prone to cracking there. then threw some paint on, that turned out to be an abortion, got some "chassis black" that turned out to be quite glossy= looked like shit. so i thought id improve it by spraying some satin black over the top, wrong move, mustve breathed too many paint fumes today. it dried faster than the first layer and went all wierd now it looks ultra shit. dunno what to do there/might leave it cause its not showcar anyway rust, begone from this place! homemade sandblasting mask Quote Link to comment Share on other sites More sharing options...
cletus Posted July 29, 2012 Author Share Posted July 29, 2012 more progress, engine out of rusty one, and sold, gearbox out, engine out of good one for a tidy up. have got some headers, 4 barrel manifold, spare 600 holley off my other car, and have got some shiny bits on the way to tart it up, and some paint. also some good scores, the diff in the green one turned out to be a 3.23 lsd, and the trans in the good one is a 727. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 18, 2012 Author Share Posted August 18, 2012 chucked some paint in the general direction of the engine today. wheels are off getting widened, the wheels will also be this colour, body satin black. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted August 25, 2012 Author Share Posted August 25, 2012 steam roller wheels spent today removing luxury items- power steer was leaking, so put the manual box out of the green one in it, i dont like the v8 booster setup so wont run a booster. if you havent had the pleasure of seeing a chrysler v8 booster , here is one. yuck. theres a push rod off the pedal which isnt straight, which pushes on a pivot bar , which pushes the booster, all on a dumb angle. this is all cause the engine isnt in the middle of the car, its offset to the drivers side, so there isnt enough room. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted September 9, 2012 Author Share Posted September 9, 2012 A common rust trap on valiants is the plenum area under the windscreen. the heater gets fresh air from in here thru the vent. inside the plenum is not painted very well and has a couple of bits where water/leaves/dirt can sit and rust, and repairing rust is a prick, you really have to cut off the top, fix the rust and seal it all back up again. this one was pretty good, but as the heater didnt work anyway, and its going to be living outside and i hate wet carpets i decided to seal it up so it cant ever leak... 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted September 16, 2012 Author Share Posted September 16, 2012 pics>words Quote Link to comment Share on other sites More sharing options...
cletus Posted September 25, 2012 Author Share Posted September 25, 2012 a van full of awesome wheels done. will use stock hubcaps as well Quote Link to comment Share on other sites More sharing options...
cletus Posted November 23, 2012 Author Share Posted November 23, 2012 engine is a runner again. shouted it a new carb as a double pumper would have been a bit over the top for this engine, now has 500cfm vac sec edelbrock, hoping it will be fairly economical. also have rebuilt front suspension, i pulled it apart to replace one bent arm, and found as per every other valiant ive owned, everything was knackered. Quote Link to comment Share on other sites More sharing options...
cletus Posted November 25, 2012 Author Share Posted November 25, 2012 diff out of other ute ready to go in, 3.23 lsd, cleaned up and painted, made some new brake pipes, brakes all like new- bonus. next will be lowering the rear, have got some new u-bolts, will make some 2'' blocks, utes have a diffrent rear spring set with more leaves so some will go into the bin for freeslam Quote Link to comment Share on other sites More sharing options...
cletus Posted December 2, 2012 Author Share Posted December 2, 2012 rear suspension done, 2 leaves removed and 2'' blocks made, also got brakes working again parts one is impressing the neighbours no doubt 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted December 31, 2012 Author Share Posted December 31, 2012 http:// fixed more little bits of rust, drivers door and guard on for good, both front guards and bonnet painted underneath, inside floor painted, new guts friendly steering wheel. trying to find a passenger door or ill have to do some major surgery on the one i have Quote Link to comment Share on other sites More sharing options...
cletus Posted January 4, 2013 Author Share Posted January 4, 2013 nosecone fixed, had rot in corners Quote Link to comment Share on other sites More sharing options...
cletus Posted January 4, 2013 Author Share Posted January 4, 2013 tailgate pooed up, looked like a bag of walnuts to start with. still not perfect, fine for no shine black though....... Quote Link to comment Share on other sites More sharing options...
cletus Posted January 4, 2013 Author Share Posted January 4, 2013 stupid rusty door cut out all that cut bit out of rusty-in-different-places door off green one, have to just quickly weld a couple of patches into the patch before i weld in the patch I DISLIKE PANEL WORK IMMENSELY. 5 Quote Link to comment Share on other sites More sharing options...
cletus Posted January 17, 2013 Author Share Posted January 17, 2013 got stupid rusty door done Quote Link to comment Share on other sites More sharing options...
cletus Posted January 17, 2013 Author Share Posted January 17, 2013 tried wheel on now its lowered, front is good...... back not so much. rub city. oops Quote Link to comment Share on other sites More sharing options...
cletus Posted January 19, 2013 Author Share Posted January 19, 2013 so after checking axle lengths, and deciding narrowing the diff was too hard, i attacked the guards with a hammer & dolly. Rh side was easy. Lh side was like i thought it was going to be, it already had old repairs and bog in it, so it needs a bit of work. good part is the tyres fit with enough room. 2 Quote Link to comment Share on other sites More sharing options...
cletus Posted January 28, 2013 Author Share Posted January 28, 2013 front panels all primered also put a msd coil and ignition in it, now it runs a lot better. took it for a drive the other day, got the stink eye from a middle age lady in a fancy car, good job 3 Quote Link to comment Share on other sites More sharing options...
